Baal Supersonic October 3, 2014 Share October 3, 2014 Just sent my car for 80k svc and the AD workshop mentioned that my air con was dirty even after detoxing it (not sure if this is the correct term but they cleaned it with a can of spray which cost $40+). Mentioned that I shld do a chemical wash which costs $300+ Never heard of car air con doing chemical wash before but have heard of office/house air con doing this. Any bros can advise? Thank you in advance!! I understand that using some sort of bleach (kao) or something can do the same & cost only a few dollars. However must be able to DIY. Or maybe a trusted outside ws to do this. @pisces69 and @kb27 should be able to share more insights. :) ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 7, 2014 Share October 7, 2014 (edited) Just sent my car for 80k svc and the AD workshop mentioned that my air con was dirty even after detoxing it (not sure if this is the correct term but they cleaned it with a can of spray which cost $40+). Mentioned that I shld do a chemical wash which costs $300+ Never heard of car air con doing chemical wash before but have heard of office/house air con doing this. Any bros can advise? Thank you in advance!! Complete AC clean only if yr coil is chocked n badly blocked. Hardly any air come out of the vents n $300 sounds expensive. Sometimes air blocked n very little air come out of vents also cud just need to replace a new AC filter for abt $20. I just buy a $7 can of Dettol spray n remove AC filter. Then put fan at full blast n spray the Dettol under the dash it wil suck into the coil n remove mould n bad smell. I do this abt every year DIY. So far my AC abt 8 yrs still good. Edited October 7, 2014 by Pisces69 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 7, 2014 Share October 7, 2014 Complete AC clean only if yr coil is chocked n badly blocked. Hardly any air come out of the vents n $300 sounds expensive. Sometimes air blocked n very little air come out of vents also cud just need to replace a new AC filter for abt $20. I just buy a $7 can of Dettol spray n remove AC filter. Then put fan at full blast n spray the Dettol under the dash it wil suck into the coil n remove mould n bad smell. I do this abt every year DIY. So far my AC abt 8 yrs still good. u mean leave glove box opened beyond stopper limit n spray dettol into a/c filter removed portion, assuming most makes have a/c filter behind (in front of) glove box? Link to post Share on other sites More sharing options...
Spring Moderator October 7, 2014 Share October 7, 2014 Complete AC clean only if yr coil is chocked n badly blocked. Hardly any air come out of the vents n $300 sounds expensive. Sometimes air blocked n very little air come out of vents also cud just need to replace a new AC filter for abt $20. I just buy a $7 can of Dettol spray n remove AC filter. Then put fan at full blast n spray the Dettol under the dash it wil suck into the coil n remove mould n bad smell. I do this abt every year DIY. So far my AC abt 8 yrs still good. Thks for the advice bro! Mine actually is 4 yrs old n periodically when I go svc at AD, they will actually use a spray to clean my aircon. This time they say even with the spray it still is dirty n suggested a chemical wash which I declined due to the cost n also I wanted to find out more. Guess I'll leave it for now since the aircon is working ok but long run may need to do what u suggested. Thks again! 5 Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 7, 2014 Share October 7, 2014 u mean leave glove box opened beyond stopper limit n spray dettol into a/c filter removed portion, assuming most makes have a/c filter behind (in front of) glove box? My AC filter is below the glove box. I must crawl upside-down in the front passenger footwell to remove the AC filter. Lucky its only about once a year. But this year still never do. Now getting lazy. 1 Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 7, 2014 Share October 7, 2014 Thks for the advice bro! Mine actually is 4 yrs old n periodically when I go svc at AD, they will actually use a spray to clean my aircon. This time they say even with the spray it still is dirty n suggested a chemical wash which I declined due to the cost n also I wanted to find out more. Guess I'll leave it for now since the aircon is working ok but long run may need to do what u suggested. Thks again! No prob. Link to post Share on other sites More sharing options...
Yan66 2nd Gear October 8, 2014 Share October 8, 2014 sometime aircon compressor will automatically shut down when temp reaches certain temp...sometime we assume that the aircon got problem but actually it's not and sometime workshop will tell u cock and bull story..pls ask for 2nd and 3rd opinion from other workshop.. it will supprised u. i kena b4 and all along i tot my aircon got problem (some even b4 looking can confirm compressor faulty)..in the end, it was actually my radiator that was choke that trigger the compressor to stop working... ... 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 8, 2014 Share October 8, 2014 My AC filter is below the glove box. I must crawl upside-down in the front passenger footwell to remove the AC filter. Lucky its only about once a year. But this year still never do. Now getting lazy. ya, somewhere there, but spray dettol where? Link to post Share on other sites More sharing options...
