Stik 1st Gear November 11, 2019 Share November 11, 2019 On 10/23/2019 at 11:08 PM, Heartbreakid said: I am not sure if what u r smelling is the same as what I had experienced before. Mine smell like mouldy, urine smell at times. Usually caused by the moisture within the cold air system. Usually I turned to heater and blast it about 10 mins prior to reaching home. Your case, could be refrigerant leakage, etc and hence the smell, better get a mechanic to check it out. Moldy smell can be rid of easily. Just get a can of cooling coil cleaner and empty it into the aircond fan below the aircond filter, while having the aircond turned on at max blower speed.. It has anti bacterial content, this rid of the moldy smell. I rid of the moldy smell of my aircond this way. ↡ Advertisement Link to post Share on other sites More sharing options...
Stik 1st Gear November 11, 2019 Share November 11, 2019 On 10/23/2019 at 3:51 PM, silverdoe said: Guys, I’m contemplating on getting a 2009 Avante. Any thoughts and recommendation? Is the maintenance cost manageable for existing owners? I don't own the Avante but I own i30CW which has similar mechanical with Avante. Parts are very cheap, cheaper than Jap cars, and easily available in Malaysia too. Whatever problems it has, it's already known. So many workshops can handle it. Link to post Share on other sites More sharing options...
Stik 1st Gear November 11, 2019 Share November 11, 2019 On 10/21/2019 at 3:34 PM, thetwoot said: Hi guys, new to the forum and a car noob. In July 19 bought my first car, a COE Avante 2009, and the other day the brakes became intermittently unresponsive with brakes sinking down to the floor and spongy and had a hell of a time stopping the car. Brought it to Harmony Motors Toh Guan and I was told either Brake pump or ABS pump spoilt. They recommended replacing brake pump first and bled my brakes. Asked me to monitor a week or two if the issue relapse. Now the brakes felt firm and seemed fine but I'm still feeling insecure and unsafe with my ride. Anyone encountered this issue before? Any advice from experiences? Pls give me some guidance guys... On a side note, really lucky didnt get injured and managed to stop and activate towing... brake softening up usually caused by cavity in brake fluid delivery system or weak seal within master pump. So the usual process is 1. Visual inspection at brake lines and pumps for leaking. 2. Replace brake fluid, bleed at all 4 wheels to eliminate cavity. --> usually after this step, will bring car out to test. but for peace of mind, do (3) 3. Replace brake master pump. I won't be looking at ABS pump at this stage, not at all. As this is a used car with history unknown, it's always a precautionary measure to replace all the fluids (radiator, brake), fan belt, lubricants (engine and gearbox) when you got the car... Link to post Share on other sites More sharing options...
AzmiAliAdnan Neutral Newbie November 13, 2019 Share November 13, 2019 Hi All, Need advise. My car vibrate during idle in D mode. When I off my aircon the vibrate is minimal. Any possible reasons or do I need to change any parts of the car. Possible cost for repair works. Thanks all. Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear November 13, 2019 Share November 13, 2019 (edited) 50 minutes ago, AzmiAliAdnan said: Hi All, Need advise. My car vibrate during idle in D mode. When I off my aircon the vibrate is minimal. Any possible reasons or do I need to change any parts of the car. Possible cost for repair works. Thanks all. Two things: 1st - Maybe a throttle body cleaning would help. 2nd - If 1st doesn't work, probably the idling servo (which is located at the top of the throttlebody assembly) needs to be replaced. I wouldn't guarantee these two solutions will solve your mentioned issue but it sounds like is idling control related hence my advice. Edited November 13, 2019 by Heartbreakid Link to post Share on other sites More sharing options...
AzmiAliAdnan Neutral Newbie November 13, 2019 Share November 13, 2019 For point 1: can i DIY? For point 2: replacement wise what is the likely cost damage im expecting Link to post Share on other sites More sharing options...
Kengheng450 2nd Gear November 13, 2019 Share November 13, 2019 This issue is due to engine mounting rubber worn,need to replace,cost about few hundred. Link to post Share on other sites More sharing options...
Newowner2009 1st Gear December 19, 2019 Share December 19, 2019 Anyone own avante HD? how many times your gear changes before it cruise mine is 4x the 2nd time the drag last the longest . Above 2k rpm , the gear changes is it normal ? Link to post Share on other sites More sharing options...
ferrytales 4th Gear December 19, 2019 Share December 19, 2019 43 minutes ago, Newowner2009 said: Anyone own avante HD? how many times your gear changes before it cruise mine is 4x the 2nd time the drag last the longest . Above 2k rpm , the gear changes is it normal ? depends on how you define cruising? avante hd is 4 auto so naturally it will change 4 times. 2nd gear is usually a torquey gear ratio to pull your car from around 20km/h onwards to around 50/60kmh. Link to post Share on other sites More sharing options...
