Ender Hypersonic November 17, 2021 Share November 17, 2021 They say it's softener. Have been using softener all the time, never kenna. Mine also front loader. ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 17, 2021 Author Share November 17, 2021 (edited) It’s the softener and liquid detergent basically. I used this one, very effective. Mine’s always a top loader. https://shopee.sg/product/173464235/2809673293?smtt=0.34349542-1637163655.9 Edited November 17, 2021 by Fcw75 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic November 17, 2021 Share November 17, 2021 1 hour ago, Fcw75 said: It’s the softener and liquid detergent basically. I used this one, very effective. Mine’s always a top loader. https://shopee.sg/product/173464235/2809673293?smtt=0.34349542-1637163655.9 Thanks, I tried to find out what's inside. I thought it's some borax or sodium carbonate. Instead I find Affresh, wm cleaner Sodium percarbonate -> Kao color bleach powder Sodium carbonate -> washing soda Vinegar -> acetic acid Ok, maybe I can cobble up some of these powders + vinegar, and avoid the bleach. I notice my Samsung top load has this problem with the black particle. Electrolux front load doesn't seem to have this problem, but it's probably hidden. Cold water wash and top load water sitting on top of a drum, may be the difference causing this problem than with front load and warm/hot water wash. 2 Link to post Share on other sites More sharing options...
Playtime Twincharged November 17, 2021 Share November 17, 2021 6 hours ago, Fcw75 said: It’s the softener and liquid detergent basically. I used this one, very effective. Mine’s always a top loader. https://shopee.sg/product/173464235/2809673293?smtt=0.34349542-1637163655.9 Had the problem lay time. Switched to powder... no more problem. 1 Link to post Share on other sites More sharing options...
Playtime Twincharged November 17, 2021 Share November 17, 2021 8 hours ago, Kxbc said: Stained some clothes permanently when I did not remove all and iron them. The black stains literally melted and got stuck to the clothes. Can't remove at all. Yeah... hated that. Like pee sai. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 17, 2021 Author Share November 17, 2021 1 hour ago, Playtime said: Had the problem lay time. Switched to powder... no more problem. Damn those soap scum. 😒 I have been using powder detergent all along but this year switched to those KA laundry capsule. Too convenient. Waiting to see when the soap scum will be back. Link to post Share on other sites More sharing options...
Tohto Hypersonic November 18, 2021 Share November 18, 2021 I am using Samsung front load washing machine. Every 40 wash it will give warning for drum cleaning, thrre is a auto drum cleaning function. I always used the drum cleaning detergent to clean it, add some soda powder. 1 Link to post Share on other sites More sharing options...
Playtime Twincharged November 18, 2021 Share November 18, 2021 For people who die die must use iquid softener, can try not pouring direct to the inlet... dilute it fully first with water. I think the pee sai forms when undissolved half dried bits of liquid softerner etc somewhere in the intestines of the washer sticks on to your clothing like glue 🤔... iron it... and it's done, can buy new cloths Link to post Share on other sites More sharing options...
Kopites Supersonic November 18, 2021 Share November 18, 2021 I am using capsules detergent for the washer. Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 18, 2021 Share November 18, 2021 Front load washer. Persil/Spin. I use the 90 degree drum cleaning cycle sometimes, maybe every few months. Supposed to do monthly but forget. Link to post Share on other sites More sharing options...
Daniu82 Supercharged November 18, 2021 Share November 18, 2021 Just buy those powder form washing machine cleaner and use it every 2 months. Confirm ok. Mine is top loader, using it to wash clothes 4 times per week. Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 18, 2021 Share November 18, 2021 basically powder detergent maybe better for removing more types of "dirt". Scum doesn't really exist in front load cos as long as u clean the rubber seal for the door, your drum is always clean. Was damn pissed that day. Was hand rinsing a mattress protector with waterproof lining inside that hasnt been washed for several years cos it was protecting a mattress which is stacked underneath another mattress. Then i noticed the plastic lining was bit worn out. But heck since i hand rinsed the bedsheet already, might as well do both. And since I've been junking lots of things recently, decided not to be so wasteful. maybe keep it for a while more before junking. Put into washer at 40 degrees, the plastic lining disintegrated coating the entire drum in white flakes (like tissue paper) but on a worse scale. At the same time, the water overflow from the drain coated my service yard floor with the same thing. Bloody hell had to spend time cleaning both. One mistake led to essentially a lot of clean up. 1 1 Link to post Share on other sites More sharing options...
