Darryn
Springs and Shocks Together?
To all the knowledgeable bro and sis,
My car's shocks are starting to leak, and I need to start considering replacing them.
I was thinking of replacing the springs at the same time with a set that is slightly lower and maybe a tad harder to give the car better handling.
This is a Wish, so it doesn't need anything fantastic, just a small improvement would be enough - I would also need to sneak it past the FC who would veto any drastic performance mods.
Was just tinking that while got the car in pieces for shocks, may as well do springs as well and save on labour...
Thoughts?
Share this post
change to after mkt gas shocks will be sufficient if u want a little better and not so drastic
Share this post
Hi bro, why don't you look at a set of coil-overs ?
This would solve your spring+shock issue.
Depending on which model you get,
can be adjusted for Damping(Hardness) and Height
Share this post
I can adjust the height myself? Would be good to lower the car by around 3 cm - stiffen up just a little would be good (less roll, better turn in)
If I did this should I also go for the front end stiffening bar thingy that can be put in engine bay?
Share this post
Just go for aftermarket gas shock absorber with lowered spring safe money for other things like strut bar,anti roll bar and braces.. [thumbsup]
Share this post
On budget, go for koni shocks plus lowered springs, stiffness and height adjustable, then get front strut bar and rear anti roll bar for better handling. Perhaps you can go JB to get , labor is cheap too.
Share this post
Turbocharged (edited)
Sure on budget - wifey woman already scold for drive too fast.
How much we talking about here? And the changes should not be obvious when driving casually, if suddenly turn from relatively smooth into STi like ride then die lor, sure will get whacked big time...strut front and anti roll rear is good idea - stiffen things up abit without too much adverse effect on ride...
Edited by Darryn
Share this post
Where can get height adjustable Koni shock absorbers locally beside JB ??? what's the price like ???
Thanks.
Share this post
Bro your car still so new so if you are only changing the shock absorber, you don't need to change the springs. There will be minimal effect and I don't think you will feel the difference unless you want to change ride height which your OC will immediately notice. If you want to have difference in damping stiffness you can try KYB's AGX range but I am not too sure if they have products for Wish.
Share this post
if u change to coilovers, your CO will definitely know that you have spent her money... ^_^
Share this post
Yup. Coilovers very hard, even if u put the settings to the softest. If u on a budget, just change to new shocks and retain ur original springs but put spring stiffeners. It wil b a tad hard. But dun expect miracles like heaven ans earth. To me, tis way meets ur expectations perfectly.
Share this post
Actually, can get OEM shocks and just change.
Retain comfort level of travel.
Share this post
Clutched
you may get new or second hand part for this.quite cheap actually.try do it in JB.will cost you less.
Share this post
What kind of car are we talking about here? Sorry if I missed in the posts above.
I wouldn't waste your money on chassis stiffeners...unless you like the look of them. Best bang for the buck would be a good shock (adjustable or not) and depending on the type of car, either sport springs or +1 or +2 wheels and tires, the shorter sidewall will help eliminate the roll of a taller tire.
Share this post
any idea how much does an oem shock cost? Im on aftermarket spring, thinking of changing to koni shock but wanna retain comfort.
does the price differ alot compare oem and koni?
Share this post
1st Gear
For OEM shock can check with stockist on price. Most of the time it is not worth to go back to OEM due to the high pricing.
If you have changed to aftermarket springs, most likely the spring rate is higher so you have already compromised on comfort. It is thus important that the shock can handle the spring rate and its valving characteristics is tailored for cushy ride.
Best to check on what an aftermarket equivalent to your OEM shock is and then read up more on whether it is suitable for your needs.
Share this post
haha that is why my shocks' lifespan is abt 3yrs+ only
thanks will check it out
Share this post
