Kelpie 2nd Gear December 25, 2007 Share December 25, 2007 Hi guys, 1. I've seen street cars fitted with smaller wheels for front and bigger wheels for rear? For example, 16" wheels for front and 17" wheels for rear. 2. What exactly are the purposes of doing so? Are there real benefits? Thanks. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Sniperben Neutral Newbie December 25, 2007 Share December 25, 2007 usually is on rear wheel drive car.. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear December 26, 2007 Author Share December 26, 2007 1. I see. Thanks for the info. Do you know why? 2. Does it mean for FWD, can use larger wheels for front and smaller wheels for rear? Regards, Link to post Share on other sites More sharing options...
Nus24 Neutral Newbie December 26, 2007 Share December 26, 2007 Some motorcycle has small wheels front and fat wheels rear. It gives a very macho stance! Actually my suzuki swift also fitted with wider wheels rear. Rim size same and rubber diameter same as well. Not much performance gain. Just want to be different. Link to post Share on other sites More sharing options...
Sniperben Neutral Newbie December 26, 2007 Share December 26, 2007 1. don't know.. my technical aspect of car is very poor.. 2. nope. never seen a FWD using different rim size yet. IIRC, MR-S, a rear wheel drive, in stock, come with bigger rear rim size. i think it come down to safely reason. Link to post Share on other sites More sharing options...
Sickscientist Clutched December 31, 2007 Share December 31, 2007 I guess u got mixed up between DIAMETER and WIDTH... Link to post Share on other sites More sharing options...
Freestylers09 5th Gear December 31, 2007 Share December 31, 2007 maybe reduce spin off since its RWD...push and pull factor... Link to post Share on other sites More sharing options...
Sickscientist Clutched December 31, 2007 Share December 31, 2007 Usually on RWD... Ever heard of torque multiplication? ↡ Advertisement Link to post Share on other sites More sharing options...
Benefits of having bigger population in our day to day life.
Is it illegal to fetch passengers at the back of a Suzuki Every?
See the road in front
Formula 1 Wheels Look Way Different for 2022. Here's Why. . .
DIY Curbed Wheel Fix - Was It Worth It?
Coaxial or Component for Rear speakers
Different front and rear tires
BBS wheels reportedly files for bankruptcy in Germany
