Micb 5th Gear May 6, 2022 Share May 6, 2022 Bringing this topic up again, as I have noted alot of tough water spots staining the windscreen, especially in those area where the wiper coverage is lacking. saw in YT, that using the super fine grade 0000 steel wool with soapy water can clean off these tough spots and stains. Anyone tried? Comment please. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 15, 2022 Share May 15, 2022 try use clay bar and lots of soapy water. it helps. 1 Link to post Share on other sites More sharing options...
Invigorated Supercharged May 15, 2022 Share May 15, 2022 Cos of covid, I've experimented with those pure alcohol wipes, even those alcohol hand sanitisers, and some of them have removed the water spots brilliantly. Maybe mine aren't those hardcore stains yet but they do work well enough. Looks like covid isn't the only stuff it removes. 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged May 15, 2022 Share May 15, 2022 On 5/6/2022 at 2:29 PM, Micb said: Bringing this topic up again, as I have noted alot of tough water spots staining the windscreen, especially in those area where the wiper coverage is lacking. saw in YT, that using the super fine grade 0000 steel wool with soapy water can clean off these tough spots and stains. Anyone tried? Comment please. Thanks. Glass polish cerium oxide. 1 Link to post Share on other sites More sharing options...
Micb 5th Gear May 15, 2022 Share May 15, 2022 11 hours ago, StreamRSZ said: try use clay bar and lots of soapy water. it helps. Thanks, perhaps the light abrasive nature of the claybar helps too 11 hours ago, Invigorated said: Cos of covid, I've experimented with those pure alcohol wipes, even those alcohol hand sanitisers, and some of them have removed the water spots brilliantly. Maybe mine aren't those hardcore stains yet but they do work well enough. Looks like covid isn't the only stuff it removes. This method is the simplest to try out, 😄. Will use some alcohol based wipes to try out. 9 hours ago, Mkl22 said: Glass polish cerium oxide. Thanks, is the cerium oxide key ingredient in those off the shelf glass oil film or stains cleaner? Or how to get it? Link to post Share on other sites More sharing options...
Kb27 Supersonic May 16, 2022 Share May 16, 2022 On 5/6/2022 at 2:29 PM, Micb said: Bringing this topic up again, as I have noted alot of tough water spots staining the windscreen, especially in those area where the wiper coverage is lacking. saw in YT, that using the super fine grade 0000 steel wool with soapy water can clean off these tough spots and stains. Anyone tried? Comment please. Thanks. If you have some Kao color bleach (liquid form), you can try this first. Link to post Share on other sites More sharing options...
Micb 5th Gear May 16, 2022 Share May 16, 2022 2 hours ago, Kb27 said: If you have some Kao color bleach (liquid form), you can try this first. Ok, I have bleach at home, will try it as well. Thanks Link to post Share on other sites More sharing options...
Kb27 Supersonic May 16, 2022 Share May 16, 2022 1 hour ago, Micb said: Ok, I have bleach at home, will try it as well. Thanks Don't use regular (chlorine) bleach. Use Kao color bleach, which is oxygen bleach. ↡ Advertisement Link to post Share on other sites More sharing options...
how to remove micro/fine scratches on windscreen
Recommendation for Spectacles
