AL5509 Neutral Newbie October 3, 2011 Share October 3, 2011 Hi guys, may I know e tyres pressure for tyre's profile of 225/45/r17. Was told the following: Front: 230 Rear: 220 Just wonder will it varies according to different car as different car weight differently. Appreciate your kind comments. ↡ Advertisement Link to post Share on other sites More sharing options...
Mercator Neutral Newbie October 3, 2011 Share October 3, 2011 Close enough. Usually tyre pressure spec given in maual range from unladen to laden, eg without passenger 220, full passenger 250. Link to post Share on other sites More sharing options...
Bluemice 2nd Gear October 3, 2011 Share October 3, 2011 240 both front n rear. reco from my tyre shop. mice Link to post Share on other sites More sharing options...
Fishman 1st Gear October 3, 2011 Share October 3, 2011 You said it... different car, different tyre pressure. For mine, its 210 front 215 back. Check the car manual. hope this helps Link to post Share on other sites More sharing options...
Jchuacl Clutched October 3, 2011 Share October 3, 2011 Check the guidelines on your driver's door. Hi guys, may I know e tyres pressure for tyre's profile of 225/45/r17. Was told the following: Front: 230 Rear: 220 Just wonder will it varies according to different car as different car weight differently. Appreciate your kind comments. Link to post Share on other sites More sharing options...
AL5509 Neutral Newbie October 3, 2011 Author Share October 3, 2011 (edited) Check the guidelines on your driver's door. The guidelines Tyre's pressure indicated: Front:220 Rear: 210 But my car comes with only 15 inches rim (stock). I had changed to 17 inches so just wonder if I need to increase/decrease on e pressure of e tyres. Edited October 3, 2011 by AL5509 Link to post Share on other sites More sharing options...
ER-3682 Turbocharged October 3, 2011 Share October 3, 2011 You can try higher tyre pressure,i put 40psi for my Z,i felt the car is sharper & better economy than the 35psi spec on the car manual. Link to post Share on other sites More sharing options...
Jchuacl Clutched October 3, 2011 Share October 3, 2011 What tyres are you using? The guidelines Tyre's pressure indicated: Front:220 Rear: 210 But my car comes with only 15 inches rim (stock). I had changed to 17 inches so just wonder if I need to increase/decrease on e pressure of e tyres. Link to post Share on other sites More sharing options...
Jchuacl Clutched October 3, 2011 Share October 3, 2011 Probably your sidewall is too soft? What tyres are you using anyway? You can try higher tyre pressure,i put 40psi for my Z,i felt the car is sharper & better economy than the 35psi spec on the car manual. Link to post Share on other sites More sharing options...
Tohto Hypersonic October 3, 2011 Share October 3, 2011 I also pump 10% more than the recommended pressure when cold. Link to post Share on other sites More sharing options...
GoodCar 4th Gear October 3, 2011 Share October 3, 2011 Plus 10 percent from the recommendation will save a lot of fuel. But make sure you know what you are doing, If you pump too high when unladen and later on the full laden weight cause pressure greater than max tyre pressure, A potential hazard present. ....... Link to post Share on other sites More sharing options...
Monoswift Clutched October 3, 2011 Share October 3, 2011 is 10% consider too much or is it still acceptable? my 15" manual recommend 230 but i upsize to 205/45/16 i just fill about 5% more when cold.. Link to post Share on other sites More sharing options...
Aeromania 1st Gear October 3, 2011 Share October 3, 2011 Hi guys, may I know e tyres pressure for tyre's profile of 225/45/r17. Was told the following: Front: 230 Rear: 220 Just wonder will it varies according to different car as different car weight differently. Appreciate your kind comments. usually u open the driver side door then u see got a sticker indicating how much pressure u shld pump. Link to post Share on other sites More sharing options...
Aeromania 1st Gear October 3, 2011 Share October 3, 2011 The guidelines Tyre's pressure indicated: Front:220 Rear: 210 But my car comes with only 15 inches rim (stock). I had changed to 17 inches so just wonder if I need to increase/decrease on e pressure of e tyres. wah lau ur car now not very powerful already right? Link to post Share on other sites More sharing options...
AL5509 Neutral Newbie October 3, 2011 Author Share October 3, 2011 What tyres are you using? Just changed to PS3. Link to post Share on other sites More sharing options...
AL5509 Neutral Newbie October 3, 2011 Author Share October 3, 2011 wah lau ur car now not very powerful already right? Sorry do not get what you mean. Though my stock rim is 15 inches, I changed it to 17 inches e moment it with me. So powerful or not, it quite e same for me. Am more concern on e grip of it and too believes getting e right tyre pressure will increase e life-span of e tyres. Link to post Share on other sites More sharing options...
Jchuacl Clutched October 3, 2011 Share October 3, 2011 Sidewall for this tyre is a bit soft, you can try 240/230 for a start. Just changed to PS3. Link to post Share on other sites More sharing options...
Dh15 Clutched October 3, 2011 Share October 3, 2011 I pump 270 for all 4 tires. ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Primacy 4 vs Continental Premium Contact 6 vs Goodyear F1A5
Rear tyres patchwork !
Is this tyre good? Made in SG!! Giti tyres!
Puncture-proof tyres trialled on DHL vans in SG
