Tanlc Neutral Newbie November 6, 2008 Share November 6, 2008 I'm confused... Read that the following configuration for Honda FIT - Red dot is 1.3L (M) or (A) - Blue dot is 1.5L (A) 7-Spd CVT Does that mean that the above uses different transmission oil? The Red dot uses normal ATF, while the Blue dot uses CVTF? ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 6, 2008 Share November 6, 2008 diff kind of tranny use diff kind of oil. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 6, 2008 Share November 6, 2008 Yours manual or CVT? If CVT, just get CVTF will do. Link to post Share on other sites More sharing options...
Tanlc Neutral Newbie November 6, 2008 Author Share November 6, 2008 Pardon my ignorance.. heh My FIT is Auto, but not sure if it is CVT Link to post Share on other sites More sharing options...
Ekul Neutral Newbie November 6, 2008 Share November 6, 2008 if ur fit is auto then it is using CVT auto transmission. have to use CVTF.. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 6, 2008 Share November 6, 2008 Yes, your is CVT. Get CVTF. Link to post Share on other sites More sharing options...
Jellyfish 1st Gear November 7, 2008 Share November 7, 2008 I'm confused... Read that the following configuration for Honda FIT - Red dot is 1.3L (M) or (A) - Blue dot is 1.5L (A) 7-Spd CVT Does that mean that the above uses different transmission oil? The Red dot uses normal ATF, while the Blue dot uses CVTF? yes they are diff, anything 1.3fit or 1.4 jazz is red dot blue dot is 1.5 version, cvt and manual uses different tranny oil, manual uses honda MTF3 oil, and auto uses CVTF or HMMF oil for their cvt auto Link to post Share on other sites More sharing options...
Jellyfish 1st Gear November 7, 2008 Share November 7, 2008 yup, your auto is using cvt gearbox Link to post Share on other sites More sharing options...
Zhngmycar 1st Gear September 19, 2013 Share September 19, 2013 Hi everyone do not use cvtf for exported honda jdm model lile airwave jazz and fit etc as those model fit in hmm gearbox not the common cvt gearbox. If ur workshop recommand cvtf u can consider changing the fluid! As those model are required to use hmmf oil for the gear box! Please take note as this fluod would run.more then 20k without any jerk ↡ Advertisement 1 Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