Yan66 2nd Gear October 9, 2014 Share October 9, 2014 ya, somewhere there, but spray dettol where? bro sonax got this product to clean the aircon..just open the cover and let it run along with aircon on...i used it b4 and its quite cool...get rid of those smell.. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 9, 2014 Share October 9, 2014 bro sonax got this product to clean the aircon..just open the cover and let it run along with aircon on...i used it b4 and its quite cool...get rid of those smell.. yes, saw it at caltex, oso saw liquimoly one in marketplace, which is slightly cheaper. only one need ac run for 10 mins, another 15mins. btw, must remove a/c filter first? Link to post Share on other sites More sharing options...
Yan66 2nd Gear October 9, 2014 Share October 9, 2014 yes, saw it at caltex, oso saw liquimoly one in marketplace, which is slightly cheaper. only one need ac run for 10 mins, another 15mins. btw, must remove a/c filter first? no need.... on aircon full blast , put to circulate , close all windows/doors and tab open the lid and let it run for few min (gas will come out ).... make sure u sit outside...hehehe all smell gone..saw some small cockroach also kena knockout worth trying bro Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 9, 2014 Share October 9, 2014 no need.... on aircon full blast , put to circulate , close all windows/doors and tab open the lid and let it run for few min (gas will come out ).... make sure u sit outside...hehehe all smell gone..saw some small cockroach also kena knockout worth trying bro ok tks bro, any gd offer? Link to post Share on other sites More sharing options...
Yan66 2nd Gear October 9, 2014 Share October 9, 2014 ok tks bro, any gd offer? aiyah u abit late lah...sonax was giving 20% few weeks back during their Kansha festival at Motorimage leng kee Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 9, 2014 Share October 9, 2014 ya, somewhere there, but spray dettol where? When u remove the AC filter....There is a rectangle opening for the Filter. Now on fan full blast n spray the Dettol into that hole. U experiment where the AC sucks air into the system(Not all cars is same) to get cooled by the cooling coil. Spray the Dettol there. Most cars wil suck air to b cooled from below the dash at the passenger/driver footwell. Link to post Share on other sites More sharing options...
Divers 2nd Gear October 9, 2014 Share October 9, 2014 (edited) ok tks bro, any gd offer? Autobacs now got promo. $23.90 if Im not wrong. I got it on discount and just try. I tired before. I like the refreshing smell coming from aircon. But smell will be gone after about 2-3 days. I do not know if it really helps or not. But seriously the sour smell from the aircon went off. So far so good. http://www.autobacs.com.sg/pdf.php Every month, I just wait for their update on promo. See if anything catches my eye. I will go. Their products are more pricey. I will only buy when they are on discount. Edited October 9, 2014 by Divers Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 9, 2014 Share October 9, 2014 When u remove the AC filter....There is a rectangle opening for the Filter. Now on fan full blast n spray the Dettol into that hole. U experiment where the AC sucks air into the system(Not all cars is same) to get cooled by the cooling coil. Spray the Dettol there. Most cars wil suck air to b cooled from below the dash at the passenger/driver footwell. tks bro, my oni concern is if any dettol oily residue get into fan or duct any issue so far, or was it formulated to be evaporated ultimately? Autobacs now got promo. $23.90 if Im not wrong. I got it on discount and just try. I tired before. I like the refreshing smell coming from aircon. But smell will be gone after about 2-3 days. I do not know if it really helps or not. But seriously the sour smell from the aircon went off. So far so good. http://www.autobacs.com.sg/pdf.php Every month, I just wait for their update on promo. See if anything catches my eye. I will go. Their products are more pricey. I will only buy when they are on discount. tks for sharing bro. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 9, 2014 Share October 9, 2014 tks bro, my oni concern is if any dettol oily residue get into fan or duct any issue so far, or was it formulated to be evaporated ultimately? tks for sharing bro. Disenfectant spray like Dettol/Lysol dun leave any oily residue. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 9, 2014 Share October 9, 2014 Spray Dettol? Attempt suicide with Dettol spray? Hahahaha. Dun lah. I spray n quickly close all doors n windows n lock the car n leave it overnight or longer. Next day can smell the smell but not so strong. U can open windows n drive a few mins to clear any strong smell. But it leaves a fresh smell for a week or so after that. ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Advice on exhaust.
Advice on exhaust.
