Kurty Supercharged December 28, 2015 Share December 28, 2015 for the past few days, It's noticeable to tell the difference with and without the grounding.. engine not that smooth despite I did a major replacement last month and with new battery on last sat. ICE also as weaker as compare to previous setup. hence conclude that ground does helps a little, nothing on performance. just enhancing the ride condition. ↡ Advertisement Link to post Share on other sites More sharing options...
Meemee 5th Gear December 28, 2015 Share December 28, 2015 If I'm don't remember wrongly its 10AWG?!Using AWG 0 Link to post Share on other sites More sharing options...
dcb Turbocharged December 28, 2015 Share December 28, 2015 Then i must have remembered wrongly. Using AWG 0 Where do you connect the hoses to and from? You grounded so many points in your ride? The grounding cables I m usingAwg0 / OFCCar runs smootherAcclecration smoother and better responseIdling - steady / no more trembling feel at traffics junctionAuto gear shift is smootherIt also very skeptical about how grounding cables worksPerhaps we should look at the size of the cablesYou hate it or you don't Link to post Share on other sites More sharing options...
Meemee 5th Gear December 28, 2015 Share December 28, 2015 Then i must have remembered wrongly. Where do you connect the hoses to and from? You grounded so many points in your ride? I m doing only 4 points And that enough for me:) Ride has been excellent :) 1 Link to post Share on other sites More sharing options...
dcb Turbocharged December 28, 2015 Share December 28, 2015 Oh. I thought you grounded many points from the amount of ground cables you have in the photos. I m doing only 4 pointsAnd that enough for me:)Ride has been excellent :) Link to post Share on other sites More sharing options...
Meemee 5th Gear December 28, 2015 Share December 28, 2015 Oh. I thought you grounded many points from the amount of ground cables you have in the photos. The Many points is the stock grounding Link to post Share on other sites More sharing options...
dcb Turbocharged December 28, 2015 Share December 28, 2015 Huh? In your photos you show many ground cables with bioth ends crimped with cable lugs. Thats what i meant by so many. The Many points is the stock grounding Link to post Share on other sites More sharing options...
Meemee 5th Gear December 28, 2015 Share December 28, 2015 (edited) Huh? In your photos you show many ground cables with bioth ends crimped with cable lugs. Thats what i meant by so many. Those are for other cars owner Fixing up for them Edited December 28, 2015 by Meemee Link to post Share on other sites More sharing options...
dcb Turbocharged December 28, 2015 Share December 28, 2015 Oh! No wonder bro. Anyway you have a PM. Those are for other cars ownerFixing up for them Link to post Share on other sites More sharing options...
dragonballdidi 2nd Gear June 27, 2020 Share June 27, 2020 Do i need to replace my old grounding cable? It is bit worn by now. Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 27, 2020 Share June 27, 2020 25 minutes ago, dragonballdidi said: Do i need to replace my old grounding cable? It is bit worn by now. Yes Just like if your toothbrush is worn out would you change it? 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic June 27, 2020 Share June 27, 2020 4 hours ago, dragonballdidi said: Do i need to replace my old grounding cable? It is bit worn by now. Replace with @Meemee la. Link to post Share on other sites More sharing options...
Meemee 5th Gear June 27, 2020 Share June 27, 2020 Why Meemee 🙂 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic June 27, 2020 Share June 27, 2020 2 hours ago, Meemee said: Why Meemee 🙂 Thought you might still be doing the grounding wires business. Link to post Share on other sites More sharing options...
Meemee 5th Gear June 27, 2020 Share June 27, 2020 No bussines close shop.... Liao 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic July 10, 2020 Share July 10, 2020 On 6/27/2020 at 10:21 PM, Meemee said: No bussines close shop.... Liao Alamak. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
E Power Voltage Stabilizer
HKS grounding kit
HKS grounding kit
2016 Estima Driving voltage 12.2V. Normal?
Need advice on grounding for Pivot Mega Raizin kit
Voltage stabiliaer for home
Voltage Stabilizer,Is it necessary?
