inlinesix Supersonic February 6, 2012 Share February 6, 2012 I change my BMW 520 rotor to Brembo Max before + Stock Brake Pad. The stopping distance is much shorter than full stock setup. In addition, it is lighter than stock rotor. In conclusion, it only works on heavier car. [laugh] ↡ Advertisement Link to post Share on other sites More sharing options...
Aeromania 1st Gear February 6, 2012 Share February 6, 2012 TS, if you only using ur car for daily normal driving i suggest get rotors like VTTR, exzess which are cross drilled or slotted can already. Do note that cross drilled and slotted rotors eat brake pads faster and creates a lot of brake dusts, 2-3 days your whole rim fully covered with brake dusts. Anyway, no point spending so much getting expensive brembo rotors just because it is "brembo" and only or mostly using it for normal drive. If really want more braking power, get a decent set of BBK or at least change to slotted/cross drilled rotors, ssbh and performance brake pads. Link to post Share on other sites More sharing options...
Hondasteam 1st Gear December 31, 2013 Share December 31, 2013 I am hunting high & low for slotted rotor for Stream RN6. For TRW, can read from this forum (http://www.jscarforum.com/viewtopic.php?f=36&t=133#p227). I think it carries brembo as well. Link to post Share on other sites More sharing options...
ChickenMob 6th Gear December 31, 2013 Share December 31, 2013 I am hunting high & low for slotted rotor for Stream RN6. For TRW, can read from this forum (http://www.jscarforum.com/viewtopic.php?f=36&t=133#p227). I think it carries brembo as well. if you getting brembo rotors for your stock calipers, you can get them from the stockiest at waterloo street. Tanly or Thian seng. call before going down. my previous edix brembo rotors was bought from there. Link to post Share on other sites More sharing options...
Marcovanbasten 1st Gear December 31, 2013 Share December 31, 2013 Both TRW & Brembo rotor disc & pads' quality all dropped a lot already. Because due to cost cutting, many of them are made in China already. Meaning sub-out to some China factories to do production & purchase of raw material etc. That's why prices are cheaper nowadays. Link to post Share on other sites More sharing options...
Hondasteam 1st Gear January 6, 2014 Share January 6, 2014 if you getting brembo rotors for your stock calipers, you can get them from the stockiest at waterloo street. Tanly or Thian seng. call before going down. my previous edix brembo rotors was bought from there. For Honda owners, refer to this forum thread http://www.jscarforum.com/viewtopic.php?f=36&t=135 for Brembo rotors. Link to post Share on other sites More sharing options...
Knoobie Supercharged January 6, 2014 Share January 6, 2014 anyone knows where can we get runstop curve slot rotors? Link to post Share on other sites More sharing options...
Hondasteam 1st Gear May 25, 2015 Share May 25, 2015 Try the brembo map to find the local dealer http://www.bremboparts.com/en/component/content/article?id=3425 Enter Singapore. Link to post Share on other sites More sharing options...
inlinesix Supersonic May 25, 2015 Share May 25, 2015 Try the brembo map to find the local dealer http://www.bremboparts.com/en/component/content/article?id=3425 Enter Singapore. Lintrak don't sell to enduser ↡ Advertisement Link to post Share on other sites More sharing options...
Where can I get rubber sheet
Where is the best buffet spread?
Where to change $1 coins FOC
Where to buy cigars in Singapore?
