Yuan 6th Gear September 4, 2008 Share September 4, 2008 You must veri handsome to be stalked. ↡ Advertisement Link to post Share on other sites More sharing options...
Yuan 6th Gear September 4, 2008 Share September 4, 2008 I agree with you. Link to post Share on other sites More sharing options...
Apollo 1st Gear September 5, 2008 Share September 5, 2008 the principal is sound, how abt the vice principal? Link to post Share on other sites More sharing options...
Brock 1st Gear September 5, 2008 Share September 5, 2008 Thanks for the info. Now considering... Link to post Share on other sites More sharing options...
Brock 1st Gear September 5, 2008 Share September 5, 2008 Thanks. Read the PDF. Lots of other stuff in your shared BOX as well. Seems like the tech shows +ve results. Link to post Share on other sites More sharing options...
Apollo 1st Gear September 5, 2008 Share September 5, 2008 not mine.. the vendor's one. Link to post Share on other sites More sharing options...
Blue2 1st Gear September 5, 2008 Share September 5, 2008 and u like to stalk minah 1 Link to post Share on other sites More sharing options...
Nkps 1st Gear September 5, 2008 Author Share September 5, 2008 i think the vice principle liao Link to post Share on other sites More sharing options...
Mongater September 5, 2008 Share September 5, 2008 My battery is Motolite 55AH MF. The measurement before and after using Nanopulser for one month: CCA 672 -> 688 Internal resistance 4.76mohm -> 4.63mohm Well, the numbers are hard to lie as I saw them with my own eyes. So it does improve the condition of the battery. Do you really need high CCA value for Singapore weather? I've read this acticle on this sites it says... "if you live in a cold climate, the CCA rating should be an important consideration in choosing a battery. Conversely, if you live in a high heat climate, you don't need as much CCA." link here.. http://www.autobatteries.com/basics/selecting.asp Anyway, CCA value alone is not going to determine a battery condition.. you need other factor like SOC and HC value as well. Any Other opinion? 1 Link to post Share on other sites More sharing options...
Boyboy 1st Gear September 5, 2008 Share September 5, 2008 it's one of the signs of the battery condition lah.... Link to post Share on other sites More sharing options...
Kb27 Supersonic September 5, 2008 Share September 5, 2008 You don't need a high CCA. You could get by with the smallest battery enough to crank start your engine. Probably a 25AH battery is enough with maybe 300 CCA. However, my battery happened to be 55AH and the improvement in CCA is as boyboy said just one of the factor indicating an improvement in the condition of the battery. Imho, the measurement is relative. A big battery should not measure as a small CCA, that would mean the battery is going bad. Link to post Share on other sites More sharing options...
Smhomie Clutched September 6, 2008 Share September 6, 2008 Just a quick update on my battery readings since I came across this newly created thread. Took my measurements yesterday after stop driving for 3 hrs at home. My CCA is now at 579 and my impedance is at 5.50 milli-ohms a slight improvement over my previous recorded improvement.... a little mind boggling as I expected my previous readings to stagnate and not improve further.... but it did! But by only a fraction. 2 months ago my readings were 576 CCA and 5.58 milli-ohms. Battery was a 2nd hand 16 mth old Amaron battery. Now into its 19th month of service. Original battery sticker CCA value is 600. Nanopulser is the genuine article The benefits experienced is making the cost look cheaper and cheaper by the month..... 1 Link to post Share on other sites More sharing options...
Ozkaki 2nd Gear September 6, 2008 Share September 6, 2008 what device you used to measure al these? and how much to get one? 1 Link to post Share on other sites More sharing options...
Apollo 1st Gear September 6, 2008 Share September 6, 2008 i think the vice principle liao tat one is principal in charge of vice... u can ask her abt minah and her nano.. Link to post Share on other sites More sharing options...
Nkps 1st Gear September 6, 2008 Author Share September 6, 2008 go wash your toylet lar Link to post Share on other sites More sharing options...
Yuan 6th Gear September 17, 2008 Share September 17, 2008 Met the installer, Ian, yesterday at my office. Did another series of checks and readings on my battery 1 month plus after the installation of my nanopulser. Looks like the readings have improved. Impedance have been reduced and my CCA readings have improved by more than 10%. Thumbs up for the nanopulser. Heard that if the battery is going to up the lorry, the nanopulser's light will turn orange first before it turns red (that is when the battery say bye bye to you). Link to post Share on other sites More sharing options...
Nkps 1st Gear September 17, 2008 Author Share September 17, 2008 i place order liao but no stocks, got to wait... Link to post Share on other sites More sharing options...
Calefare Neutral Newbie September 17, 2008 Share September 17, 2008 Sorry newbie here Install already will affect warranty or not? Thanks in advance ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Nanopulser World Series Challenge Featuring Legendary Tracks
Nanopulser
Nanopulser
