Theoldjaffa Hypersonic January 11, 2019 Share January 11, 2019 Oh ET35 I was still thinking to look for front and back ET45.. what wheels are u changing? Umm I see.. no wonder I notice the yellow colour thinking the ride comes with halogen lol because previously my ride also using hid but bulb is 5k or 6k for the stock. True stock light always last longer. I just joined the WhatsApp group yesterday night. Getting the TE37 SAGA. I'm no longer in the WhatsApp group liao cos it drains my phone battery ↡ Advertisement Link to post Share on other sites More sharing options...
JX83 3rd Gear January 11, 2019 Share January 11, 2019 Getting the TE37 SAGA. I'm no longer in the WhatsApp group liao cos it drains my phone battery Link to post Share on other sites More sharing options...
PaulTwl Neutral Newbie January 14, 2019 Share January 14, 2019 Good day Bro & Sis... Thinking to get a COE IS250. Pls give me suggestion if it is worth to buy? What are the things I must lookout What are the parts will wear and tear often beside tyre and brake pad..... Is it true that the engine top tend to leaks....how much will the repair cost Any other things I need to take note... Thanks for the help... cheers 1 Link to post Share on other sites More sharing options...
MR2SBA 2nd Gear January 14, 2019 Share January 14, 2019 Good day Bro & Sis... Thinking to get a COE IS250. Pls give me suggestion if it is worth to buy? What are the things I must lookout What are the parts will wear and tear often beside tyre and brake pad..... Is it true that the engine top tend to leaks....how much will the repair cost Any other things I need to take note... Thanks for the help... cheers IS250 is a very good car. Smooth engine and robust gearbox. The later years Premium specs even more attractive. I have a 9 y.o. IS250 Premium. Odo at 120k. Only rear shock replaced. Dash and door panels replaced by BMS under warranty claim. BIL has a CoE IS250 Luxury. Odo around 160k. Replaced all shocks and front ball joints. ATF and strainer changed. Everything else ok. Prices could not remember. Will post when records found. 2 Link to post Share on other sites More sharing options...
PaulTwl Neutral Newbie January 14, 2019 Share January 14, 2019 IS250 is a very good car. Smooth engine and robust gearbox. The later years Premium specs even more attractive. I have a 9 y.o. IS250 Premium. Odo at 120k. Only rear shock replaced. Dash and door panels replaced by BMS under warranty claim. BIL has a CoE IS250 Luxury. Odo around 160k. Replaced all shocks and front ball joints. ATF and strainer changed. Everything else ok. Prices could not remember. Will post when records found. Thanks bro for the update....the one I getting mileage is about 86K. Not sure have the shop adjusted it... Hope is not a fraud case....internal panel and dashboard also replace.... 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged January 14, 2019 Share January 14, 2019 (edited) Thanks bro for the update....the one I getting mileage is about 86K. Not sure have the shop adjusted it... Hope is not a fraud case....internal panel and dashboard also replace.... IS250 is good ride, main 2 problems are melting top dash/door panels (Which you mention is already replaced) and carbon built up on intake ports due to single direct injection. For carbon built up you may want to go do the walnut blasting to clean up. There is a workshop advertising this service. Mainly Audi, BMW, merc need to do this. Edited January 14, 2019 by t0y0ta Link to post Share on other sites More sharing options...
L23 6th Gear January 14, 2019 Share January 14, 2019 Thanks bro for the update....the one I getting mileage is about 86K. Not sure have the shop adjusted it... Hope is not a fraud case....internal panel and dashboard also replace.... 10 year still less than 100k? Red plated huh? Take it as a pinch of salt ba. Link to post Share on other sites More sharing options...
159er 5th Gear January 14, 2019 Share January 14, 2019 Getting the TE37 SAGA. I'm no longer in the WhatsApp group liao cos it drains my phone battery 𤣠Please share pics of your ride when your new rims are on. 1 Link to post Share on other sites More sharing options...
PaulTwl Neutral Newbie January 15, 2019 Share January 15, 2019 IS250 is good ride, main 2 problems are melting top dash/door panels (Which you mention is already replaced) and carbon built up on intake ports due to single direct injection. For carbon built up you may want to go do the walnut blasting to clean up. There is a workshop advertising this service. Mainly Audi, BMW, merc need to do this. thanks bro for the update 10 year still less than 100k? Red plated huh? Take it as a pinch of salt ba. ya lor…..just listen and pray that it was not alter... Link to post Share on other sites More sharing options...
PaulTwl Neutral Newbie January 15, 2019 Share January 15, 2019 IS250 is good ride, main 2 problems are melting top dash/door panels (Which you mention is already replaced) and carbon built up on intake ports due to single direct injection. For carbon built up you may want to go do the walnut blasting to clean up. There is a workshop advertising this service. Mainly Audi, BMW, merc need to do this. btw....where you do the walnut blasting and what the damage? TIA Link to post Share on other sites More sharing options...
t0y0ta Supercharged January 15, 2019 Share January 15, 2019 btw....where you do the walnut blasting and what the damage? TIA https://www.mycarforum.com/topic/2709649-decarbonisation-for-better-performance-walnut-blasting/?fromsearch=1 Link to post Share on other sites More sharing options...
PaulTwl Neutral Newbie January 15, 2019 Share January 15, 2019 https://www.mycarforum.com/topic/2709649-decarbonisation-for-better-performance-walnut-blasting/?fromsearch=1 Thanks mate Link to post Share on other sites More sharing options...
L23 6th Gear January 17, 2019 Share January 17, 2019 Hello i am from Andora and i can help you with all of problems. Please write. Relgise Give me your head and your body can just leave here :yuush: @radx Link to post Share on other sites More sharing options...
Gabdat 4th Gear January 22, 2019 Share January 22, 2019 guys,not sure how true this info is but this is what i found on the internet for the 2020 IS.it is also longer and wider than the current IS. 5 Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic January 22, 2019 Share January 22, 2019 Wow looks like a JDM Camry from the back Link to post Share on other sites More sharing options...
walkofwinners 4th Gear January 22, 2019 Share January 22, 2019 thanks bro for the update ya lorâ¦..just listen and pray that it was not alter... I saw that too and the dealer claimed it's partial agent maintained. Better to check with Borneo if they have any servicing records. 86k ain't a good sign which also means wear and tear not replaced too of the mileage is legit. 2 Link to post Share on other sites More sharing options...
DACH Supersonic January 22, 2019 Share January 22, 2019 guys,not sure how true this info is but this is what i found on the internet for the 2020 IS.it is also longer and wider than the current IS. I doubt will look like this. 2 Link to post Share on other sites More sharing options...
Gabdat 4th Gear January 23, 2019 Share January 23, 2019 Wow looks like a JDM Camry from the back ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda EZ-6
2025 Mazda EZ-6
MAZDA 6
MAZDA 6
[Official] 2024 Lexus LBX
W212 owners, please check-in
Toyota Corolla Cross
New Subaru XV
New Subaru XV
