Seabass_sg Neutral Newbie January 19, 2012 Share January 19, 2012 Since last wk, I realised a funny sound like 'gron gron' from my car engine when the car is picking up speed. Once it has picked up speed, the sound disappeared. However, sometimes the sound will not be present at all. I also realize if I off e aircon, this problem did not appear at all. Anyone know wat could be e issue? My car almost 5 yrs always service at AD. ↡ Advertisement Link to post Share on other sites More sharing options...
RoadTricks Neutral Newbie January 19, 2012 Share January 19, 2012 Since last wk, I realised a funny sound like 'gron gron' from my car engine when the car is picking up speed. Once it has picked up speed, the sound disappeared. However, sometimes the sound will not be present at all. I also realize if I off e aircon, this problem did not appear at all. Anyone know wat could be e issue? My car almost 5 yrs always service at AD. From your description, I would say engine mounting. Link to post Share on other sites More sharing options...
VellfireS 4th Gear January 19, 2012 Share January 19, 2012 Since last wk, I realised a funny sound like 'gron gron' from my car engine when the car is picking up speed. Once it has picked up speed, the sound disappeared. However, sometimes the sound will not be present at all. I also realize if I off e aircon, this problem did not appear at all. Anyone know wat could be e issue? My car almost 5 yrs always service at AD. go check your engine mounting.. Link to post Share on other sites More sharing options...
Seabass_sg Neutral Newbie January 20, 2012 Author Share January 20, 2012 But mine just changed by e AD 2 yrs ago. So fast gone liao? Any idea how much e cost as e previous change was free Link to post Share on other sites More sharing options...
Ronnchee Clutched January 20, 2012 Share January 20, 2012 I had the same problem when I was driving M3SP, 2007 model. It came and went, cant detect the problem. It would go when I stepped harder on accelerator. Link to post Share on other sites More sharing options...
Johnc 1st Gear January 20, 2012 Share January 20, 2012 Similar experience on my 2004 Mz3, which was resolved this week. The sound comes from the aircon compressor, which has bearings which have worn out the housing, so on low-rev you'll hear the sound. i tolerated for a few weeks, until it affected my alternator as well. Workshop replaced both aircon compressor & alternator with cannabilised parts, and changed the belt as well. Now working like fine again; damage about $500, including air-con gas, labour, etc. Note: my workshop couldn't find a new aircon compressor; the honest mechanic told me that apparently the new part doesn't fit (i saw it for myself), and most workshops will force it with some washers. Link to post Share on other sites More sharing options...
Seabass_sg Neutral Newbie January 28, 2012 Author Share January 28, 2012 I also noticed if I switched off e aircon, the problem will be gone. But if I on aircon the sound will appear when moving off or low revs but once picked up speed will be OK. If Mazda repair, will be ex right? Link to post Share on other sites More sharing options...
Jchuacl Clutched January 28, 2012 Share January 28, 2012 It sounds like your fan motor is about to spoil or already spoiled. The reason why the problem went away when you pick up speed is because the temp is low enough and does not require the fan motor to run to bring down the water temp. You can bring to Mark Cool or Tomika for them to take a look for confirmation. I also noticed if I switched off e aircon, the problem will be gone. But if I on aircon the sound will appear when moving off or low revs but once picked up speed will be OK. If Mazda repair, will be ex right? Link to post Share on other sites More sharing options...
Ehren Neutral Newbie February 1, 2012 Share February 1, 2012 could it be drive shaft problem? had mine replaced when i heard some sound coming from the engine bay.... mechanic told me was due to drive shaft. Link to post Share on other sites More sharing options...
Jchuacl Clutched February 1, 2012 Share February 1, 2012 Worned drive shaft gives a different type of sound. could it be drive shaft problem? had mine replaced when i heard some sound coming from the engine bay.... mechanic told me was due to drive shaft. Link to post Share on other sites More sharing options...
Latka 1st Gear February 5, 2012 Share February 5, 2012 But mine just changed by e AD 2 yrs ago. So fast gone liao? Any idea how much e cost as e previous change was free There shud be 4 individual mounting, this cud be another one of the mounting. Link to post Share on other sites More sharing options...
Stomp Neutral Newbie May 12, 2012 Share May 12, 2012 Hi, I also have the same problem. May i know what is the cause so that i can send it for repair as well ... Thank you Link to post Share on other sites More sharing options...
Stomp Neutral Newbie May 12, 2012 Share May 12, 2012 Since last wk, I realised a funny sound like 'gron gron' from my car engine when the car is picking up speed. Once it has picked up speed, the sound disappeared. However, sometimes the sound will not be present at all. I also realize if I off e aircon, this problem did not appear at all. Anyone know wat could be e issue? My car almost 5 yrs always service at AD. I also service my car with AD for 5 yrs but not anymore. I noticed i also have the same problem as yours. May i know what is the cause ? Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 12, 2012 Share May 12, 2012 Hi, I also have the same problem. May i know what is the cause so that i can send it for repair as well ... Thank you its the belt tensioner. once air con compressor cuts in and the extra load is exerted onto the belt tensioner, its no longer has the strength to hold it and thus made that sound. Link to post Share on other sites More sharing options...
Seabass_sg Neutral Newbie May 16, 2012 Author Share May 16, 2012 For my case was e aircon compressor. I got it changed for slightly less than $800 at mova automotive at Alexandra inclusive of labour while Mazda quoted me $2,500. Link to post Share on other sites More sharing options...
Keithchue 5th Gear May 16, 2012 Share May 16, 2012 (edited) mine also have this problem. changed the compressor, but problem did not go away.. now suspect it is the gearbox. especially low revs low speed..is this the same case as yours 5 yr old honda. yesterday went to kah,told me that mazda and honda have this problem, maybe we have this problem. Edited May 16, 2012 by Keithchue Link to post Share on other sites More sharing options...
Masjojon Neutral Newbie May 16, 2012 Share May 16, 2012 It came and went, cant detect the problem. It would go when I stepped harder on accelerator. Link to post Share on other sites More sharing options...
Gohtg Neutral Newbie May 16, 2012 Share May 16, 2012 It came and went, cant detect the problem. It would go when I stepped harder on accelerator. i had e same problem with u on my 2015 mazda6.its e aircon compressor....does e sound come with u stop yr car at traffic light n going at slow speed?when u start to accelerate,e sound will go off? dun b too anxious first,e problem persisted for about 2-3months b4 e compressor spoil. ↡ Advertisement Link to post Share on other sites More sharing options...
I See, I Laugh, I Share...
MAZDA 6
MAZDA 6
2019 All new Mazda 3
The Rotary-Electric Mazda Iconic SP Concept Could Save the Sports Car
GSS 2021 join forces with Lazada
Legendary aunties and uncles?
