Sign in to follow this
Newdrive
A loud sound coming from under carriage during sharp turning
went to service my car last sat and was told that i need to replace my drive shaft...
Before this servicing i noticed whenever i do turning (i find the bends quite sharp for me) at first lane (after MBS towards AYE) i will heard a loud sound coming from undercarriage. the technician told me could be due to this drive shaft...
But after changing the drive shaft, both sides.
I still encounter this issue.
Any idea what other possible causes?
Share this post
When servicing the under carriage drive shaft
always make sure there is enough lubrication.
If there is not enough grease the friction is very bad
for the drive shaft and this leads to premature failure.
:D
Share this post
Steering rack could be also the issue. I faced it last time.
Share this post
if turning got sound usually is CV joint shot.....
sorry me not a mechanical person... but i did some google... i change the whole drive shaft, CV joint is part of it right?if so then weird... cos i still experiencing that sound when i do turning (only during sharp turns)...
Edited by Newdrive
Share this post
hmm steering rack usually last how long? my car is 7 year old... 114k miles already.
Share this post
:D
thanks for advise!
Share this post
I dont think not all car models come as a complete set. From your initial pics looks like your cv boot is torn and likely cv joint is gone which causes sound when you turn. You sure your workshop change the whole drive shaft with new cv joint? To double confirm you might want to look at the cv joint boot and shaft is actually new.
Edited by Ivanpaseo
Share this post
you better go workshop ASAP change
my drive shaft broke, axle broke, cost me $3K :wacko:
tolong a bit, plrease go and change
Share this post
I changed it at Elite Drive Shaft. is a whole piece (left + right). the picture u see is before I change.
Share this post
change already... left and right by Elite Drive Shaft.
Share this post
heng is change arleady
dont be like me, drive until the whole shaft up my own lorlee :ph34r:
Share this post
If drive shaft and Cv joint is changed. You might want to check your control arm bushes and sway bar links.
Share this post
ok. most probably i send my car to the workshop to check again this sat (me driving OPC and not driving often). think better to let them diagnose the root cause of the sound... [crazy]
Share this post