Kxbc Turbocharged November 18, 2021 Share November 18, 2021 In conclusion: 1. Top loader - seems to be happening to almost every user, whether using or not using washing powder, washing liquid, liquid softener, bleach. Proposed solutions might work. 2. Front loader - No such issue noted from users. 1 Link to post Share on other sites More sharing options...
Playtime Twincharged November 18, 2021 Share November 18, 2021 11 minutes ago, Lala81 said: basically powder detergent maybe better for removing more types of "dirt". Scum doesn't really exist in front load cos as long as u clean the rubber seal for the door, your drum is always clean. Was damn pissed that day. Was hand rinsing a mattress protector with waterproof lining inside that hasnt been washed for several years cos it was protecting a mattress which is stacked underneath another mattress. Then i noticed the plastic lining was bit worn out. But heck since i hand rinsed the bedsheet already, might as well do both. And since I've been junking lots of things recently, decided not to be so wasteful. maybe keep it for a while more before junking. Put into washer at 40 degrees, the plastic lining disintegrated coating the entire drum in white flakes (like tissue paper) but on a worse scale. At the same time, the water overflow from the drain coated my service yard floor with the same thing. Bloody hell had to spend time cleaning both. One mistake led to essentially a lot of clean up. And you got a full cardio workout too.. what's not to like 🤣🤣🤣 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 18, 2021 Author Share November 18, 2021 (edited) 37 minutes ago, Kxbc said: In conclusion: 1. Top loader - seems to be happening to almost every user, whether using or not using washing powder, washing liquid, liquid softener, bleach. Proposed solutions might work. 2. Front loader - No such issue noted from users. No leh, if you just use washing powder only for top loader then no such problem. Edited November 18, 2021 by Fcw75 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 18, 2021 Author Share November 18, 2021 8 hours ago, Kb27 said: Thanks, I tried to find out what's inside. I thought it's some borax or sodium carbonate. Instead I find Affresh, wm cleaner Sodium percarbonate -> Kao color bleach powder Sodium carbonate -> washing soda Vinegar -> acetic acid Ok, maybe I can cobble up some of these powders + vinegar, and avoid the bleach. I notice my Samsung top load has this problem with the black particle. Electrolux front load doesn't seem to have this problem, but it's probably hidden. Cold water wash and top load water sitting on top of a drum, may be the difference causing this problem than with front load and warm/hot water wash. Bro, you are a DIY guy. Take out the whole drum and clean the outside yourself man! 😁 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 18, 2021 Author Share November 18, 2021 40 minutes ago, Lala81 said: basically powder detergent maybe better for removing more types of "dirt". Scum doesn't really exist in front load cos as long as u clean the rubber seal for the door, your drum is always clean. Was damn pissed that day. Was hand rinsing a mattress protector with waterproof lining inside that hasnt been washed for several years cos it was protecting a mattress which is stacked underneath another mattress. Then i noticed the plastic lining was bit worn out. But heck since i hand rinsed the bedsheet already, might as well do both. And since I've been junking lots of things recently, decided not to be so wasteful. maybe keep it for a while more before junking. Put into washer at 40 degrees, the plastic lining disintegrated coating the entire drum in white flakes (like tissue paper) but on a worse scale. At the same time, the water overflow from the drain coated my service yard floor with the same thing. Bloody hell had to spend time cleaning both. One mistake led to essentially a lot of clean up. New washing machine? 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 18, 2021 Share November 18, 2021 17 minutes ago, Fcw75 said: New washing machine? no lah. use hot water cycle disintegrate the plastic flakes to smaller. Then hand clean the drum with pail of water and a thin microfibre cloth that can see the flakes. Also clean up my service yard. then run another 2 rinse cycles. Dulan man. Chucked the mattress protector down the rubbish chute! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Washing machine front loading
GSS 2021 join forces with Lazada
From India to S.Africa in an off-peak Hyundai Matrix
Blast from the past!!! WWF stars!!
Singapore Idol Hady Mirza BANNED from condo facilities
Washing machine repair
Michelle Yeoh deported from Burma
