TebogoPeterMakinita Neutral Newbie January 12, 2019 Share January 12, 2019 Hi there, My car proton persona don’t want to go into gear all of the sudden, what could be the issue? ↡ Advertisement Link to post Share on other sites More sharing options...
Cypher 4th Gear January 14, 2019 Share January 14, 2019 (edited) Hi there, My car proton persona donât want to go into gear all of the sudden, what could be the issue? Transmission Cable broken? Edited January 14, 2019 by Cypher Link to post Share on other sites More sharing options...
RynerWong Neutral Newbie January 17, 2019 Share January 17, 2019 My Proton Persona Elegance bring me serious trouble now. Recently, the engine oil light blink n then stay on like that. Then the engine started to sounds like diesel engine.Cut story short, I had go to a workshop n they did the service of the bottom engine crank case/oil sump. After that refill new engine oil brand Pulzar 10-40w. They tested 1 day it was ok. Then the other day i went there n took my car. Drive out highway, refuel n not even 30mins...the car went back into the same problem at 1st.Now, the mechanic said, the engine cant save anymore. It needed a general overhaul.Anyone got this problem before for Proton persona elegance model 2013? Seriously need an advise here. Not sure really need to overhaul or not as of about last year i just had a top overhaul process due to timing belt broken. Head of the engine already been taken to engineering department to shim. All valves changed. Crank case just been cleaned up as well. Thou, they claimed that seeing some water sign in the oil sump. Oh ya, at the same time. My radiator seems like the water kept on reducing. No any leaking seen while the car stopped. ALready glued the hose attached to top radiator cover. Link to post Share on other sites More sharing options...
Contipro 5th Gear January 18, 2019 Share January 18, 2019 My Proton Persona Elegance bring me serious trouble now. Recently, the engine oil light blink n then stay on like that. Then the engine started to sounds like diesel engine. Cut story short, I had go to a workshop n they did the service of the bottom engine crank case/oil sump. After that refill new engine oil brand Pulzar 10-40w. They tested 1 day it was ok. Then the other day i went there n took my car. Drive out highway, refuel n not even 30mins...the car went back into the same problem at 1st. Now, the mechanic said, the engine cant save anymore. It needed a general overhaul. Anyone got this problem before for Proton persona elegance model 2013? Seriously need an advise here. Not sure really need to overhaul or not as of about last year i just had a top overhaul process due to timing belt broken. Head of the engine already been taken to engineering department to shim. All valves changed. Crank case just been cleaned up as well. Thou, they claimed that seeing some water sign in the oil sump. Oh ya, at the same time. My radiator seems like the water kept on reducing. No any leaking seen while the car stopped. ALready glued the hose attached to top radiator cover. yours an isolate case as you mentioned timing belt broken.most case in Malaysia for such incident normally just replaced with a engine from donor car. ↡ Advertisement Link to post Share on other sites More sharing options...
New Proton Perdona.
New Proton Perdona.
Proton overseas
Proton overseas
Proton To Introduce smart Electric Vehicles In Malaysia
2022 Proton Persona 1.6 Premium
2022 Persona & Iriz facelift
27 year old Malaysian save money driving a 21-year-old Proton Saga
Proton Exora#2
Proton Exora#2
Proton X50
Proton X50
