Tohto Hypersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 10:36 AM, Mkl22 said: then you have to sort and do multiple loads. for me bo eng to sort so much...😁 No lah.. general wash always set to 40deg. Bed sheet, towel will use 60deg. Them also have wool mode which is very helpful. ↡ Advertisement Link to post Share on other sites More sharing options...
Kxbc Turbocharged May 24, 2023 Share May 24, 2023 On 5/24/2023 at 8:15 AM, 13177 said: Yours is top loan or front load? One thing i don't like about LG there is one function that if the load of the wash is not balance, the rinse cycle would keep repeating until it is balance then go to spin cycle. Quite waste water if you never see it and let the washer operate. all TL are like that, even the Jap brands. Link to post Share on other sites More sharing options...
13177 Supersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 10:42 AM, Kxbc said: all TL are like that, even the Jap brands. No le, all my previous washer not like that de. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 24, 2023 Author Share May 24, 2023 On 5/24/2023 at 10:45 AM, 13177 said: No le, all my previous washer not like that de. Then how your washer adjust the unbalanced clothes? U stand there and adjust throughout the wash? 😁 2 Link to post Share on other sites More sharing options...
Kxbc Turbocharged May 24, 2023 Share May 24, 2023 On 5/24/2023 at 10:45 AM, 13177 said: No le, all my previous washer not like that de. some TL might be more sensitive than others. But generally, if you are washing 1 big piece of garment - say blanket, this will clump up into a big ball of cloth and fall towards 1 side, leading to the drum being uneven. 1 Link to post Share on other sites More sharing options...
13177 Supersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 12:03 PM, Fcw75 said: Then how your washer adjust the unbalanced clothes? U stand there and adjust throughout the wash? 😁 I remember the washer just continues to the next cycle without keep repeating the same cycle le. Or it is due to the size of the washer? Maybe a 5kg washer don't have this unbalanced clothes adjustment function? A bigger size washer like 10kg needs to have? 😅 1 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged May 24, 2023 Share May 24, 2023 On 5/24/2023 at 1:46 PM, 13177 said: I remember the washer just continues to the next cycle without keep repeating the same cycle le. Or it is due to the size of the washer? Maybe a 5kg washer don't have this unbalanced clothes adjustment function? A bigger size washer like 10kg needs to have? 😅 depends on your spin speed. Link to post Share on other sites More sharing options...
Daniu82 Supercharged May 24, 2023 Share May 24, 2023 1 question, for the FL hot water part, need to supply it with hot water (like from a heater drum) or cold water goes in then gets heated up? I have been using TL washer all this while. Link to post Share on other sites More sharing options...
inlinesix Supersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 2:38 PM, Daniu82 said: 1 question, for the FL hot water part, need to supply it with hot water (like from a heater drum) or cold water goes in then gets heated up? I have been using TL washer all this while. FL washer will heat it up 1 Link to post Share on other sites More sharing options...
13177 Supersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 2:38 PM, Daniu82 said: 1 question, for the FL hot water part, need to supply it with hot water (like from a heater drum) or cold water goes in then gets heated up? I have been using TL washer all this while. Think TL can also have hot water. Maybe depends on the model. I remember donkey years ago my parents had one TL washer that have a heated water function.😂 1 Link to post Share on other sites More sharing options...
Daniu82 Supercharged May 24, 2023 Share May 24, 2023 On 5/24/2023 at 2:53 PM, inlinesix said: FL washer will heat it up No wonder FL is much more expensive than TL washer 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 2:57 PM, Daniu82 said: No wonder FL is much more expensive than TL washer Buy Midea😂 Link to post Share on other sites More sharing options...
Daniu82 Supercharged May 24, 2023 Share May 24, 2023 On 5/24/2023 at 3:20 PM, inlinesix said: Buy Midea😂 Good meh? I only bought Samsung and LG TL washers before. Both brands still ok. Just that the Samsung dryer I bought gone case in less than 3 years, just changed into an Electrolux one. 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 3:23 PM, Daniu82 said: Good meh? I only bought Samsung and LG TL washers before. Both brands still ok. Just that the Samsung dryer I bought gone case in less than 3 years, just changed into an Electrolux one. PRC Top selling brand 9.5kg load for less than $1k. It will be my next WM 1 Link to post Share on other sites More sharing options...
Blueray Hypersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 2:38 PM, Daniu82 said: 1 question, for the FL hot water part, need to supply it with hot water (like from a heater drum) or cold water goes in then gets heated up? I have been using TL washer all this while. cold water goes in and gets heated up. mine can go up to 90 degrees. but the max I go is 40 degrees. Link to post Share on other sites More sharing options...
Tohto Hypersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 4:06 PM, Blueray said: cold water goes in and gets heated up. mine can go up to 90 degrees. but the max I go is 40 degrees. For bed sheet and towel I will use 60deg, the washing time reduce compare to 40deg Link to post Share on other sites More sharing options...
13177 Supersonic May 24, 2023 Share May 24, 2023 On 5/24/2023 at 4:06 PM, Blueray said: cold water goes in and gets heated up. mine can go up to 90 degrees. but the max I go is 40 degrees. Go up to 90 deg? Can cook maggie mee liao. 😂 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 24, 2023 Author Share May 24, 2023 On 5/24/2023 at 4:26 PM, 13177 said: Go up to 90 deg? Can cook maggie mee liao. 😂 Make some chamomile tea too. 😁 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Washing machine front loading
GSS 2021 join forces with Lazada
From India to S.Africa in an off-peak Hyundai Matrix
Blast from the past!!! WWF stars!!
Singapore Idol Hady Mirza BANNED from condo facilities
Washing machine repair
Michelle Yeoh deported from Burma
