Tcx607 4th Gear August 28, 2013 Share August 28, 2013 Recently, I came across a electronic circuit connect to the battery. Looks a like the voltage stabilizer Basically, I break down the carbon and sulphate dioxide on the batt plate to improve performance. Even old battery, it will function as per normal. Anyone aware of this gadget??? ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic August 28, 2013 Share August 28, 2013 Automotive battery is lead-acid battery and composed of lead/oxide plates/sponge and sulphuric acid. There is no carbon and no dioxide. Anyone who market this does not know the basics. Lead sulphate is formed during the discharge phase. It is normally converted back to its lead and sulphuric acid component during charging. However, it is known that some lead sulphate can hardened and do not revert back, especially when left for prolonged period in a discharged state. Some people sells desulphators, which are electronic device sending out high voltage pulse in an attempt to breakdown the hardened lead sulphate. Results may vary depending on how badly the battery is sulphated. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 28, 2013 Share August 28, 2013 Recently, I came across a electronic circuit connect to the battery. Looks a like the voltage stabilizer Basically, I break down the carbon and sulphate dioxide on the batt plate to improve performance. Even old battery, it will function as per normal. Anyone aware of this gadget??? As I know the battery plates wil start to b covered with the sulphuate when the current stops flowing. This device might b releasing a small current to the battery after u shut off the engine to prevent this. It wil make yr battery last much longer. Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 29, 2013 Share August 29, 2013 Can share how you DIY the cameras battery? I already shared in the in-car camera thread. Go search for it there. Lets not OT on other stuff here on this thread. Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 29, 2013 Share August 29, 2013 The most effective way to break down sulphated battery plates is via a battery charger that have such charging mode. Link to post Share on other sites More sharing options...
Davidtoh Clutched September 11, 2013 Share September 11, 2013 omg... are you serious.. Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 11, 2013 Share September 11, 2013 in what????? Link to post Share on other sites More sharing options...
ThePeak Neutral Newbie September 11, 2013 Share September 11, 2013 My batt just died at my workplace....will jump start later, anione noe which workshop is open after 8pm? Link to post Share on other sites More sharing options...
TVT Supercharged September 11, 2013 Share September 11, 2013 My batt just died at my workplace....will jump start later, anione noe which workshop is open after 8pm? Call the DACB guy, he advertise on our MCF. His name is Eric, service not bad. He will come to you, 24hrs a day! Link to post Share on other sites More sharing options...
ThePeak Neutral Newbie September 11, 2013 Share September 11, 2013 Call the DACB guy, he advertise on our MCF. His name is Eric, service not bad. He will come to you, 24hrs a day! Thanks bro..cheers. Link to post Share on other sites More sharing options...
Tapas Neutral Newbie September 12, 2013 Share September 12, 2013 Any kind soul working ard Amoy Street can help me jumpstart later ard 6pm?? Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 13, 2013 Share September 13, 2013 The easiest way is to use a multimeter or voltmeter to check the voltage at the battery if it is 13+ to 14V. If it is, means alternator is working. If only 12+ to 11V, means alternator not working. No need to remove batt terminal. that's the right way to test it Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 13, 2013 Share September 13, 2013 I am very scared and of maintenance free battery. Some can last quite long but some just die without warning. I Kena twice and now only use wet battery. At least can last 2 years. When you tried that have to top up water more and more, have to be careful already cos it's a sign of end of life. For around$100 per battery, quite worth. Topping up battery water is not that difficult that's true, sealed maintenance free battery do not give you "advance" warning before it die, wet type still have some tell tale signs Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 13, 2013 Share September 13, 2013 If u need to top-up water often, it means yr alternator is over-charging the battery. But now most pple use maintenance-free battery. Most can last abt 2 yrs. If less than that, the battery farked up. But also depends on what electrical stuff u hv. If u overload it wil spoil faster. besides overloading, it also depends on the number of cranks you do per day cause that's where most of the juice are sucked out of the battery. Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 13, 2013 Share September 13, 2013 Automotive battery is lead-acid battery and composed of lead/oxide plates/sponge and sulphuric acid. There is no carbon and no dioxide. Anyone who market this does not know the basics. Lead sulphate is formed during the discharge phase. It is normally converted back to its lead and sulphuric acid component during charging. However, it is known that some lead sulphate can hardened and do not revert back, especially when left for prolonged period in a discharged state. Some people sells desulphators, which are electronic device sending out high voltage pulse in an attempt to breakdown the hardened lead sulphate. Results may vary depending on how badly the battery is sulphated. well said, not a lot of owners out there understand the theory behind desulphators. Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 14, 2013 Share September 14, 2013 besides overloading, it also depends on the number of cranks you do per day cause that's where most of the juice are sucked out of the battery. Ya thats why try not to do short trips of <20mins cos each crank to start takes abt 20 mins to recharge the juice used. Also short trips dun give yr exhaust pipe time to dry throughly n u wil get corrosion very quickly. Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 15, 2013 Share September 15, 2013 Ya thats why try not to do short trips of <20mins cos each crank to start takes abt 20 mins to recharge the juice used. Also short trips dun give yr exhaust pipe time to dry throughly n u wil get corrosion very quickly. well, unless they drive like me so short trip won't be a problem to charge the battery, the problem is FC will be bad Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 15, 2013 Share September 15, 2013 well, unless they drive like me so short trip won't be a problem to charge the battery, the problem is FC will be bad Ya some dun hv that problem but hv others. Hahaha Most of my trips >30 mins so Im safe. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
My EV journey to the i4
Request for dark mode
The Electric Vehicle Charging Problem
Lithium-Iron Battery (LFP) - New & Better Alternative?
Car key fob battery
Car key fob battery
