Cephas
3rd Gear
Last few days the weather was a killer! and the aircon is always temperamental to break down on these hot days.....
Was reading the forum for aircon workshop - MarkCool, Tomika came up as most popular. Some suggestions were Kim.
Went over to Ubi early morning 8.45am. Saw Tomika already opened and Kim was yet to open. There were already cars inside Tomika so decided to wait for Kim.
After discussion with Kim and his visual inspection, the possibility of breakdown is cooling coil leak. Quoted the job cost, nego a bit, go ahead to do it.
Good thing is if the coil is OK, then i just need to pay for aircon service fee (include coil checking).
Humble boss, give Kim a try. Just make sure you are early because the job will take 3-4hrs (for cooling coil or more for compressor).
The assistant is OK quite open to share knowledge with me.
The above quote applied to bread & butter Jap 1.3L car. I understand from boss that Conti car will need more workmanship, thus higher job fee.
Share this post
3rd Gear
my aircon also wacko these few days, gas is full, but takes very lonf time to cool down ( 10 mins) can feel the coolness only if you switch the fan speed to a low level...
Share this post
Clutched
maybe u can check on the cabin filter as sometime it will block the wind from coming out,hence need longer time to cool your ride.
Share this post
3rd Gear (edited)
I have removed the filter lor...tested, tried, still hot air blowing....
I got similar issue last year, change filter, it was settled. Now take out the whole filter, go direct blow, also hot, no choice, got to repair... [:(]
Edited by Cephas
Share this post
3rd Gear
So what is yr damage?
PM sent.
Share this post
Can anyone advise if changing of air con compressor oil required? Driving for 3.5years now.
Share this post
Clutched
PM sent.
Might sharing with me the damage as well?? I have a similar problem where there's a gas leak in the coil.
Thanks.
Share this post
Hypersonic
Don't fix it if it ain't broken.
Share this post
3rd Gear
Thanks.
PM sent.
Share this post
3rd Gear
Fully agreed.
Share this post
1st Gear
yes,air con compressor oil need to change,it can extand your air con clucth and compressor life band.i will change around 40-50k km
Share this post
1st Gear
From what I know is 60000 km . Quite subjective....some said necessary and some said no. Still down to consumer. -_-
Share this post
Clutched
my ride at around 180K, luckily did not need to change anything till now,
Recently gas leak, need to change cooling coil already
Share this post
Moderator
i dont quite agree to this.
i believe in changing the air con compressor oil periodically. i change every 40k KM or so. It doesn't cost alot anyway. I just did it on last Sat. Costs me $68.
the ws will clean up the inside blower too.
many drivers don't change air con compressor oil and the compressor will not last long eventually.
Share this post
Hypersonic
Different view I guess. My VW is now 5 and 8 mths with mileage 80K. Never done servicing before, the aircon still strong and cold. Only change the aircon filter every 20K.
Share this post
To be honest, I did nothing to my Hyundai Matrix's air con for the past 9 years except cabin filter changed. It went strong till I scraped the car recently but I still think is good to do a oil change for the compressor.
Share this post
Turbocharged (edited)
I used to subscribe that changing compressor oil is good. But then the fridge and home Aircon also never heard of anyone changing oils before. What's so special about car Aircon? So never bother now. I think it's just a way to get more money by workshops.
Edited by Mkl22
Share this post