Newowner2009 1st Gear December 19, 2019 Share December 19, 2019 27 minutes ago, ferrytales said: depends on how you define cruising? avante hd is 4 auto so naturally it will change 4 times. 2nd gear is usually a torquey gear ratio to pull your car from around 20km/h onwards to around 50/60kmh. Thanks for the prompt reply . Meaning in d mode , from stationary to when we start accelerating , the moment the car move , it is in gear 0? If it switch 4 times , cruising mode is in 4th gear . Am I right ? Or start in 1 , cruise in 5th gear ? Link to post Share on other sites More sharing options...
teomingern 6th Gear December 20, 2019 Share December 20, 2019 12 hours ago, Newowner2009 said: Thanks for the prompt reply . Meaning in d mode , from stationary to when we start accelerating , the moment the car move , it is in gear 0? If it switch 4 times , cruising mode is in 4th gear . Am I right ? Or start in 1 , cruise in 5th gear ? Obviously you start off at neutral gear or what you term gear 0. The moment you step on the accelerator, the gearbox will engage 1st gear lar... there isn't a gear 0 if that's what you're trying to ascertain... therefore you start off by engaging 1st gear and the automatic gearbox will simply change up to 2, 3 and 4 under suitable conditions lor... Link to post Share on other sites More sharing options...
ferrytales 4th Gear December 20, 2019 Share December 20, 2019 14 hours ago, Newowner2009 said: Thanks for the prompt reply . Meaning in d mode , from stationary to when we start accelerating , the moment the car move , it is in gear 0? If it switch 4 times , cruising mode is in 4th gear . Am I right ? Or start in 1 , cruise in 5th gear ? i guess you've never driven a manual car where you gotta engage the 1st gear for the car to move. otherwise it will be on neutral gear. Link to post Share on other sites More sharing options...
Newowner2009 1st Gear December 20, 2019 Share December 20, 2019 8 hours ago, ferrytales said: i guess you've never driven a manual car where you gotta engage the 1st gear for the car to move. otherwise it will be on neutral gear. Haha. Since get class 3 license , never touch manual . I think I know already cos I am confused when ppl say avante hd only 4 “speed “. And old avante dashboard dun show the gear number Actually is change gear 4 times , can reach 5th gear Link to post Share on other sites More sharing options...
teomingern 6th Gear December 22, 2019 Share December 22, 2019 On 12/20/2019 at 8:52 PM, Newowner2009 said: Haha. Since get class 3 license , never touch manual . I think I know already cos I am confused when ppl say avante hd only 4 “speed “. And old avante dashboard dun show the gear number Actually is change gear 4 times , can reach 5th gear No... there are only 4 gears... there's no 5th gear... Link to post Share on other sites More sharing options...
Newowner2009 1st Gear December 22, 2019 Share December 22, 2019 15 hours ago, teomingern said: No... there are only 4 gears... there's no 5th gear... Sian then . Recently repair gearbox to fix other critical issue , yet this issue still remain . normally , the 3 gear changing is at what speed eg, 1 to 2 , x 2 to 3, y 3 to 4 , z Link to post Share on other sites More sharing options...
teomingern 6th Gear December 24, 2019 Share December 24, 2019 On 12/23/2019 at 7:34 AM, Newowner2009 said: Sian then . Recently repair gearbox to fix other critical issue , yet this issue still remain . normally , the 3 gear changing is at what speed eg, 1 to 2 , x 2 to 3, y 3 to 4 , z That's the standard gearbox of the era bro... sian for what? Ha ha... and unless your gearbox has a manual override, it will only show the gear in the manual override mode... not often you get the gear display when in full auto mode... What problem still remains? Repair means? What did your mechanic replace? Link to post Share on other sites More sharing options...
Newowner2009 1st Gear December 26, 2019 Share December 26, 2019 On 12/24/2019 at 5:08 PM, teomingern said: That's the standard gearbox of the era bro... sian for what? Ha ha... and unless your gearbox has a manual override, it will only show the gear in the manual override mode... not often you get the gear display when in full auto mode... What problem still remains? Repair means? What did your mechanic replace? Haha : just want the car to behave normally which the rpm will drop 3 times instead of 4 times it is not a serious issue . Even though the rpm drop an extra time , I did not experience loss of power btw, just did an overhaul Link to post Share on other sites More sharing options...
teomingern 6th Gear December 28, 2019 Share December 28, 2019 On 12/26/2019 at 8:13 AM, Newowner2009 said: Haha : just want the car to behave normally which the rpm will drop 3 times instead of 4 times it is not a serious issue . Even though the rpm drop an extra time , I did not experience loss of power btw, just did an overhaul The 4th time the RPM falls is due to overdrive... I know what you're referring to I think... ↡ Advertisement Link to post Share on other sites More sharing options...
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
