Kenari Neutral Newbie December 12, 2011 Share December 12, 2011 Good Carbuyer, i a bit at fault also, work tuas, stay circuit road, but 630 like that then set off, so running 100km++ is common thing. just wondering if anyone else doing the same thing getting the same result..... haiz.... i also struggle very long then post de, cause FC too epic liao. to add, RPM most of the time is around 3~4k de. i dun expect too much la, just wondering if it's normal. ↡ Advertisement Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 12, 2011 Share December 12, 2011 Good Carbuyer, i a bit at fault also, work tuas, stay circuit road, but 630 like that then set off, so running 100km++ is common thing. just wondering if anyone else doing the same thing getting the same result..... haiz.... i also struggle very long then post de, cause FC too epic liao. I believe you are using PIE at that time without traffic jam, so that should be about the cruising speed. Kenari got different aerodynamics from Kelisa. Ever drove Kelisa from Ang Mo Kio to KL and back (distance over 700km) with about 100km petrol left in the 40L tank when I reached Ang Mo Kio. I like to believe there is mechanical problem(s) besides Kenari's aerodynamics. Perhaps you fetch full load of passengers/goods... under-inflated tire, wheels alignment, handbrake adjustment, slippery tire... Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 12, 2011 Share December 12, 2011 (edited) to add, RPM most of the time is around 3~4k de. i dun expect too much la, just wondering if it's normal. I believe Kenari share the same gearbox as Kelisa. Most economical to maintain within their crising speed with 3600rpm (estimated 110km/H). Beyond 36000 rpm the engine starts to get noiser irregardless of what engine oil you put in. FC starts getting poor from then. If ours under warranty, I believe only John the boss at Perocom can have the expertise to look into this. The rest in this AD's workshop are learn-through-mistakes Apprentices only (not familiar with non regular servicing tasks...). I would suggest if you do not need Kenari's headroom, to trade-in for Spark (manual) or Kelisa (manual). SparK got impressive suspension, and Kelisa got impressive FC. Viva a current replacement for Kelisa. I have not test drove this model yet, looking for more powerful cars. Sirion more value-for-money than Myvi. Edited December 12, 2011 by Good-Carbuyer Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear December 13, 2011 Share December 13, 2011 I believe Kenari share the same gearbox as Kelisa. Most economical to maintain within their crising speed with 3600rpm (estimated 110km/H). Beyond 36000 rpm the engine starts to get noiser irregardless of what engine oil you put in. FC starts getting poor from then. If ours under warranty, I believe only John the boss at Perocom can have the expertise to look into this. The rest in this AD's workshop are learn-through-mistakes Apprentices only (not familiar with non regular servicing tasks...). I would suggest if you do not need Kenari's headroom, to trade-in for Spark (manual) or Kelisa (manual). SparK got impressive suspension, and Kelisa got impressive FC. Viva a current replacement for Kelisa. I have not test drove this model yet, looking for more powerful cars. Sirion more value-for-money than Myvi. Yes! Sirion more value for money than Myvi Link to post Share on other sites More sharing options...
Raytham Neutral Newbie December 13, 2011 Share December 13, 2011 Yes! Sirion more value for money than Myvi Sirion is not too bad la but have its own issues also. I just changed the steering assembly due to knocking issues. Now got vibration issues at low rpm, but STS workshop told me because turn on headlight or when RPM drop so will encounter this issue. Feels weird. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 13, 2011 Share December 13, 2011 Sirion is not too bad la but have its own issues also. I just changed the steering assembly due to knocking issues. Now got vibration issues at low rpm, but STS workshop told me because turn on headlight or when RPM drop so will encounter this issue. Feels weird. How could the headlights cause vibration? That must be a Mess-chanic, not Mechanic. Go to another workshop. Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear December 13, 2011 Share December 13, 2011 Sirion is not too bad la but have its own issues also. I just changed the steering assembly due to knocking issues. Now got vibration issues at low rpm, but STS workshop told me because turn on headlight or when RPM drop so will encounter this issue. Feels weird. The car is good....just that STS is another AD of a kind Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 13, 2011 Share December 13, 2011 The car is good....just that STS is another AD of a kind Seems MASSA MOTOR not only AD who employed peculiar staff. Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear December 14, 2011 Share December 14, 2011 Sirion is not too bad la but have its own issues also. I just changed the steering assembly due to knocking issues. Now got vibration issues at low rpm, but STS workshop told me because turn on headlight or when RPM drop so will encounter this issue. Feels weird. Some batch have steering issues which I have read from somewhere. Quite a frustrating issue which many owners very unhappy about. Link to post Share on other sites More sharing options...
Raytham Neutral Newbie December 14, 2011 Share December 14, 2011 How could the headlights cause vibration? That must be a Mess-chanic, not Mechanic. Go to another workshop. He did not mentioned is the headlights is the culprit. Just that when he offs the headlight the RPM goes down, vibrations will come though not very irritating. He did tried with me when we off the headlights RPM will drop to 700rpm. Link to post Share on other sites More sharing options...
Ahbao999 1st Gear December 14, 2011 Share December 14, 2011 Hi Guys, I changing my timing belt and water pump soon ... wanna check if the OE number for VIVA 1.0 , is 16100-29115/29116 (T-128) NPW Anyone changed before ??? pls advise , thanks Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 14, 2011 Share December 14, 2011 He did not mentioned is the headlights is the culprit. Just that when he offs the headlight the RPM goes down, vibrations will come though not very irritating. He did tried with me when we off the headlights RPM will drop to 700rpm. Earthing circuitry conductance deficiency? Some electrical problems are solved by an additional earthing cable to the battery terminal Link to post Share on other sites More sharing options...
