Tianmo Hypersonic July 25, 2013 Share July 25, 2013 Ok two days back my maid came running to me.............the fan had stopped turning again...........the last time I sprayed some WD40 and it lasted for 2 months............this time ran out of WD40...........so I put afew drops of my balance engine oil............and it started to turn as new.... and so.........idea came to my mind...........I poured some engine oil into a spray container given by NEA (my area now hotspot lor).....and went around spraying on metal joints at home.............better than using WD40..........smooth smooth.... so for those with balance engine oil .............don't throw away............use it as household lubricant and save the money buying WD40........ those who do servicing at WS.........take back the balance of the engine oil......................don't let them sell those balance oil to others.............you paid for the oil after all...............and save some money on that can of WD40........ hope this idea can help make full use of balance engine oil........ [laugh] this is the 30ml bottle from NEA which I use to contain my engine oil spray........... ↡ Advertisement Link to post Share on other sites More sharing options...
Rustyz 5th Gear July 25, 2013 Share July 25, 2013 This thread would be tikko in no time Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 25, 2013 Share July 25, 2013 During the 70's used engine oil was reuse as anti corrosion fluid when storing up machineries and tools Link to post Share on other sites More sharing options...
Airwaver 4th Gear July 25, 2013 Share July 25, 2013 Sometimes I used it to lub my bicycle chain :D Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 25, 2013 Author Share July 25, 2013 During the 70's used engine oil was reuse as anti corrosion fluid when storing up machineries and tools wah........70's I still very young ...........lol but used engine oil contaminated liao leh..............not very healthy hor.......... Link to post Share on other sites More sharing options...
Mits_jc 5th Gear July 25, 2013 Share July 25, 2013 That's a very good idea, thanks for sharing. Any issue with the EO coming out of the spray nozzle, meaning is it too thick? Ok two days back my maid came running to me.............the fan had stopped turning again...........the last time I sprayed some WD40 and it lasted for 2 months............this time ran out of WD40...........so I put afew drops of my balance engine oil............and it started to turn as new.... and so.........idea came to my mind...........I poured some engine oil into a spray container given by NEA (my area now hotspot lor).....and went around spraying on metal joints at home.............better than using WD40..........smooth smooth.... so for those with balance engine oil .............don't throw away............use it as household lubricant and save the money buying WD40........ those who do servicing at WS.........take back the balance of the engine oil......................don't let them sell those balance oil to others.............you paid for the oil after all...............and save some money on that can of WD40........ hope this idea can help make full use of balance engine oil........ [laugh] this is the 30ml bottle from NEA which I use to contain my engine oil spray........... Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 25, 2013 Author Share July 25, 2013 That's a very good idea, thanks for sharing. Any issue with the EO coming out of the spray nozzle, meaning is it too thick? mine is 5w30..........no problem..........but of course no as strong as WD40 lah............. [laugh] Link to post Share on other sites More sharing options...
Hydraexhaust Neutral Newbie July 26, 2013 Share July 26, 2013 I use the eo to lubricate my kupchai chain/sporcket. Haha Link to post Share on other sites More sharing options...
Acemundo Supercharged July 26, 2013 Share July 26, 2013 solid. like that also you can think of Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 26, 2013 Author Share July 26, 2013 solid. like that also you can think of I cheapskate mah.......... [laugh] sometimes ideas just strike from nowhere lah.......... Link to post Share on other sites More sharing options...
RadX Moderator July 26, 2013 Share July 26, 2013 I cheapskate mah.......... [laugh] sometimes ideas just strike from nowhere lah.......... dun try using in replacement of KY.....pls [laugh] Link to post Share on other sites More sharing options...
Newdrive 1st Gear July 26, 2013 Share July 26, 2013 idea! but w40 too thick right? Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 26, 2013 Author Share July 26, 2013 dun try using in replacement of KY.....pls [laugh] will not happen........because I no use KY........ the always very the wet wet................... [:p] Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 26, 2013 Author Share July 26, 2013 idea! but w40 too thick right? mine is w30.....works well.......dont know about w40..........you try lah....... [laugh] Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 26, 2013 Share July 26, 2013 Ok two days back my maid came running to me.............the fan had stopped turning again...........the last time I sprayed some WD40 and it lasted for 2 months............this time ran out of WD40...........so I put afew drops of my balance engine oil............and it started to turn as new.... and so.........idea came to my mind...........I poured some engine oil into a spray container given by NEA (my area now hotspot lor).....and went around spraying on metal joints at home.............better than using WD40..........smooth smooth.... so for those with balance engine oil .............don't throw away............use it as household lubricant and save the money buying WD40........ those who do servicing at WS.........take back the balance of the engine oil......................don't let them sell those balance oil to others.............you paid for the oil after all...............and save some money on that can of WD40........ hope this idea can help make full use of balance engine oil........ [laugh] this is the 30ml bottle from NEA which I use to contain my engine oil spray........... I read from BITOG they use ATF + Acetone for lubricating hinges. This combination allow the oil to penetrate into crevices and acetone will evaporate leaving the ATF for lubricating. I think ATF is thinner than engine oil would be better, apply it using syringe for more precise application. Spray is a bit messy. Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 26, 2013 Author Share July 26, 2013 (edited) I read from BITOG they use ATF + Acetone for lubricating hinges. This combination allow the oil to penetrate into crevices and acetone will evaporate leaving the ATF for lubricating. I think ATF is thinner than engine oil would be better, apply it using syringe for more precise application. Spray is a bit messy. I read they said is 4 times better tha WD40..........but need to go buy and mix acetone............i was just using EO as it is lor.............ATF sld do the job as well I believe.......ATF also lubricant leh.....only thing is it is dye red.......i try the ATF i have at home see how............ [cool] Edited July 26, 2013 by Tianmo Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 26, 2013 Share July 26, 2013 WD40 is basically kerosene Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 26, 2013 Author Share July 26, 2013 WD40 is basically kerosene oh..........learn something today......... ↡ Advertisement Link to post Share on other sites More sharing options...
Households to pay more for waste disposal from July 1
ACG Performance - Official Distributor For Brembo, AirBFT Air Suspensions & GFG Forged Wheels!
Shopee Singapore
Shopee Singapore
Household incomes in S’pore rose in 2022 but inflation has chipped away at growth
SCHNELL Engine Oil 5W40
P2096 Check engine light
