Kb27 Supersonic July 25, 2013 Share July 25, 2013 ok so such capacitors are definitely gonna of a decent size compared to normal capacitors. it also seems this author feels even large capacitors are overkill for ICE. what do you think of sprint booster? Yes, there are some who feels the Farad cap is not as useful. Whatever energy you take from the cap or the batt, you have to put it back somehow. It's only a matter of time. Caps are just faster than batt, but their stored energy is limited. Not sure which sprint booster you mention, but I google and it appears to be the same stuff as Pivot 3-drive. They modify TPS signal. You would have achieve the same thing if you step on the pedal more or less, but some people may just feel better with something that "helps" them by cheating the ECU. Personally, after playing around with a few mods, I get tired of them. They are more or less toys and they sucked away your money. If you want the real performance stuffs, if you have not already one; a turbocharged car would do wonders. Simple and it works. I'll rather spend my time and money elsewhere. ↡ Advertisement Link to post Share on other sites More sharing options...
Acemundo Supercharged July 25, 2013 Share July 25, 2013 Not sure which sprint booster you mention, but I google and it appears to be the same stuff as Pivot 3-drive. They modify TPS signal. You would have achieve the same thing if you step on the pedal more or less, but some people may just feel better with something that "helps" them by cheating the ECU. Personally, after playing around with a few mods, I get tired of them. They are more or less toys and they sucked away your money. If you want the real performance stuffs, if you have not already one; a turbocharged car would do wonders. Simple and it works. I'll rather spend my time and money elsewhere. haha I am just curious how they modify the signal. but to be far, I tried my brother's car with sprint booster it does make it more responsive but again I think it is more meaningful to get increase of power via turbos and ecu remap. I am currently on a turbo car anyway. I didn't ask about these gadets because I planned to use them. more like just satisfying my apetite for knowledge. Link to post Share on other sites More sharing options...
Kb27 Supersonic July 25, 2013 Share July 25, 2013 haha I am just curious how they modify the signal. but to be far, I tried my brother's car with sprint booster it does make it more responsive but again I think it is more meaningful to get increase of power via turbos and ecu remap. I am currently on a turbo car anyway. I didn't ask about these gadets because I planned to use them. more like just satisfying my apetite for knowledge. Such electronics are simple circuitry and not too difficult to build, although I don't profess to know exactly how. Example, if originally, factory range of TPS is between 1V to 4V; where 1V = idling rpm and 4V = redline rpm and we want to build a "sprint booster" for more response, we could simply shift the voltage return upwards. Instead of returning 1V to the ecu, we changed the signal to say 1.2V. Then we test if the ecu will wrongly interpret the signal and gives instruction to increase idling rpm. If it doesn't, good! We can sell it for that car. If ecu doesn't give the required result, we're looking for, we start looking elsewhere or changing voltage value only after certain range. So it's kind of trial and error. Remember, we are not the original car designer and only wants to screw with factory setting...and hopefully doesn't create other problems. The voltage shift can be simply done by choosing a set of resistors value or potential dividers, biased for the right voltage we desire. But this simple method has drawbacks and suffer from heat deviation which change resistors value. So going upscale, we may try the more expensive method of using transistors to bias the change. What I'm trying to say is, that simple electronics can easily achieve what we want. And we don't care what happens elsewhere due to our modification. We just want to build a low-cost product, slapped on a good branding and make big bucks !!! ...and with great marketing, we can all be rich. Link to post Share on other sites More sharing options...
Acemundo Supercharged July 25, 2013 Share July 25, 2013 very enlightening! I like the way you explained it Link to post Share on other sites More sharing options...
Kb27 Supersonic July 25, 2013 Share July 25, 2013 And if that infernal peony website author comes to "expose" our product, we pour black epoxy over it, even concrete if we have to. So that no one can open it without breaking into pieces. In the meantime, we advertise that it's proprietary, improved version 2 and need protection. But you get the idea. Such is the state of aftermarket products. 1 Link to post Share on other sites More sharing options...
Forte3737 5th Gear July 25, 2013 Share July 25, 2013 best is dun waste $$ on such things Link to post Share on other sites More sharing options...
Ysc3 Twincharged March 25, 2018 Share March 25, 2018 wow ... they are still at it ... now even bigger more expensive !! from $330 to $850 !! can buy 4 batteries liow !! Link to post Share on other sites More sharing options...
Othello Supersonic March 25, 2018 Share March 25, 2018 wow ... they are still at it ... now even bigger more expensive !! from $330 to $850 !! can buy 4 batteries liow !! $330 for carrot-elantra $850 for carrot-Lexus Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 27, 2018 Share March 27, 2018 Buy EPS Power Charger gets free Lexus ↡ Advertisement Link to post Share on other sites More sharing options...
S’pore Airshow - Worst transport experience’
Migrating down under? Come share your experiences
Suu Kyi detained
Suu Kyi detained
The Best Cooling Measures: Ice Cream! 😂
