Somebody
Help! my ABS kicks in waaayyy too easily!
1st Gear
it kicks in when i go over a bump!
it kicks in when i go over those metal humps!
when it rains, it kicks in waaay sooner than what my gen2 or camy does...
resulting in a ssssuuuupeeer long stopping distance...
any explanation?
possible that i have a faulty ABS? or its just that my tyres are not grippy enough?
Share this post
5th Gear
Maybe is the tyres wearing out, hence loosing grip causing ABS to sense that wheels are locking and therefore the early cut in of ABS...
Share this post
go get it check ....... safer.... no point pondering....
Share this post
2nd Gear
I have a feeling it might not be ABS. I don't understand how ABS can kick in over humps.
But is ur car under warrenty? If yes just bring it to the service center to rectify the problem.
I remember there was a case where the Kia Forte was have the same problem ( front knocking sound n jerking in front wheels)
In the end it was faulty suspension system.
U might want to get a pro to check it out for u before it gets out of hand.
Share this post
2nd Gear
My guess is that you have real cheap slippery tires.
Share this post
Twincharged
Might be the tires. Got the same problem last time. After changing tires then no problems again.
Share this post
4th Gear
Some humps are painted with yellow strips, and the paint is quite slick.
When braking hard on the hump, once the front tyres touch the paint, front tyre will slip and lock up, resulting in ABS activating.
Share this post
6th Gear
To TS's issue, I share the same views as yours.
Share this post
2nd Gear
best is go to your nearest reputable workshop for advice... dun drag regarding anything that can compromise your/others people safety on the road
Share this post
3rd Gear
be extra careful of those steel plates that are lay across the road during construction work.....especially when they are near traffic light junctions...last time balls nearly dropped when i brake at a traffic junction after a shower across those plates....wheels locked up and slipped [dizzy] [dizzy]
Share this post
1st Gear
ABS sensor dirty/faulty...
hi bro, anyway to DIY check?
mine kicks in at MSCP.
Share this post
1st Gear
i sent it in to Honda Service centre today.
told him what i wrote here. and he seems to say its just the ABS doing its job. and that it could be my tyres not being grippy enough.
asked him if there is any chance of the ABS being "over sensitive", he said "unlikely, if not the ABS signal will light up"
so i guess i just have to go change my tyres.... or do you bros have any other advice?
Share this post
4th Gear
wah fierce. u do handbrake turns up and down ah?!
liddat yrs not anti-lock braking system...
its always brake system.
Share this post
Supersonic
It's unlikely that your tyre is so worn or bald that every little bump will trigger ABS.
I had tyres that do trigger more or less, but only when driven hard and brake over wet puddles.
ABS sensor could be an issue.
ABS light on the instrument cluster only when there's a malfunction in the circuit board.
Whether it's too sensitive or not, should not cause the ABS to light.
Share this post
Clutched
any explanation?
If the tyre is botak and result in wet weather very slippery ABS kick in easily then the tyre is really very botak until like those semi slick tyre which in normal condition should be more grippy due the more rubber contact with the road so go over metal hump wun activate ABS right? Unless when u go over metal hump also wet?
Share this post
Clutched
- What tyres are u using and for how long?
- When did the problem start, and did it occur gradually or suddenly?
- Does it occur for for all humps, and both in the dry and wet?
- You driving manual or auto?
Share this post
