Keithchue 5th Gear February 22, 2011 Share February 22, 2011 Bros, my 6yr old vios is not starting when i turn the key intermittenly...it is cranking fine, but not starting. i was advised that the fuel pump is dead...it is fine when i depress the accerlator while starting, it just starts when i do that. any advice or other parts that i should look at thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Cttan456 2nd Gear February 22, 2011 Share February 22, 2011 A common problem with fuel pump. Don't worry, it doesn't cost much to buy and replace. Link to post Share on other sites More sharing options...
Keithchue 5th Gear February 22, 2011 Author Share February 22, 2011 how much is it, i was quoted close to 500 plus labour? costly? Link to post Share on other sites More sharing options...
Dojon 1st Gear February 22, 2011 Share February 22, 2011 I have the same problem only when after i pump finish. After that never happens... What happen arh ? Link to post Share on other sites More sharing options...
Dscheng 3rd Gear February 22, 2011 Share February 22, 2011 I have the same problem only when after i pump finish. After that never happens... What happen arh ? Do you pump petrol until overflow?? Link to post Share on other sites More sharing options...
Mllcg 3rd Gear February 22, 2011 Share February 22, 2011 Do you pump petrol until overflow?? i normally pump until the cap area can see the petrol. too much? Link to post Share on other sites More sharing options...
Dojon 1st Gear February 22, 2011 Share February 22, 2011 Do you pump petrol until overflow?? No bah... but more than after it auto stop. I also need to step on accelerator before it starts. Link to post Share on other sites More sharing options...
Airwaver 4th Gear February 22, 2011 Share February 22, 2011 Bros, my 6yr old vios is not starting when i turn the key intermittenly...it is cranking fine, but not starting. i was advised that the fuel pump is dead...it is fine when i depress the accerlator while starting, it just starts when i do that. any advice or other parts that i should look at thanks What's your mileage? Could be a choked fuel filter. Link to post Share on other sites More sharing options...
Keithchue 5th Gear February 22, 2011 Author Share February 22, 2011 130K, i have just changed my fuel filter at 120K Link to post Share on other sites More sharing options...
Dscheng 3rd Gear February 22, 2011 Share February 22, 2011 No bah... but more than after it auto stop. I also need to step on accelerator before it starts. It should be normal then. I do encounter this when i pump gas at Jb haha. Link to post Share on other sites More sharing options...
Airwaver 4th Gear February 22, 2011 Share February 22, 2011 130K, i have just changed my fuel filter at 120K Oic, then probably a faulty pump liao. Link to post Share on other sites More sharing options...
Alantyc Clutched February 22, 2011 Share February 22, 2011 Ur fuel injectors kaput? Link to post Share on other sites More sharing options...
ER-3682 Twincharged February 22, 2011 Share February 22, 2011 Oic, then probably a faulty pump liao. A faulty fuel pump,not onlt affect the starting,it also affect the driving,check your coils & spark plugs. Link to post Share on other sites More sharing options...
XenonWhite 1st Gear February 22, 2011 Share February 22, 2011 Spark plugs foul up maybe?? Link to post Share on other sites More sharing options...
Keithchue 5th Gear February 22, 2011 Author Share February 22, 2011 don;t think...normal driving is fine...only starting.... Link to post Share on other sites More sharing options...
Ghostami 2nd Gear February 22, 2011 Share February 22, 2011 You try before using those injector cleaner?? Maybe will help abit.. Link to post Share on other sites More sharing options...
Siewss 1st Gear February 22, 2011 Share February 22, 2011 don;t think...normal driving is fine...only starting.... I had engine start difficulty plus uneven idling - changed the fuel pump followed by the throttlebody and the uneven idling problem got solved, and so did the engine start problem. Over time, though I'm not plagued by uneven idling, the engine start problem resurfaced. The WS again stated there's nothing wrong. Now my warm cranking (usually after turning off engine for 2~3 hours) can take between 5~10 secs. I can only remember 2 things I did that could have led to the problem: i) Started the engine when the engine was already running ii) Ran completely dry of petrol while driving Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear February 22, 2011 Share February 22, 2011 Bros, my 6yr old vios is not starting when i turn the key intermittenly...it is cranking fine, but not starting. i was advised that the fuel pump is dead...it is fine when i depress the accerlator while starting, it just starts when i do that. any advice or other parts that i should look at thanks Start with the most basic, the fuel filter, then check connectors to the fuel pump as well as connectors to the injectors ↡ Advertisement Link to post Share on other sites More sharing options...
Cars at Expo
Cars at Expo
COE Bidding - March 2024
Singapore ‘open to’ idea of one-off rise in vehicle population
New car discount/price/promo
Top 5 questions to ask every used car dealer
