Arjohn Neutral Newbie January 14, 2014 Share January 14, 2014 Hi Gearosv2, I did not connect to cig charger, just direct from power bank to cam. I have a few powerbank so i exchange and bring home to charge. Yes it is very troublesome, but already use to it. Your suggested way of connection is not a bad idea. However, 2 issues 1)if the power bank become flat, your 1 hr drive will not be able to charge up the powerbank much, 2)I think that recharging the powerbank if it is not flat will degrade the powerbank ( this also depend on the type of material the powerbank is made of). ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Bioinformatics 3rd Gear January 19, 2014 Share January 19, 2014 those USB power bank produce only 5V from the USB but my camera need 12V, how? Any Bro, got answer? 1 Link to post Share on other sites More sharing options...
Solar Turbocharged January 19, 2014 Share January 19, 2014 those USB power bank produce only 5V from the USB but my camera need 12V, how? can try this? http://www.ebay.com/itm/NEW-Portable-Car-Truck-Battery-Charger-Jump-Start-500-Amp-12V-Roadside-Emergency-/291058317552?pt=Motors_Car_Truck_Parts_Accessories&hash=item43c46d78f0 Link to post Share on other sites More sharing options...
Kwchan 1st Gear January 20, 2014 Share January 20, 2014 can try this? http://www.ebay.com/itm/NEW-Portable-Car-Truck-Battery-Charger-Jump-Start-500-Amp-12V-Roadside-Emergency-/291058317552?pt=Motors_Car_Truck_Parts_Accessories&hash=item43c46d78f0 errr...so big, just to power a car cam?? Link to post Share on other sites More sharing options...
Picanto 3rd Gear January 20, 2014 Share January 20, 2014 Will explode? Link to post Share on other sites More sharing options...
Bioinformatics 3rd Gear January 21, 2014 Share January 21, 2014 Another challenge will be the DC jack. I think Itronics is using DC 2.5mm 12V. None of my power bank "jack" can fit. Must go Sim lim tower customize it (USB to 2.5mm jack). A lot of work... Link to post Share on other sites More sharing options...
Solar Turbocharged January 21, 2014 Share January 21, 2014 errr...so big, just to power a car cam?? guarantee won't run out of juice for 24 or more hr surveillance yes.. only issue is the storage. Link to post Share on other sites More sharing options...
Manmaster 2nd Gear January 21, 2014 Share January 21, 2014 I think a 20,000mah powerbank should do a good job and definitely can do a good job. It costs only around $30-$40. Link to post Share on other sites More sharing options...
renhau 3rd Gear February 24, 2014 Share February 24, 2014 Any Bro, got answer? Either you buy 12v po we r bank or using magic pro. Normal power bank wont work. Link to post Share on other sites More sharing options...
Carnoob Supercharged February 24, 2014 Author Share February 24, 2014 I used a 50,000mah power bank on a 5V car cam, works just nice. Thanks for all the bros here. Link to post Share on other sites More sharing options...
Arjohn Neutral Newbie March 30, 2014 Share March 30, 2014 Can share the brand, model, price of the 50000 mah power bank. Can upload a pic. Where to buy? Thanks. Link to post Share on other sites More sharing options...
CarzmeSG Neutral Newbie May 4, 2014 Share May 4, 2014 Actually the car dvr wont eat much power even if connect constant power. If really worry abt draining battery can buy the magic power option or buy dvr with auto cut off function. Powerbank need to be charge fruqently and car driving wont charge enough against the usage. Link to post Share on other sites More sharing options...
user23 Neutral Newbie June 25, 2014 Share June 25, 2014 Hi Gearosv2, I did not connect to cig charger, just direct from power bank to cam. I have a few powerbank so i exchange and bring home to charge. Yes it is very troublesome, but already use to it. Your suggested way of connection is not a bad idea. However, 2 issues 1)if the power bank become flat, your 1 hr drive will not be able to charge up the powerbank much, 2)I think that recharging the powerbank if it is not flat will degrade the powerbank ( this also depend on the type of material the powerbank is made of). Hi Arjohn, Could you please let me know what cable do you use to connect your power bank to the cam (Blackvue DR550GW) ? I'm planning to do the same thing. What is the size of the DC jack ? Link to post Share on other sites More sharing options...
Ahgong Supercharged June 25, 2014 Share June 25, 2014 I used a 50,000mah power bank on a 5V car cam, works just nice. Thanks for all the bros here. what camera is it hooked to? how long before you need to recharge? Link to post Share on other sites More sharing options...
Carnoob Supercharged June 25, 2014 Author Share June 25, 2014 what camera is it hooked to? how long before you need to recharge? My car cam does have motion detection so it's on loop for 5 minutes, it would last 6 hrs. If with motion detection which I had also tried, it will last me 3 days. So buy 2 good enough 1 Link to post Share on other sites More sharing options...
Ahgong Supercharged June 25, 2014 Share June 25, 2014 My car cam does have motion detection so it's on loop for 5 minutes, it would last 6 hrs. If with motion detection which I had also tried, it will last me 3 days. So buy 2 good enough thanks bro. that is a good indicator. time to go source for a 50k mah bank liow Link to post Share on other sites More sharing options...
jirotan Neutral Newbie July 2, 2014 Share July 2, 2014 bought a power bank, but the inputs and output is an issue for me, I want to ask anyone out there how to over come it. The power bank comes with USB heads, but the car camera is with cigarette lighter adapter. how do i get a male cigarette lighter head to a USB input to the power bank and also a USB output head to a female cigarette lighter adapter? Anyone can advice? Link to post Share on other sites More sharing options...
TVT Supercharged July 2, 2014 Share July 2, 2014 bought a power bank, but the inputs and output is an issue for me, I want to ask anyone out there how to over come it. The power bank comes with USB heads, but the car camera is with cigarette lighter adapter. how do i get a male cigarette lighter head to a USB input to the power bank and also a USB output head to a female cigarette lighter adapter? Anyone can advice? Most car cam comes with both a USB cable and a 12V socket head (cigarette adapter). Yours don't have the USD cable ? ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Battery Voltage up & down
Marbella DashCam Users
Car camera recommendation
Request for dark mode
The Electric Vehicle Charging Problem
