Fuelsaver Supercharged September 8, 2014 Share September 8, 2014 Personally, I'd go for Amaron too. However, some cars are prone to corrosion salt. Using Amaron you tend to have to look out for them. Probably the acid is stronger there. Acid strength depends on manufacturer. Too weak, and it dies off quickly. Too strong, and corrosion accelerates. Nonetheless, those with corrosion salt should attempt to clean them up regularly. You can use hot water to pour over the salt to dissolve them, just make sure not to short circuit the battery by pouring carefully only at one terminal at a time. To reduce formation, you can put high temp grease coating over the terminals. tks bro Kb27, have learnt a lot fr u. Sorry bro, for replying late, as mentioned you could choose not to top up, the lifespan still could match most of the top brand in market. But, it would be best that you do, as by ensuring the plates being floated by battery water do help prolong the lifespan of the battery and Also, it would be safer in preventing explosion caused by low electrolyte level, as you could correct the electrolyte level. You could top up the battery water level just enough to cover the top of the plates, or you could get the workshop that you purchased the battery to help topping up, advisable first check will be on 7th - 8th month for new battery, subsequent will be every 3-4 months, as different cars emission level varies. Thanks... hi GS, instead of topping up w battery water, could we use distilled water instead, as what some bros here have shared? Tks. ↡ Advertisement Link to post Share on other sites More sharing options...
Vinil 1st Gear April 16, 2015 Share April 16, 2015 Hi can i check you have any battery sutitable for Alfa Romeo 159 i am musing 75AH Link to post Share on other sites More sharing options...
Missyoumuch Neutral Newbie January 29, 2016 Share January 29, 2016 Hi GS, is GS Yuasa battery still made in Japan now? how much is it for 58A one for Honda Stream RSZ? Thank you. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear January 30, 2016 Share January 30, 2016 Hi GS, is GS Yuasa battery still made in Japan now? how much is it for 58A one for Honda Stream RSZ? Thank you. yes, it is. give any of the local retailers a call to confirm and find out the actual price. i bought mine from a retailer at Bukit Merah Lane 1. Hi can i check you have any battery sutitable for Alfa Romeo 159 i am musing 75AH he previously mentioned Midac brand "Sigillum" series DIN size battery with capacity from 55Ah to 100Ah. Link to post Share on other sites More sharing options...
Missyoumuch Neutral Newbie January 30, 2016 Share January 30, 2016 Hi bro,thanks for replying.could u share with me how much did u get it and the full address please.is it at 119 level 1?.Thank you. Link to post Share on other sites More sharing options...
GSYuasa Neutral Newbie January 31, 2016 Share January 31, 2016 Hi bro,thanks for replying.could u share with me how much did u get it and the full address please.is it at 119 level 1?.Thank you.Hi bro, paiseh for replying late, the model suitable for your Honda stream is 60B24L, our dealer at Bukit Merah is Tong Hin at blk 119 #01-18-20, 62717976. Thanks Link to post Share on other sites More sharing options...
Missyoumuch Neutral Newbie February 1, 2016 Share February 1, 2016 Thank you for your infor. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear February 1, 2016 Share February 1, 2016 Thank you for your infor. make sure you shut the engine off before allowing the worker to replace the battery or else you run the risk of frying the ecu. Link to post Share on other sites More sharing options...
Missyoumuch Neutral Newbie February 1, 2016 Share February 1, 2016 make sure you shut the engine off before allowing the worker to replace the battery or else you run the risk of frying the ecu. I see, thanks for the advice bro :). Link to post Share on other sites More sharing options...
Missyoumuch Neutral Newbie February 2, 2016 Share February 2, 2016 Hi bro, paiseh for replying late, the model suitable for your Honda stream is 60B24L, our dealer at Bukit Merah is Tong Hin at blk 119 #01-18-20, 62717976. Thanks Went to Tong Hin and replaced the battery as advised by GSYuasa. They asked me to turn on the engine so that the settings will not lost when they change the battery. I asked them regarding the ECU risk but the boss said no problem...anyway, it was a bit of heart stopping but everything is fine eventually. The price is 110$ inclusive of replacement. Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 2, 2016 Share February 2, 2016 Went to Tong Hin and replaced the battery as advised by GSYuasa. They asked me to turn on the engine so that the settings will not lost when they change the battery. I asked them regarding the ECU risk but the boss said no problem...anyway, it was a bit of heart stopping but everything is fine eventually. The price is 110$ inclusive of replacement. unprofessional work. Lazy is the word. simply hook it up to another battery should be the way. 3 Link to post Share on other sites More sharing options...
Kippei 3rd Gear February 2, 2016 Share February 2, 2016 Went to Tong Hin and replaced the battery as advised by GSYuasa. They asked me to turn on the engine so that the settings will not lost when they change the battery. I asked them regarding the ECU risk but the boss said no problem...anyway, it was a bit of heart stopping but everything is fine eventually. The price is 110$ inclusive of replacement. I say i dont care. Just plug out the batteries. I rather lose setting than the entire ECU. 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear February 4, 2016 Share February 4, 2016 it raise a Doubt here when replacing battery A) keep the engine running ( can help retain all the setting)? B)off engine ( most setting will be gone like radio / reverse camera / power windows / ECU ) ? C)back supply like connecting a external battery prior the died battery disconnect ? or anyone got issue adopt the above method or any other way can share? Link to post Share on other sites More sharing options...
Cephas 3rd Gear February 4, 2016 Share February 4, 2016 it raise a Doubt here when replacing battery A) keep the engine running ( can help retain all the setting)? B)off engine ( most setting will be gone like radio / reverse camera / power windows / ECU ) ? C)back supply like connecting a external battery prior the died battery disconnect ? or anyone got issue adopt the above method or any other way can share? © shld be the way to apply Link to post Share on other sites More sharing options...
Furrynadz 5th Gear February 4, 2016 Share February 4, 2016 ecu is a few k replace ecu is one thing it will / might short other modules along the way as well, such as fusebox, electronic parking brakes, immobiliser system..etc Link to post Share on other sites More sharing options...
Blue_Bird 1st Gear April 17, 2016 Share April 17, 2016 Can I check what type of battery skyactiv Mazda 2 is using. What is the price and where is your local dealer address? Link to post Share on other sites More sharing options...
GSYuasa Neutral Newbie April 17, 2016 Share April 17, 2016 Can I check what type of battery skyactiv Mazda 2 is using. What is the price and where is your local dealer address?Hi, for Mazda 2 skyactiv is on Start/Stop feature, the original factory fixed battery is Q85, current you could only get the Japan Made Q85 from Trans Eurokars, you could visit their Ubi or Leng Kee service centre to get the battery replace.. Thanks Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 17, 2016 Share April 17, 2016 Is GS Yuasa happy their dealers are doing this? Changing battery with the engine on. If not please advise your authorised dealers accordingly. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
COE Bidding - March 2024
My EV journey to the i4
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
Battery Voltage up & down
