5936 1st Gear July 4, 2010 Share July 4, 2010 Cant find replacement S/S air filter? Model 17801-28040 Toyota Estima Hybrid Shape of element : Long Rectangle ↡ Advertisement Link to post Share on other sites More sharing options...
Japan96 Clutched July 4, 2010 Share July 4, 2010 got for Hurricane Stainless steel air filter at west coast Mok yang Audio Link to post Share on other sites More sharing options...
5936 1st Gear July 4, 2010 Author Share July 4, 2010 Thanks for the address. Hurricane is my first choice. Tried several places, but they dont carry for this model. But I'll still visit Mok Yang Audio. Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear July 4, 2010 Share July 4, 2010 Cant find replacement S/S air filter? Model 17801-28040 Toyota Estima Hybrid Shape of element : Long Rectangle my advice is not to use such stainless steel filter. the performance gain is not worth the amt of dirt/dust that is going into the engine Link to post Share on other sites More sharing options...
5936 1st Gear July 4, 2010 Author Share July 4, 2010 So what would you recommend. Stock fiber filter is $40 a piece.. Link to post Share on other sites More sharing options...
Limiter Neutral Newbie July 4, 2010 Share July 4, 2010 Hurricane filter is suicide for your engine over long run. It is almost as good as no filtration to particles. I would say k&n is the most ideal that u can consider. Link to post Share on other sites More sharing options...
5936 1st Gear July 4, 2010 Author Share July 4, 2010 I wont mine SS or cotton, as long as I can reuse them. But so far, can find K&N replacement for my model... That is the problem.... Any cure? Link to post Share on other sites More sharing options...
Whisper_2000 Clutched July 4, 2010 Share July 4, 2010 Hurricane filter is suicide for your engine over long run. It is almost as good as no filtration to particles. I would say k&n is the most ideal that u can consider. Hey, wat's the diff between hurricane vs k&n steel filters? Aren't they the same? Link to post Share on other sites More sharing options...
Ultramega 1st Gear July 4, 2010 Share July 4, 2010 Hey, wat's the diff between hurricane vs k&n steel filters? Aren't they the same? Different. Hurricane is stainless steel. K&N is cotton. Link to post Share on other sites More sharing options...
Cerano 1st Gear July 4, 2010 Share July 4, 2010 Hurricane filter is suicide for your engine over long run. It is almost as good as no filtration to particles. I would say k&n is the most ideal that u can consider. wrong... nowadays hurricanemesh size smaller alr bro Link to post Share on other sites More sharing options...
Ultramega 1st Gear July 4, 2010 Share July 4, 2010 I wont mine SS or cotton, as long as I can reuse them. But so far, can find K&N replacement for my model... That is the problem.... Any cure? There are 4 K&N SG dealers listed here: http://www.knfilters.com/search/dealersearch.aspx Since they are official dealers, if they don't have stock I believe they can order for you... unless K&N don't make filters for your car. Link to post Share on other sites More sharing options...
Carer 2nd Gear July 5, 2010 Share July 5, 2010 The problem with aftermarket drop in filters is that it allows a higher amount of dirt into the engine. unless u plan to drive for 2-3 yrs, i suggest keep the air filter paper. Link to post Share on other sites More sharing options...
5936 1st Gear July 5, 2010 Author Share July 5, 2010 Stock paper or fiber filter has the best filtration properties. Have to live with partially dirty filter until cannot clean anymore. I am quite sure, they dont have drop in for my model. Maybe have to KIV, until they make. Link to post Share on other sites More sharing options...
Swiftee Clutched July 6, 2010 Share July 6, 2010 Stock filter if u want to drive yr car till end of 10th year. Link to post Share on other sites More sharing options...
5936 1st Gear July 6, 2010 Author Share July 6, 2010 I am serious thinking about keeping it so long as possible. My previous car, 5 years. I like this car even more as power is acceptable, FC acceptable, equipment status- up to date( at the moment). But if I see dropin filter, I will also get one.... Thks for the advice Link to post Share on other sites More sharing options...
Ky13 Clutched July 6, 2010 Share July 6, 2010 The problem with aftermarket drop in filters is that it allows a higher amount of dirt into the engine. unless u plan to drive for 2-3 yrs, i suggest keep the air filter paper. I used K & N replacement filter in my previous Celica-ST204 (in aus) since the 2nd week I owned the car. I drove this car for almost 8 years then sold it to a friend of mine. Well, it's been almost 20 years and last time I checked with my friend (few months ago), the engine is still running alright. Link to post Share on other sites More sharing options...
Grix17 Clutched September 18, 2010 Share September 18, 2010 I am serious thinking about keeping it so long as possible. My previous car, 5 years. I like this car even more as power is acceptable, FC acceptable, equipment status- up to date( at the moment). But if I see dropin filter, I will also get one.... Thks for the advice Bro, if you want to mod, go for the Tom's Linear Throttle System and Fuel Mapping combination. Specific to Estima Hybrid model. Should feel more powerful without too much effect on FC. Try TRD Sportivo at Sin Ming. I have been looking for aftermarket air filter too, but in vain. Anyway, I find it really difficult to remove the air filter from the engine compartment. Such a tight fit. Link to post Share on other sites More sharing options...
Thedream 3rd Gear September 19, 2010 Share September 19, 2010 Air with dirt goes into the combustion chamber and is ignited with petrol. Any soot, together with the dirt, is carried away by the engine oil. So using aftermarket filters shouldn't be a problem if you change your engine oil regularly. ↡ Advertisement Link to post Share on other sites More sharing options...
Looking for storage space ...
Air Purifier Discussion - tips and info
NEW Condom in market and looking for TESTERS !!!
Redmart charges a "Slot Fee" from 15 June
DIY engine oil change
Steel cabinet
Steel cabinet
Recommendation for water filter
