Mercury1 Turbocharged April 26, 2018 Share April 26, 2018 Anyone using Steelmate TP-77 with external sensors? How is it?I used to use it, does the job and quite accurate. Only annoying part is when refilling the air have to unlock the locking nut hence i change to internal. If ur considering and dun mind used I can make u a good offer on my old set which I put in storaged ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 26, 2018 Share April 26, 2018 Anyone using Steelmate TP-77 with external sensors? How is it? I used it before too, has been pretty accurate, but it became too tight on one wheel, so had trouble trying to remove it to pump air. So key is not to overtighten the sensor and the locking ring behind it. 1 Link to post Share on other sites More sharing options...
Nicholas 5th Gear April 26, 2018 Share April 26, 2018 I used it before too, has been pretty accurate, but it became too tight on one wheel, so had trouble trying to remove it to pump air. So key is not to overtighten the sensor and the locking ring behind it.The locking nut behind is for anti theft. If you don't lock hard then the nut is unnecessary. 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 26, 2018 Share April 26, 2018 (edited) I used to use it, does the job and quite accurate. Only annoying part is when refilling the air have to unlock the locking nut hence i change to internal. If ur considering and dun mind used I can make u a good offer on my old set which I put in storaged Thanks bro, I am quite a fussy person so better not. Got any misunderstanding then not nice. But if one of the sensor get stolen by A-hole, then have to buy a whole set right? Edited April 26, 2018 by Fcw75 Link to post Share on other sites More sharing options...
Mercury1 Turbocharged April 26, 2018 Share April 26, 2018 Sure thing bro nps, But yes as you mentioned if One kanna lost or stolen have to get new set. That’s another downer 1 Link to post Share on other sites More sharing options...
Bluemint 2nd Gear April 26, 2018 Share April 26, 2018 (edited) Thanks bro, I am quite a fussy person so better not. Got any misunderstanding then not nice. But if one of the sensor get stolen by A-hole, then have to buy a whole set right? I removed the locking nuts becoz they are annoying when I need to top up the air pressure. Stealing one, or even a set of four, is pretty useless unless the thief also steal the display, isn't it? So why worry over it? Yup, must change all four. I know becoz one of them went dead after slightly over a years and the seller refused to sell me just one sensor. I'm using internal ones now and happy that they don't spoil the look of my rims, and best of all, protected from the elements and hence should last longer Edited April 26, 2018 by Bluemint 1 Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear April 26, 2018 Share April 26, 2018 For my previous and current ride, I bought and use TPMS with internal sensors. Pros: Better accuracy as compare to External sensors. Looks nicer without the big looking black tyre caps (External Sensors) Cons: When doing tyre rotation, Driver need to be mindful which readings are front or rear as most TPMS do not allow reset the Front & Back readings Above is my personal opinions. 2 Link to post Share on other sites More sharing options...
Kklee 6th Gear April 27, 2018 Share April 27, 2018 Why the need to rotate tyres ? Bcuz it's recommended ? What's it supposed to do ? When I was driving my van, I change tyres in 2s, not 4s. It's either front or back. I never rotate them. They always wear out evenly. The only time they wear unevenly is when the front toe is out of spec. Keep the front alignment correct and there's no uneven wear, and no need for tyre rotation. IMHO, those that park at higher level of MSCP will likely have uneven wear. Link to post Share on other sites More sharing options...
BlueSoap 1st Gear May 9, 2018 Share May 9, 2018 Anyone using the more atas ZUS system? Would love to hear some reviews. https://www.nonda.co/products/connected-car-device?prod=stsm Link to post Share on other sites More sharing options...
Sotong07 3rd Gear May 10, 2018 Share May 10, 2018 I am using the TPMS with internal type sensor. No need to worry loss / theft / troublesome in securing and releasing of nut. If you regularly do tire rotation, balancing and alignment, then its quite convenient to switch the sensors around. Link to post Share on other sites More sharing options...
Mercury1 Turbocharged May 10, 2018 Share May 10, 2018 Seems abit troublesome to be honest, Got the big soap bar receiver and still use handphone for display (which might already be used for waze etc) Would opt for something with a small display. Anyone using the more atas ZUS system? Would love to hear some reviews.https://www.nonda.co/products/connected-car-device?prod=stsm Link to post Share on other sites More sharing options...
BlueSoap 1st Gear May 11, 2018 Share May 11, 2018 Seems abit troublesome to be honest, Got the big soap bar receiver and still use handphone for display (which might already be used for waze etc) Would opt for something with a small display. Small plug in display? What would you recommend then? Most of the systems I've seen in the market uses phone apps now. Link to post Share on other sites More sharing options...
Cochran 1st Gear May 11, 2018 Share May 11, 2018 Anyone using the more atas ZUS system? Would love to hear some reviews. https://www.nonda.co/products/connected-car-device?prod=stsm i been using it. No problem so far. Got it much cheaper during last black friday sale. Link to post Share on other sites More sharing options...
Mercury1 Turbocharged May 11, 2018 Share May 11, 2018 Small plug in display? What would you recommend then? Most of the systems I've seen in the market uses phone apps now.I’m using the steelmate tpms tp77, display is plugged into the cig lighter. Link to post Share on other sites More sharing options...
inlinesix Supersonic May 11, 2018 Share May 11, 2018 Small plug in display? What would you recommend then? Most of the systems I've seen in the market uses phone apps now. Taobao has Philips TPMS. The display is charged via solar power. Link to post Share on other sites More sharing options...
CronusWeer May 12, 2018 Share May 12, 2018 have u installed TPMS? Link to post Share on other sites More sharing options...
BlueSoap 1st Gear May 15, 2018 Share May 15, 2018 Taobao has Philips TPMS. The display is charged via solar power.I saw that too. Thanks! Link to post Share on other sites More sharing options...
MayYang Neutral Newbie June 4, 2018 Share June 4, 2018 pardon me for asking, external sensors refer to those cap TPMS? are they accurate? thinking of investing a set since every few months, i will travel far. a good indicator to know my tires are ok. The externals sensor work accurate as internal sensor, what different is external sensor battery can not last long as the internal sensor but the battery can not replaced. vehiclegpstracker.net ↡ Advertisement Link to post Share on other sites More sharing options...
