Count_duku 4th Gear July 28, 2013 Share July 28, 2013 I tried installing one of those cheap t10 led into the side lights (evening lights) slot. The moment I slot in even without key in the ignition, it lights up, cannot switch off and blows the signal light in the process + canbus error. Sigh.. lesson learned dun use non canbus LEDs, plugged back old regular bulb and replaced signal light. ↡ Advertisement Link to post Share on other sites More sharing options...
Desmojon 1st Gear July 28, 2013 Share July 28, 2013 I tried installing one of those cheap t10 led into the side lights (evening lights) slot. The moment I slot in even without key in the ignition, it lights up, cannot switch off and blows the signal light in the process + canbus error. Sigh.. lesson learned dun use non canbus LEDs, plugged back old regular bulb and replaced signal light. I also back side itchy one day and bought those led from eBay that mentions they are canbus error free. Not really expensive. I swapped out the side signal lights and the side lights. Try those that mention canbus free. Link to post Share on other sites More sharing options...
Chaona Clutched July 28, 2013 Share July 28, 2013 I tried installing one of those cheap t10 led into the side lights (evening lights) slot. The moment I slot in even without key in the ignition, it lights up, cannot switch off and blows the signal light in the process + canbus error. Sigh.. lesson learned dun use non canbus LEDs, plugged back old regular bulb and replaced signal light. make sure these canbus LEDs are heat proof as well, had 2 installed for my front parking lights and the LEDs blew after a month. Link to post Share on other sites More sharing options...
Upsilon Clutched July 28, 2013 Share July 28, 2013 make sure these canbus LEDs are heat proof as well, had 2 installed for my front parking lights and the LEDs blew after a month. W5W is still the best, don't trust these led from eBay anymore. They are mostly made of crap chips that doesn't last as long as a typical w5w, the good one cost 10 or 20 times more than a typical bulb. Just changed mine to red w5w sidelights, the centre light is now red... A bit too 'beng'? Link to post Share on other sites More sharing options...
Wrxblue 1st Gear July 28, 2013 Share July 28, 2013 Went up to Port Dickson and back over the weekend. Link to post Share on other sites More sharing options...
Desmojon 1st Gear July 28, 2013 Share July 28, 2013 W5W is still the best, don't trust these led from eBay anymore. They are mostly made of crap chips that doesn't last as long as a typical w5w, the good one cost 10 or 20 times more than a typical bulb. Just changed mine to red w5w sidelights, the centre light is now red... A bit too 'beng'? Just be careful of LTA. If not swap out the rear ones. I am still monitoring if mine will blow. I keep the original in the boot. Link to post Share on other sites More sharing options...
Desmojon 1st Gear July 28, 2013 Share July 28, 2013 Went up to Port Dickson and back over the weekend. I was up in MY (Ipoh) too. My friend drove his M3 there. My car is still under observation for the cooling system that was repaired so did not take the risk to drive there. Link to post Share on other sites More sharing options...
Count_duku 4th Gear July 28, 2013 Share July 28, 2013 I also back side itchy one day and bought those led from eBay that mentions they are canbus error free. Not really expensive. I swapped out the side signal lights and the side lights. Try those that mention canbus free. OK will try canbus ones, but not red though .. maybe strobe red and blue but seriously, I am looking for a single forward firing bright LED that does not light up the housing reflectors. Something that can be seen even during the day, will really make the front look mean. Not exactly DRL but something that will integrate with the design of the hooded headlamps. Link to post Share on other sites More sharing options...
Upsilon Clutched July 28, 2013 Share July 28, 2013 OK will try canbus ones, but not red though .. maybe strobe red and blue but seriously, I am looking for a single forward firing bright LED that does not light up the housing reflectors. Something that can be seen even during the day, will really make the front look mean. Not exactly DRL but something that will integrate with the design of the hooded headlamps. You mean the CREE type of bulb? Like a mini projector lamp Random link, http://www.dhgate.com/product/t10-w5w-5w-c.../144554926.html I don't think it will work for us as our sidelight is 'tuck' into the top of the housing, the front projection is blocked. Link to post Share on other sites More sharing options...
Count_duku 4th Gear July 29, 2013 Share July 29, 2013 You mean the CREE type of bulb? Like a mini projector lamp Random link, http://www.dhgate.com/product/t10-w5w-5w-c.../144554926.html I don't think it will work for us as our sidelight is 'tuck' into the top of the housing, the front projection is blocked. Yeah saw the Cree 5w on eBay will buy this one. I know what you mean, if you look from further away the side light can be seen, just hidden when you look from near/top. Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear July 29, 2013 Author Share July 29, 2013 Changed out Millers gearbox oil with a oil additive. Shifting is much smoother :) Link to post Share on other sites More sharing options...
Ftco 2nd Gear July 29, 2013 Share July 29, 2013 Yeah saw the Cree 5w on eBay will buy this one. I know what you mean, if you look from further away the side light can be seen, just hidden when you look from near/top. No mention of canbus error free, so will this give issues? Link to post Share on other sites More sharing options...
Count_duku 4th Gear July 29, 2013 Share July 29, 2013 No mention of canbus error free, so will this give issues? Trying this "canbus error free" see whether it works: http://www.ebay.com/itm/2PCS-T10-501-1210-...575&vxp=mtr Link to post Share on other sites More sharing options...
Chrispie 5th Gear July 29, 2013 Share July 29, 2013 changed my selespeed accumulator... SS problem solved finally! Link to post Share on other sites More sharing options...
Desmojon 1st Gear July 29, 2013 Share July 29, 2013 changed my selespeed accumulator... SS problem solved finally! Feels like a brand new car isn't it? Link to post Share on other sites More sharing options...
Desmojon 1st Gear July 29, 2013 Share July 29, 2013 Trying this "canbus error free" see whether it works: http://www.ebay.com/itm/2PCS-T10-501-1210-...575&vxp=mtr They seems alright. I use these for about 3 weeks. http://item.mobileweb.ebay.com.sg/viewitem...Id=390566098152 I also did the yellow tint on the fog light same as you did before. Light penetrate through haze very well. Link to post Share on other sites More sharing options...
Thingy 1st Gear July 30, 2013 Share July 30, 2013 Changed my left and right lower arms... Heard from ppl saying that if you are using the air gun to tighten the bolts on your lower arm, it tends to give way earlier? Anyone has any idea? found my mid pipe leaking and now my babe is alive again.... Link to post Share on other sites More sharing options...
Iridiumx Clutched July 30, 2013 Share July 30, 2013 Changed my left and right lower arms... Heard from ppl saying that if you are using the air gun to tighten the bolts on your lower arm, it tends to give way earlier? Anyone has any idea? found my mid pipe leaking and now my babe is alive again.... the bolt give way? ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Alfa Romeo Tonale (965)
Suu Kyi detained
Suu Kyi detained
Left over Alfa Romeo owners
The 2017 Alfa Romeo Giulia
Today my credit card was hacked
