mersaylee Supersonic October 20, 2021 Share October 20, 2021 2 minutes ago, Fcw75 said: This grille. Other than to prevent dumb people from putting his finger in to touch the moving fan, I see no purpose? Got rust one…na bei. As for the flap, I see something like a plastic screw on the other end so wondering if can be remove. How do you guys DIY clean the fan blades? Mine doesn't have that. It's so high up for any unassuming kiddo to reach it... However, yes, there are dumb adults out there though...like retrieving wind mirror or cycling along the expressway for example...😁 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 20, 2021 Share October 20, 2021 (edited) 1 hour ago, Fcw75 said: How do you guys DIY clean the fan blades? Need to remove the whole cover. Then unscrew the side of the fan mount. Unscrew the locking screw within the fan blade. Lift the coiling coil slightly and slide the fan blades out. I do this fan blade cleaning like once a year. I bring the entire fan blade roller to the bathroom, switch on my Worx Hydroshot and blast away the dust and dirt attached to the fan blades. Edited October 20, 2021 by Adrianli 5 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 20, 2021 Share October 20, 2021 1 hour ago, Fcw75 said: This grille. Other than to prevent dumb people from putting his finger in to touch the moving fan, I see no purpose? Got rust one…na bei. As for the flap, I see something like a plastic screw on the other end so wondering if can be remove. How do you guys DIY clean the fan blades? Mine also no grille. Probably different models. After setting up the cover, I clean the blower with high pressure water jet. I find it much easier than removing the blower. https://shopee.sg/New-Air-Conditioner-Cleaning-Cover-Waterproof-Cleaning-Dust-Washing-Cover-Clean-Protector-White-Household-Tools-i.314130759.6661007786 3 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 20, 2021 Share October 20, 2021 6 minutes ago, Adrianli said: Need to remove the whole cover. Then unscrew the side of the fan mount. Unscrew the locking screw within the fan blade. Lift the coiling coil slightly and slide the fan blades out. I do this fan blade cleaning like once a year. I bring the entire fan blade roller to the bathroom, switch on my Worx Hydroshot and blast away the dust and dirt attached to the fan blades. Taking out always easier than putting back 😅 Any difficulty putting back? 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 20, 2021 Share October 20, 2021 2 minutes ago, Kb27 said: Mine also no grille. Probably different models. After setting up the cover, I clean the blower with high pressure water jet. I find it much easier than removing the blower. https://shopee.sg/New-Air-Conditioner-Cleaning-Cover-Waterproof-Cleaning-Dust-Washing-Cover-Clean-Protector-White-Household-Tools-i.314130759.6661007786 Use high water pressure jet in room? I cannot la…haha. Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 20, 2021 Share October 20, 2021 13 minutes ago, Fcw75 said: Taking out always easier than putting back 😅 Any difficulty putting back? No difficulty. However, when new, a bit difficult. After a few times, pretty much "loose" already so easier. 3 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 20, 2021 Share October 20, 2021 10 minutes ago, Adrianli said: No difficulty. However, when new, a bit difficult. After a few times, pretty much "loose" already so easier. Hmmmmm…..😁 1 Link to post Share on other sites More sharing options...
mersaylee Supersonic October 20, 2021 Share October 20, 2021 7 minutes ago, Fcw75 said: Hmmmmm…..😁 Like all things...don't be too uptight when thing gets loose after a while...it's known as seasoned...😁 2 Link to post Share on other sites More sharing options...
mersaylee Supersonic October 20, 2021 Share October 20, 2021 @Fcw75 How come yours doesn't seem to have the louvre to close the opening when not in use? Industrial type of fan coil? 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 20, 2021 Share October 20, 2021 58 minutes ago, Fcw75 said: Taking out always easier than putting back 😅 Any difficulty putting back? Putting the blower back needs a bit of adjustment. Use a torchlight (headlight is easier, so you have both hands to work) and shine at the right side where the motor is. You will find a slot, this is where the screw needs to sit into. Otherwise, it will not hold the blower properly. The right side of the blower is a rubber thingy where it rest on the chassis. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 20, 2021 Share October 20, 2021 21 minutes ago, mersaylee said: @Fcw75 How come yours doesn't seem to have the louvre to close the opening when not in use? Industrial type of fan coil? Have bro. Just above the black metal grille in the photo. 😁 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 20, 2021 Share October 20, 2021 10 minutes ago, Kb27 said: Putting the blower back needs a bit of adjustment. Use a torchlight (headlight is easier, so you have both hands to work) and shine at the right side where the motor is. You will find a slot, this is where the screw needs to sit into. Otherwise, it will not hold the blower properly. The right side of the blower is a rubber thingy where it rest on the chassis. Thanks for the info bro. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 20, 2021 Share October 20, 2021 Saw this video and I have the exact unit with the black metal grille. 2 Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 29, 2021 Share October 29, 2021 At last, gotten the aircon men come and check. Turns out, no more gas. So will be arranging with them to do checking before topping up any gas. If not waste money to top up gas. Pressure testing of gas pipes will cost me $320. Need to arrange another day. 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 30, 2021 Share October 30, 2021 Pressure testing in progress. Need to monitor the Pressure gauge everyday and see if got drop in Pressure for each indoor unit. They used nitrogen for this test. 4 Link to post Share on other sites More sharing options...
Mkl22 Twincharged October 30, 2021 Share October 30, 2021 (edited) 25 minutes ago, Adrianli said: Pressure testing in progress. Need to monitor the Pressure gauge everyday and see if got drop in Pressure for each indoor unit. They used nitrogen for this test. How old and did you chemical clean or remove anything the last 6mths. typically something leaks after the pipes are removed. thus with my new units. I only pressure wash insitu. No more taking down to chem wash if I pressure wash it every 4mths or so. Will be clean enough Edited October 30, 2021 by Mkl22 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 30, 2021 Share October 30, 2021 39 minutes ago, Adrianli said: Pressure testing in progress. Need to monitor the Pressure gauge everyday and see if got drop in Pressure for each indoor unit. They used nitrogen for this test. Few days no aircon?? 😅 Pray for cooling weather. Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 30, 2021 Share October 30, 2021 45 minutes ago, Mkl22 said: How old and did you chemical clean or remove anything the last 6mths. typically something leaks after the pipes are removed. thus with my new units. I only pressure wash insitu. No more taking down to chem wash if I pressure wash it every 4mths or so. Will be clean enough Around 8 years old. Never chemical wash before. Previously, did replace 1 indoor unit, 2 years ago. ↡ Advertisement 2 1 Link to post Share on other sites More sharing options...
Simple home DIY repairs
Electrician lobang?
Electrician lobang?
Home renovation tips
