Ody_2004 Turbocharged April 19, 2020 Share April 19, 2020 Any plumber to recommend? I need to change the whole WC which is leaking.. the leak oso dunno from where... Need his to supply and install ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic April 19, 2020 Share April 19, 2020 (edited) 30 minutes ago, Ody_2004 said: Any plumber to recommend? I need to change the whole WC which is leaking.. the leak oso dunno from where... Need his to supply and install Referred by hdb gofix Maybe you can try them. Or this Edited April 19, 2020 by Kb27 2 Link to post Share on other sites More sharing options...
inlinesix Supersonic April 19, 2020 Share April 19, 2020 1 hour ago, Ody_2004 said: Any plumber to recommend? I need to change the whole WC which is leaking.. the leak oso dunno from where... Need his to supply and install Mr Lau 97911101 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 19, 2020 Share April 19, 2020 2 hours ago, Ody_2004 said: Any plumber to recommend? I need to change the whole WC which is leaking.. the leak oso dunno from where... Need his to supply and install Just Google "plumber near me". Find one that has a hp number and call. Change whole WC?? If it's leaking means the rubber seal of the flush assembly is dirty or needs replacement. You dont need to change the whole WC. 3 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged April 19, 2020 Share April 19, 2020 7 hours ago, Watwheels said: Just Google "plumber near me". Find one that has a hp number and call Change whole WC?? If it's leaking means the rubber seal of the flush assembly is dirty or needs replacement. You dont need to change the whole WC. Rubber seal and flush assembly i done.. the leak seem from the internal porcelain area which i got no way to repair.. so I guess is to replace whole wc.. challenge is now CB.. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 20, 2020 Share April 20, 2020 3 hours ago, Ody_2004 said: Rubber seal and flush assembly i done.. the leak seem from the internal porcelain area which i got no way to repair.. so I guess is to replace whole wc.. challenge is now CB.. You can try using ready made plaster or quick dry fillers at DIY store to repair the leak...I think selffix still open. I see the outlets at Vivocity and GreatWorld are open. Some kinda quick fix but might not be a permanent fix. At least can tahan until the CB is over. 2 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged April 20, 2020 Share April 20, 2020 24 minutes ago, Watwheels said: You can try using ready made plaster or quick dry fillers at DIY store to repair the leak...I think selffix still open. I see the outlets at Vivocity and GreatWorld are open. Some kinda quick fix but might not be a permanent fix. At least can tahan until the CB is over. Thank for the suggestion. The problem is I cannot locate the leak. I guess must be internal.. guess need to tahan till CB over.. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 20, 2020 Share April 20, 2020 (edited) 23 minutes ago, Ody_2004 said: Thank for the suggestion. The problem is I cannot locate the leak. I guess must be internal.. guess need to tahan till CB over.. Check and see if it's because of the float. If the float mechanism fails the water will keep filling the tank until it overflows. In that case it's not a leak. It's highly unlikely for the porcelain WC to leak on its own. Once the water level reaches its designated volume the float acts as a switch to stop the valve from supplying water. If it doesnt work it will keep supplying water until your WC overflows. What you can do is on/off the main valve along the water supply hose. Once the WC is filled turn it off. Edited April 20, 2020 by Watwheels 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 9, 2023 Share January 9, 2023 Anyone rewire your HDB flat recently? Any company to recommend? Thanks. Link to post Share on other sites More sharing options...
Freeder Hypersonic January 9, 2023 Share January 9, 2023 Look for David @ 9732 6129 Say Victor intro.. Did my office wiring with him and workmanship was good and also cheaperest among 4 quotes.. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 9, 2023 Share January 9, 2023 (edited) 16 minutes ago, Freeder said: Look for David @ 9732 6129 Say Victor intro.. Did my office wiring with him and workmanship was good and also cheaperest among 4 quotes.. Thanks bro!! Will WhatsApp him. Edited January 9, 2023 by Fcw75 ↡ Advertisement Link to post Share on other sites More sharing options...
Electrician lobang?
Electrician lobang?
DIY plumber
DIY plumber
COE Mercedes - Reliable?
Help with STA report remarks
