Bro, does brake fluid need to top-up? I tot it is a closed system....
I am surprised you could still brake properly when your fluid is almost empty.... [laugh]
Read the manual book to check brake fluid if sensor light is activate and voila. Will monitor again in the next few rides....also 60k servicing coming soon.
Yeah that time brakes still good.....the power of Exora [;)]
Share this post
This job should be done by the SC itself as it looks like a ABS system issue.
The Handbrake light issue also should be related.
You can read this old article for reference (not sure whether it is already outdated due to the new ABS systems).
http://www.eobdtool.com/blog/2011/08/my-br...t-does-it-mean/
thanks Mandrew, i managed to fix the problem by replacing the cable sensor, cost me M$185 (same price when i asked the workshop in sg, but they dont hv the part) :D
Apologize to Panhard of not "jio" you, it just happen that i went to Gelang Patah to pay a visit to my friend and they brought me to Proton service centre somewhere near to my friend house :)
Share this post
You mean the WS in SG charge you also RM185? Or is it SGD185 ?
Share this post
SG 185, they called someone for the part.
Share this post
Dear Exorians,
Has anyone encounter such an issue:
Driving at high speed , going down slope and depress the brake pedal. There is this feeling of gear change but when you accelerate the RPM will increase and the engine sounds slightly noisier. After few distance it stabilises and manoeuvre as usual. The mechanic in Proton JB service centre says it is normal.
Is it true?
Share this post
ooo didnt know auto also got clutch oil, will go check n see if my have too... thanks
Share this post
Dear Exorians,
Is it true?
i tink that is bcos the engine downshift to lower gear.
Share this post
Dear Exorians,
Is it true?
yap , for the auto like my one, it is normal [;)]
Share this post
I remember having the same scenario in my CPS and infact I brought it back to SC for checking.
They informed that it is a auto gear shift down feature. But I didn't notice the RPM during that time....
But the Craziest thing is that after I installed the Power Charger, I didn't fell that much..... (to my knowledge the Power charger was only to stabilise the current)... maybe... it was just a psychological thought [:p]
Share this post
Thanks bro shorty, bro SGXora and bro Mandrew for the comments. Appreciate it.
Edited by Iz_Exora
Share this post
My problem is the ABS light, after 60K major service in my hometown, the light kept lid. sent in to local workshop and had the system reset. the light goes off for awhile but came back when i applied the brake.
any suggestion is much appreciative.
Just go to any Johor service Ctr and have ur Abs sensor changed.I change for RM200 and its fine until now.
Share this post
Have u try cold air intake?My 2 friends driving Gen2 1.3/Exora 1.6 using them and the response is quite good.Fuel economy improve a bit
Share this post
I haven't tried Cold air intake. But tried out the HKS power compressor in my old CPS. Didn't feel much improvement in the Fuel efficiency but the response was great. If the timing of the Compressor is bit out, it will drink more petrol [rolleyes]
You can see the photo below.
Share this post
No worries bro [rolleyes]
Share this post
Everything is okay. Looks like sensor or some other thing. Have to go workshop to check.
Some cars if brake fluid low or brake pads finishing...e handbrake light wil come on to warn u.
Share this post
Thanks bro. Already top up the brake fluid.
Share this post
Hv e abs sensors checked. Maybe ty disturb a sensor during service. There r several sensors. Each wheel has one n near front bumper is another.
Share this post
I checked the brake and clutch fluid and its almost empty. Top up with mobil dot 4 (small box) and voila the handbrake sensor is gone. Rechecked and no leaking [sweatdrop] phew
Suspect that the previous 2 servicing the guy forgot to top up but there's no proof - just a hunch though.
Even if there is no leak...yr brake fluid wil drop as yr brake pads wear n get thinner. If e level is very low chk yr brake pads fr wear.
Share this post
Guest
