S4vtec 3rd Gear August 16, 2016 Share August 16, 2016 I believe all brands keyless systems are in some way vulnerable to such hacking. .. not just vw. That is the nature of this tech compared to physical key. I carry additional locks when I drive to JB ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Supersonic August 16, 2016 Share August 16, 2016 I carry additional locks when I drive to JB Pro: More secure as it takes time to break the lock Con: Higher chances of carjacking Link to post Share on other sites More sharing options...
S4vtec 3rd Gear August 16, 2016 Share August 16, 2016 Pro: More secure as it takes time to break the lock Con: Higher chances of carjacking lock can double up as weapon for self defense in incidents of carjacking... Link to post Share on other sites More sharing options...
inlinesix Supersonic August 16, 2016 Share August 16, 2016 lock can double up as weapon for self defense in incidents of carjacking... Ya right. Try to use lock when a pistol or parang knock on your window. Pistol cost RM 2k. Assassin cost RM 5k Link to post Share on other sites More sharing options...
S4vtec 3rd Gear August 16, 2016 Share August 16, 2016 Ya right. Try to use lock when a pistol or parang knock on your window. Pistol cost RM 2k. Assassin cost RM 5k you wont take me alive!!!!! eh , parang knock on my window I don't give a rat's ass about . Pistol different story Link to post Share on other sites More sharing options...
inlinesix Supersonic August 16, 2016 Share August 16, 2016 you wont take me alive!!!!! eh , parang knock on my window I don't give a rat's ass about . Pistol different story Got balls!!!! Rather die than surrender car or money. Link to post Share on other sites More sharing options...
S4vtec 3rd Gear August 16, 2016 Share August 16, 2016 Got balls!!!! Rather die than surrender car or money. depends on whether the window is rolled up or not first.... Link to post Share on other sites More sharing options...
inlinesix Supersonic August 16, 2016 Share August 16, 2016 depends on whether the window is rolled up or not first.... Your window got bullet proof tint huh???? Link to post Share on other sites More sharing options...
Eyke Supercharged August 16, 2016 Share August 16, 2016 Got balls!!!! Rather die than surrender car or money. Doesn't mean they won't rape/kill or rape then kill u just because u surrender. 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged August 27, 2016 Share August 27, 2016 It's Okey. Contrary to popular belief. The robbers have conceince. Vw owners are punished enough with the bad service provided by the agent and the high incident rate of the DSG failure. Link to post Share on other sites More sharing options...
Ssuperzonic Clutched October 23, 2016 Share October 23, 2016 Hi, There is a community on Facebook which has more than 7K members who have got affected because of this problem. You can know about it more there. :) I hope it helps. Audi's GB is the same as VW's DSG right? If so, I wonder if similar DSG problems plagued the Audi owners. Link to post Share on other sites More sharing options...
Ake109 6th Gear October 23, 2016 Share October 23, 2016 Audi's GB is the same as VW's DSG right? If so, I wonder if similar DSG problems plagued the Audi owners. Depends on which model. e.g. The DL501 is unique to Audi as VW has no longitudinal mount. Link to post Share on other sites More sharing options...
ER-3682 Twincharged October 23, 2016 Share October 23, 2016 Audi's GB is the same as VW's DSG right? If so, I wonder if similar DSG problems plagued the Audi owners. I think only the A1 & the A3 shared the same "Almost" same Gearbox. Depends on which model. e.g. The DL501 is unique to Audi as VW has no longitudinal mount. The Casing may be not the same,but how many % of Parts inside are shared.? Link to post Share on other sites More sharing options...
merc280v6 6th Gear October 23, 2016 Share October 23, 2016 Depends on which model. e.g. The DL501 is unique to Audi as VW has no longitudinal mount.Not for long..... soon it will be all traverse-mounted engines for all Audi models. Sama sama VW 1 Link to post Share on other sites More sharing options...
Paddie 3rd Gear October 23, 2016 Share October 23, 2016 The Casing may be not the same,but how many % of Parts inside are shared.? The DL501 is very similar to the DQ500, just that it has been adapted for a longitudinal mounting. Link to post Share on other sites More sharing options...
BlueSwifts 3rd Gear October 23, 2016 Share October 23, 2016 Audi's GB is the same as VW's DSG right? If so, I wonder if similar DSG problems plagued the Audi owners.Audi A4 and above uses the Longitudinal Gearboxes which are different from VW's dry clutch transverse DSG. The front wheel drive Audis on the new A4 1.4, and current gen A6 and A7 uses the DL382-7F wet clutch gearbox while the Quattro variants found in the A4 and A5 2.0L uses the DL382-7Q. So far I havent heard of any major gb issues from these vehicles. Link to post Share on other sites More sharing options...
Ssuperzonic Clutched October 23, 2016 Share October 23, 2016 Depends on which model. e.g. The DL501 is unique to Audi as VW has no longitudinal mount.Ok thanks. I think only the A1 & the A3 shared the same "Almost" same Gearbox. The Casing may be not the same,but how many % of Parts inside are shared.? Ouch! I'm thinking of getting either the A1 or A3 for wifey. I will need to investigate the GB of boths models. Audi A4 and above uses the Longitudinal Gearboxes which are different from VW's dry clutch transverse DSG. The front wheel drive Audis on the new A4 1.4, and current gen A6 and A7 uses the DL382-7F wet clutch gearbox while the Quattro variants found in the A4 and A5 2.0L uses the DL382-7Q. So far I havent heard of any major gb issues from these vehicles. Thanks. Incidentally I got the new A4 1.4. I should have just asked the PA folks on the GB. Link to post Share on other sites More sharing options...
Ssuperzonic Clutched October 23, 2016 Share October 23, 2016 The optimist in me think that perhaps DSG isn't really so horrendous, otherwise we should see more VWs in the workshops than on the road. And perhaps there are plenty of VW's DSG cars that are working fine and dainty. So, those VW owners with DSG GB that are working fine, pls kee chew! ↡ Advertisement Link to post Share on other sites More sharing options...
Xpeng is Coming to Town
Volkswagen Sharan..
Volkswagen Sharan..
2011 VW New beetle
2011 VW New beetle
2021 8th Generation VW Golf
2nd Generation Volkswagen Tiguan (2016)