Meganut 2nd Gear December 14, 2011 Share December 14, 2011 i just changed last month... I did at Ros Merah last month about RM800. I change the following: Engine oil Brake oil Power steering oil Coolant Timing belt Power steering belt Aircon belt Brake pads and a few more stuff.... super major servicing Link to post Share on other sites More sharing options...
Weiiix Neutral Newbie December 14, 2011 Share December 14, 2011 i just changed last month... I did at Ros Merah last month about RM800. I change the following: Engine oil Brake oil Power steering oil Coolant Timing belt Power steering belt Aircon belt Brake pads and a few more stuff.... super major servicing Whats your mileage now? How much is the labour? Link to post Share on other sites More sharing options...
Meganut 2nd Gear December 14, 2011 Share December 14, 2011 Mileage 82k... All in is RM800. I change alot of stuff took 3.5 hours, went in the morning reach around 11.30 finish at about 3.30, left at 4... The labour for all the timing belt around RM350 (i cannot remember the amount but its RM300+) but they change 3 belts for me and never charge me extra, the labour for the oil change, brake pads etc is about RM70 if i remember correctly... BTW most Perodua service centre, you cant bring your own oil and timing belt etc to get it change, they dun entertain Link to post Share on other sites More sharing options...
Meganut 2nd Gear December 14, 2011 Share December 14, 2011 (edited) Hi brother, you cannot expect your mileage to show you 500km like every car you first need to see how big is your fuel tank. My fuel tank is 36 litres, when the lights turn on and start blinking... i can fill my tank to max 28 litres and it overflows... and wait for 30 secs and press abit more still over flows, so that is the max i can go.... for me i get about 350km-370km of mileage each time and each time i fill up is about 23-25 litres IF your mileage is 310km, you need to check how much are you pumping at every full tank. Do you pump full tank or half tank? Do you pump when its empty or when there is 1/4 left. All these will determine your mileage. If you pump 3/4 tank petrol everytime you reach 1/4 and you clock 310km its quite reasonable. Best is to monitor your driving and pumping. Pump your tank to the fullest.... take note of your mileage when its almost empty and your refill, see how many litres you pump and divide by the number of KM you travel, take note over 6 cycles and see lor. If you pump 22 litres of petrol each time (cos if they tell you your tank is 30 litres, there is about 5-6 litres which is the reserve tank so unless you touch it if not its quite hard to pump 30 litres of petrol unless your car totally empty) so if you pump 22 litres and your travel 310km, that will work out to be about 14km/litre which is quite good. Also take note to make sure your tyres are in proper order. If your alignment is out or your wheels are not properly balanced, the car will consume more petrol, if your tyres are deflated that also affect. I suggest that you pump your tyres once a week or once in two weeks. Hope this helps. Hi, Any one driving Kenari??? how many KM you all can get out of one full tank?? mine is like damn low, 300~315 km max... haiz.... Edited December 14, 2011 by Meganut Link to post Share on other sites More sharing options...
Kenari Neutral Newbie December 15, 2011 Share December 15, 2011 Hi brother, you cannot expect your mileage to show you 500km like every car you first need to see how big is your fuel tank. My fuel tank is 36 litres, when the lights turn on and start blinking... i can fill my tank to max 28 litres and it overflows... and wait for 30 secs and press abit more still over flows, so that is the max i can go.... for me i get about 350km-370km of mileage each time and each time i fill up is about 23-25 litres IF your mileage is 310km, you need to check how much are you pumping at every full tank. Do you pump full tank or half tank? Do you pump when its empty or when there is 1/4 left. All these will determine your mileage. If you pump 3/4 tank petrol everytime you reach 1/4 and you clock 310km its quite reasonable. Best is to monitor your driving and pumping. Pump your tank to the fullest.... take note of your mileage when its almost empty and your refill, see how many litres you pump and divide by the number of KM you travel, take note over 6 cycles and see lor. If you pump 22 litres of petrol each time (cos if they tell you your tank is 30 litres, there is about 5-6 litres which is the reserve tank so unless you touch it if not its quite hard to pump 30 litres of petrol unless your car totally empty) so if you pump 22 litres and your travel 310km, that will work out to be about 14km/litre which is quite good. Also take note to make sure your tyres are in proper order. If your alignment is out or your wheels are not properly balanced, the car will consume more petrol, if your tyres are deflated that also affect. I suggest that you pump your tyres once a week or once in two weeks. Hope this helps. Thanks! it's really more or less it say.... +/- 310km to 22 ~ 25 l, (cause sometime i do stupid stuff like wake up late, or try to overtake BMW, haha). just glad to see that my Kenari is flying normally, even that i push it to 110~120 km most of the time. Link to post Share on other sites More sharing options...
Kenari Neutral Newbie December 15, 2011 Share December 15, 2011 I believe you are using PIE at that time without traffic jam, so that should be about the cruising speed. Kenari got different aerodynamics from Kelisa. Ever drove Kelisa from Ang Mo Kio to KL and back (distance over 700km) with about 100km petrol left in the 40L tank when I reached Ang Mo Kio. I like to believe there is mechanical problem(s) besides Kenari's aerodynamics. Perhaps you fetch full load of passengers/goods... under-inflated tire, wheels alignment, handbrake adjustment, slippery tire... Buyer, your guess is more or less there, i go by PIE,KPE, then westcoast highway, (there can run easier than other highway), then jurong port road, finally AYE to tuas ave 8. i have issue on it's aerodynamics and shape also. but my mom sign the car without telling me. (haiz... that one is long story) anyway i like the sitting position and all. so if the FC is ok, then i dun mind keeping this car (partly due to COE also). Just worried that my FC is abnormal. Thanks you guys for the help! ↡ Advertisement Link to post Share on other sites More sharing options...
Perodua AXIA at RM24,900?
Crazy weather in Singapore ?
National Service in Singapore
