Wildfaye29 Turbocharged September 22, 2019 Share September 22, 2019 On 9/21/2019 at 8:02 PM, Stik said: Since it's on air filter. Let me share what I am doing with my air filter. Firstly, I had been giving my air filter additional layer of 3M n95 filter. Some months ago, because the 3M filter had collected quite some dirt, so I took it off, with the stock filter still spanking new, I didn't replace it with another layer of 3M. In the picture, it shows the condition of the stock filter, after 7,000km of usage. New one I purchased, I had layered it with 3M. Difference? Air flow less by around 10-20%. Expected. Fresh air! You don't smell fumes or funny things from the aircond. can show the before and after of the 3M filter? ↡ Advertisement Link to post Share on other sites More sharing options...
Stik 1st Gear September 22, 2019 Share September 22, 2019 34 minutes ago, Wildfaye29 said: can show the before and after of the 3M filter? Wait few months later.. 😛 So far from experience, it won' t be dark but grey, It will trap enough dust particles at around 10,000km to choke the air flow down to 60%. Expect to replace it every 8000km. Your stock filter will still look like new as the 3M took everything. 1 Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged September 23, 2019 Share September 23, 2019 13 hours ago, Stik said: Wait few months later.. 😛 So far from experience, it won' t be dark but grey, It will trap enough dust particles at around 10,000km to choke the air flow down to 60%. Expect to replace it every 8000km. Your stock filter will still look like new as the 3M took everything. BTW u got use this on home Aircon? Does it actually make the Aircon cooling coil cleaner and easier to maintain on terms of servicing? Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear September 23, 2019 Share September 23, 2019 It seems like one could modify the original air con filter holder, with the original paper filter removed and stick the 3M N95 filter since the 3M ones perform better over the original and could retain or improve the air flow. Link to post Share on other sites More sharing options...
Stik 1st Gear September 23, 2019 Share September 23, 2019 8 hours ago, Wildfaye29 said: BTW u got use this on home Aircon? Does it actually make the Aircon cooling coil cleaner and easier to maintain on terms of servicing? Oh yes! I didn't follow instruction by covering 2/3 of the surface, instead, I covered 100% of the surface. Turns out the cooling fin is spanking clean after few years of usage. Dust free. Just need to change the filter. 1 Link to post Share on other sites More sharing options...
Stik 1st Gear September 23, 2019 Share September 23, 2019 7 hours ago, Heartbreakid said: It seems like one could modify the original air con filter holder, with the original paper filter removed and stick the 3M N95 filter since the 3M ones perform better over the original and could retain or improve the air flow. I wouldn't do that, unless you are pretty sure you are able to secure the filter layer nicely without it getting sucked into the system. Link to post Share on other sites More sharing options...
Stik 1st Gear September 23, 2019 Share September 23, 2019 (edited) Filter I am using is actually this one: https://www.filtrete.com.hk/3M/zh_HK/filtrete-hk/products/~/3M-淨呼吸-靜電空氣濾網-超效能過濾14-x103-9908R-/?N=4315+3291245372+3294529192&rt=rud 14" wide (36cm) x 103" (2.6m) long. Edited September 23, 2019 by Stik Linked to product page. 1 Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged September 23, 2019 Share September 23, 2019 1 hour ago, Stik said: Filter I am using is actually this one: https://www.filtrete.com.hk/3M/zh_HK/filtrete-hk/products/~/3M-淨呼吸-靜電空氣濾網-超效能過濾14-x103-9908R-/?N=4315+3291245372+3294529192&rt=rud 14" wide (36cm) x 103" (2.6m) long. u buy from HK? how much? Taobao got similar product but diff packaging Link to post Share on other sites More sharing options...
Stik 1st Gear September 23, 2019 Share September 23, 2019 7 hours ago, Wildfaye29 said: u buy from HK? how much? Taobao got similar product but diff packaging HKD250 for the purple box. HKD190 for the red box. I find the effectiveness of both are good and can't really tell the difference in use. Link to post Share on other sites More sharing options...
lawrencetay512 Neutral Newbie September 24, 2019 Share September 24, 2019 hi, anyone knows how to remove and change the polelight? been trying to turn counter clockwise, push and turn , pull also cant work. thanks. Link to post Share on other sites More sharing options...
Stik 1st Gear September 29, 2019 Share September 29, 2019 On 9/25/2019 at 4:04 AM, lawrencetay512 said: hi, anyone knows how to remove and change the polelight? been trying to turn counter clockwise, push and turn , pull also cant work. thanks. If I see your pole light correct which is at bottom, you should be able to turn it then pull out. Link to post Share on other sites More sharing options...
lawrencetay512 Neutral Newbie September 29, 2019 Share September 29, 2019 will try to turn it clockwise. thank u for the info. Link to post Share on other sites More sharing options...
Stik 1st Gear October 10, 2019 Share October 10, 2019 LED arrived from Taobao few weeks ago but haven’t got time to fix. Finally found time and found my friend have time to help So strip the meter cluster for second time, now place it back to identify the blown LED.. appears to have two blown LED in the 3x4 LED cluster Link to post Share on other sites More sharing options...
Stik 1st Gear October 10, 2019 Share October 10, 2019 LED testing and replacement.. solder at side so quite easy to work on Later tonight reassemble and share the picture later Link to post Share on other sites More sharing options...
Mkl22 Twincharged October 10, 2019 Share October 10, 2019 On 9/23/2019 at 11:09 AM, Wildfaye29 said: BTW u got use this on home Aircon? Does it actually make the Aircon cooling coil cleaner and easier to maintain on terms of servicing? i use the daiso one for my home aircon. yes it keeps the coil and fan blades cleaner. possible to stretch the chemical cleaning till 2yrs plus. Link to post Share on other sites More sharing options...
Stik 1st Gear October 10, 2019 Share October 10, 2019 Final test, final assembly and reinstall all good 2 Link to post Share on other sites More sharing options...
teomingern 6th Gear October 12, 2019 Share October 12, 2019 Nice bro... thanks for sharing the DIY replacement... Link to post Share on other sites More sharing options...
thetwoot Neutral Newbie October 21, 2019 Share October 21, 2019 Hi guys, new to the forum and a car noob. In July 19 bought my first car, a COE Avante 2009, and the other day the brakes became intermittently unresponsive with brakes sinking down to the floor and spongy and had a hell of a time stopping the car. Brought it to Harmony Motors Toh Guan and I was told either Brake pump or ABS pump spoilt. They recommended replacing brake pump first and bled my brakes. Asked me to monitor a week or two if the issue relapse. Now the brakes felt firm and seemed fine but I'm still feeling insecure and unsafe with my ride. Anyone encountered this issue before? Any advice from experiences? Pls give me some guidance guys... On a side note, really lucky didnt get injured and managed to stop and activate towing... ↡ Advertisement Link to post Share on other sites More sharing options...
Cost of new SG citizenship
2024 Hyundai Kona Electric Debuts: Refreshed Design, 260-Mile Estimated Range
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
