Ptc77 Neutral Newbie May 18, 2011 Share May 18, 2011 Car due for servicing 110k, driving stock latio sports, intend to use Amsoil EO, should i use 5W30 or 5W40 ? Any advice? ↡ Advertisement Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear May 18, 2011 Share May 18, 2011 Car due for servicing 110k, driving stock latio sports, intend to use Amsoil EO, should i use 5W30 or 5W40 ? Any advice? all along you using which one?? if you used 5W30 all the while.. the sudden switch to 5W40 will make you feel like your car gone weak and sluggish.. but at this mileage.. most mech will advise you to use 5W40.. i know a MCFer using Amsoil SSO 0W30 for this 160,000km.. Link to post Share on other sites More sharing options...
Itsec 2nd Gear May 18, 2011 Share May 18, 2011 my buddy's city is on 5w30..and his mileage is more than 200k liao... timely maintenance is the key.... Link to post Share on other sites More sharing options...
Mona-vie 1st Gear May 18, 2011 Share May 18, 2011 You can continue to use 5w30 oil. You do not have to switch unless you are having excessive oil consumption (eg. 1L for every 3,000 KM). The reason why older cars need thicker oil is due to wear at the piston rings which causes blow-by. thicker oil can reduce that. If you are not having this issue, then there isn't a need to switch to thicker oil. You FC will drop. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged May 18, 2011 Share May 18, 2011 Car due for servicing 110k, driving stock latio sports, intend to use Amsoil EO, should i use 5W30 or 5W40 ? Any advice? My mileage 200k, using 5w-30 Link to post Share on other sites More sharing options...
Mugen85 1st Gear May 18, 2011 Share May 18, 2011 If there's no loss of engine oil, can continue using 5w-30 Link to post Share on other sites More sharing options...
Picanto 3rd Gear May 18, 2011 Share May 18, 2011 loss of engine oil can be due to engine gaskets too. Link to post Share on other sites More sharing options...
Ithunk 1st Gear May 18, 2011 Share May 18, 2011 (edited) im using 5W40 shell helix point to note...larger engines use more oil.... so if you rev or race some oil will be burned drive safe Edited May 18, 2011 by Ithunk Link to post Share on other sites More sharing options...
Club21z 4th Gear May 18, 2011 Share May 18, 2011 5w30 for my 144k km pica. no problem one lah, 5w40 so thick waste petrol Link to post Share on other sites More sharing options...
Ithunk 1st Gear May 18, 2011 Share May 18, 2011 lol i have some engine oil lying around so just finish using up the oil first Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear May 18, 2011 Share May 18, 2011 Car due for servicing 110k, driving stock latio sports, intend to use Amsoil EO, should i use 5W30 or 5W40 ? Any advice? will you be travelling on NSHW? if yes, suggest you to opt for 5W40. Mugen85 bro is right. If there's no loss of engine oil, you can continue go with 5W30. it's all about balance. NA car with high mileage, it is recommended to go for 5W40. Link to post Share on other sites More sharing options...
Ithunk 1st Gear May 18, 2011 Share May 18, 2011 (edited) anyway if u have a user manual you can read the recommendations....diff car will have diff engine oil requirements..... lol maybe next servicing i may change to 5W30 but recommended for mine in the user manual is 5W40 anyway relative to the driver.... Edited May 18, 2011 by Ithunk Link to post Share on other sites More sharing options...
Blackyv Turbocharged May 18, 2011 Share May 18, 2011 my 4.5yrs old 4at latio just gone for 90K service (odo reads 97K) last week and use 0w30 still but this will be the last round with w30 ..... im preparing 0w40 for next round onward, just thinking of protecting it after 100k, it's always good to give the engine with some form of protection since i rev to 4-5Krpm daily and even 5.5K at certain stretch or while over taking, i guess it's about time to "protect" it slightly at such age and milleage.... no harm and i dont think slight lower fc is going to kill me but a koyak engine before i scrap it will ..... Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie May 19, 2011 Share May 19, 2011 the thinner oil provided better protection at start where most of the wear and tear occurs.. the wear rate between 5w20, 5w30, 5w40 were almost similar for my 200k km old jap mazda Link to post Share on other sites More sharing options...
Moredhel 2nd Gear May 19, 2011 Share May 19, 2011 the thinner oil provided better protection at start where most of the wear and tear occurs.. the wear rate between 5w20, 5w30, 5w40 were almost similar for my 200k km old jap mazda Mine is 380k and i'm still using 10w30. Link to post Share on other sites More sharing options...
Itsec 2nd Gear May 19, 2011 Share May 19, 2011 Mine is 380k and i'm still using 10w30. salute.. 380k sia... Link to post Share on other sites More sharing options...
Car-b_Investment_Co Neutral Newbie May 19, 2011 Share May 19, 2011 I think 5W40 should be better! Link to post Share on other sites More sharing options...
Mona-vie 1st Gear May 19, 2011 Share May 19, 2011 the thinner oil provided better protection at start where most of the wear and tear occurs.. the wear rate between 5w20, 5w30, 5w40 were almost similar for my 200k km old jap mazda How do you measure the wear rate? You did used oil analysis? ↡ Advertisement Link to post Share on other sites More sharing options...
My huat ah mileage....
Motul 8100 X-cess 5W40
Recommend lawyer to take dealer to court for mileage / odometer tampering?
Old WW2 Relic disposals
Used car dealers tampering odometer readings
SCHNELL Engine Oil 5W40
Would you buy a high mileage E200K (W211) ?
EV battery life: real vs advertised
