Pumped Diesel into Suzuki Swift
Pentrain
Just got a message from my friend..
a pump attendant pumped abt 10 litres of diesel into his 3 yrs old suzuki swift..anybody know any complications or wad he should do??
please advise, thanks!
If sufficiently diluted, then it will just smoke. If the car can't run, then he/she has no choice but to drain the tank and fuel system and refill with petrol.
10 litres is a lot... assuming he have very little petrol inside as he is at the petrol station. dont risk it. get some1 to drain the mixture out and pump fresh petrol inside.
and ask the blardy petrol station to compensate your friend. ( make sure he have the evidence )
which petrol kiosk is this... For Esso they split the diesel and petrol pumps so this can never happen... weird stuff.
He should note down the date & time it happened. Notify the kiosk person in-charge, note down his name & IC and the pump attendant's. Take out a piece of paper and write a declaration that they will be liable and all checks & repairs bills they will be responsible. Call a tow truck tow back to workshop and flush out the diesel, thoroughly flush the fuel system to prevent contamination.
Confirm Diesel Nozzlle diameter is bigger then Unleaded petrol.
Even Leaded Petrol Nozzle is bigger then Unleaded ones.
Modern cars are fitted with a smaller size nozzle inlet so that
only UL petrol can fill in from the pump.
Even my 1995 Punky Nissan March is fitted with this feature.
Unless the Diesel is filled in to the car without having the nozzle
fully inserted to the Petrol inlet.
Edited by Godfinger
Ur friend is joking with U lah...
How to pump diesel into the Swift unless the uncle pour it in.
As mention by others, the nozzle simply doesn't fit!
ok bro, thanks all for your reply.
i will check with him n let him noe ur suggestions but i don't think he is joking.
he shld have the receipt or something when he pay but i dun tink he took down detail of the pump attendant.
thanks alot once again
Uncle? Can be [gorgeous] FT? So TS friend [inlove] and pump it in himself? [laugh]
Only few months ago, the pump attendant used a funnel to pump diesel into my company's Toyota Liteace (Petrol). They are real innovative.
Good thing it was only $10. At first cannot start.
Then our driver topped it full with petrol. After that, there was no problem.
that's why you should always pump the petrol yourself. just ask the uncle to wipe your glass.
best to flush system - not too difficult job.
Edited by Kyojin
i agreed. DIY is the best.
epic win, pump attendant trying to save money for you guys. if your friend pumped full tank of diesel and made it home probably he's s**tting you. if it really works let us know the result, increase performance, engine smoother etc? old SS running 1.3L suzuki engine right? if it works i'll switch to diesel too. lol.
ok guys, now for the update..
it happened at ESSO in toa payoh..n the pump attendant might be sleeping..cos its past 3am..this i could verify becos it happened after i met him..
anyway..he called up esso and complained..and they arranged for tow truck to bring his car to their service centre..near thomson if not wrong and drain the fuel..gave him a full tank of synergy 8000 FOC
hmm..he went to check out and told me the nozzle for diesel and other petrol are the same..haha..i shld check it out later..
cheers and thanks for all the replieS!
