Keithchue 5th Gear October 10, 2010 Share October 10, 2010 guys, my laptop recently lags alot, the problems is as described. opening applications is taking close to 2 mins, once opened, running is fine. booting up is also not a problem. my laptop is 8 yrs old, running on XP, and about 1 week ago it is fine, i did not install any extra apps. and i also cannot system restore to a earlier time. ↡ Advertisement Link to post Share on other sites More sharing options...
Bystander50 5th Gear October 10, 2010 Share October 10, 2010 Go task manager, check your processor and memory usage. High usage, then probably virus/trojan infection. Average cpu utilisation at idle should be less than 5%. A small spike when you launch any apps b4 dipping. For a 8 year old laptop, if you've not changed the harddisk, then the harddisk could be failing. Is the harddisk led being lighted up for a long time (instead of the usual blinking) when u encountered the slowness? If so, better backup your data asap. It could be failing. Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 10, 2010 Share October 10, 2010 for Win XP, it is possible to slash no. of processes to about 26~30. i noted that most computers run anything from about 50 to nearly 70, my friends' and company workstations that is. Link to post Share on other sites More sharing options...
Vid Hypersonic October 10, 2010 Share October 10, 2010 8 yr old laptop? time to change loh. in any case, think of anything you have installed recently. Virus, malware, spyware will make it slow. Suspicious websites visited or emails? Anti virus installed? Link to post Share on other sites More sharing options...
Boyboy 1st Gear October 10, 2010 Share October 10, 2010 time to format. 8 years is a really good run for a windows laptop. even 8 months, i'd notice a significant slowdown. When i was still using windows, 6-8 months is a good time to format to clean out everything. the longest is 1 year. but truth be told, system slowdown is noticeable from the 4th month or so.. and that's with me using antivirus and not getting infected. like what another person suggested, get a new laptop. u wanna upgrade also hard cos parts from that era are different. Tried to upgrade my wife's HP laptop but the cost of the RAM was much more due to the different era of RAM, so i shelved the idea. your HDD likely to be IDE, while nowadays it's SATA HDD. different connectors. Link to post Share on other sites More sharing options...
Kopites Supersonic October 10, 2010 Share October 10, 2010 Try this free up your disk space. If that don't work than time for you to re-format and upgrade ram. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 10, 2010 Share October 10, 2010 Just do a Defragment on your hard drive. From time to time it's recommended to do so. It beats formatting the hard drive which is more dedious. 8 years is a long time. Already made your money's worth. Link to post Share on other sites More sharing options...
Karebu 1st Gear October 10, 2010 Share October 10, 2010 scan for spywares, clean them and perhaps upgrade ram, if u can. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 11, 2010 Share October 11, 2010 guys, my laptop recently lags alot, the problems is as described. opening applications is taking close to 2 mins, once opened, running is fine. booting up is also not a problem. my laptop is 8 yrs old, running on XP, and about 1 week ago it is fine, i did not install any extra apps. and i also cannot system restore to a earlier time. Can check for improvement after de-fragmenting it? Link to post Share on other sites More sharing options...
Little_prince Supersonic October 11, 2010 Share October 11, 2010 8 yrs old is a long time for a laptop... it could be a million and 1 things... perhaps you could consider changing a new one... it's so cheap nowadays Link to post Share on other sites More sharing options...
Keithchue 5th Gear October 11, 2010 Author Share October 11, 2010 guys, thank you for the information, i have upgraded my ram from ancient 512 to 1.5 (added another 1gb) about 3 yrs ago. i think it may due to trojan/malware, but my anti virus comes out nothing. i have also de-frag...a couple of times and nothing seem to improve. i have a active paid antivirus running and the it tells me that 100% of my system resources is running most of the time. Link to post Share on other sites More sharing options...
Dafansu Turbocharged October 11, 2010 Share October 11, 2010 Normally for old pc I will format every year or half a year, not sure if it's the correct way Link to post Share on other sites More sharing options...
Kxbc Turbocharged October 11, 2010 Share October 11, 2010 sometimes anti virus does not help. run both spy-bot and ad aware. it solved a rather similar problem for me last time. Link to post Share on other sites More sharing options...
Rainman 1st Gear October 11, 2010 Share October 11, 2010 guys, my laptop recently lags alot, the problems is as described. opening applications is taking close to 2 mins, once opened, running is fine. booting up is also not a problem. my laptop is 8 yrs old, running on XP, and about 1 week ago it is fine, i did not install any extra apps. and i also cannot system restore to a earlier time. Try run combofix. Link to post Share on other sites More sharing options...
VellfireS 4th Gear February 9, 2011 Share February 9, 2011 guys, thank you for the information, i have upgraded my ram from ancient 512 to 1.5 (added another 1gb) about 3 yrs ago. i think it may due to trojan/malware, but my anti virus comes out nothing. i have also de-frag...a couple of times and nothing seem to improve. i have a active paid antivirus running and the it tells me that 100% of my system resources is running most of the time. Try to reformat your system.. Link to post Share on other sites More sharing options...
Bugts Neutral Newbie February 9, 2011 Share February 9, 2011 guys, my laptop recently lags alot, the problems is as described. opening applications is taking close to 2 mins, once opened, running is fine. booting up is also not a problem. my laptop is 8 yrs old, running on XP, and about 1 week ago it is fine, i did not install any extra apps. and i also cannot system restore to a earlier time. fyi, anti-virus may slow down your PC too. real time scanning.. 1.5gb not good enough for XP. i find 3gb also slow.. Hdd run out space may slow down too. Link to post Share on other sites More sharing options...
Viceroymenthol 6th Gear February 9, 2011 Share February 9, 2011 guys, my laptop recently lags alot, the problems is as described. opening applications is taking close to 2 mins, once opened, running is fine. booting up is also not a problem. my laptop is 8 yrs old, running on XP, and about 1 week ago it is fine, i did not install any extra apps. and i also cannot system restore to a earlier time. have you been watching too much naughty stuff ↡ Advertisement Link to post Share on other sites More sharing options...
Chechnya bans dance music that is too fast or slow
Help with STA report remarks
Any laptop repairers?
HELP! Upstairs neighbour causing sleepness nights
Exporting Gmail Contacts (Pls help)
