Keithchue 5th Gear February 11, 2014 Share February 11, 2014 Hi Guys, I have a VW with a clicking noise, like a spring being pulled while the steering wheel is being turned. been into VW for the 6th time and was told that this is normal. they have relubed, replace the spring and the noise is still back after 1-2 weeks is this normal? or what could be wrong? ↡ Advertisement Link to post Share on other sites More sharing options...
GLZT 6th Gear February 11, 2014 Share February 11, 2014 Does it sound normal to you? They can only say its common. Not normal. Link to post Share on other sites More sharing options...
Kangadrool Supersonic February 11, 2014 Share February 11, 2014 (edited) Clockspring aka rotary switch kaput liao. Request for replacement if still under warranty, else wait until airbag sign comes up. Edited February 11, 2014 by Kangadrool Link to post Share on other sites More sharing options...
iohu8567 Neutral Newbie February 11, 2014 Share February 11, 2014 I got the same issue here. It's like one end of a spring scratching a piece of plastic while turning the spring kinda sound. Started to appear about 2 weeks ago and it's kinda getting worse. Not sure what's the problem need to service or not. Driving a Toyota Vios 1st gen. Link to post Share on other sites More sharing options...
Laserjet Neutral Newbie February 12, 2014 Share February 12, 2014 You can go to Dynamics Mechanic for help. Can post your problem in their thread too for professional view. http://www.mycarforum.com/forum/123-dynamics-mechanic-pte-ltd/ Link to post Share on other sites More sharing options...
Watwheels Supersonic February 12, 2014 Share February 12, 2014 Hi Guys, I have a VW with a clicking noise, like a spring being pulled while the steering wheel is being turned. been into VW for the 6th time and was told that this is normal. they have relubed, replace the spring and the noise is still back after 1-2 weeks is this normal? or what could be wrong? My car although not vw but had this sound before. Did a steering fluid flush and it was gone. Check your steering fluid. It should be red in colour, if turned black it's time for a change. Link to post Share on other sites More sharing options...
Crashburner 3rd Gear February 12, 2014 Share February 12, 2014 Did you feel as though you losing control of the steering wheel when going over a hump and even if stationery, when u do a slight turn left or right of the steering, u hear the sound? If yes, better get a 2nd opinion to check. I recently encountered it and after checking with 2 mechanics, i was informed that the bar holding the wheel axis had broken or to that extend. Had to replace it. But my car was 8 years old already Link to post Share on other sites More sharing options...
Keithchue 5th Gear February 12, 2014 Author Share February 12, 2014 (edited) Does it sound normal to you? They can only say its common. Not normal. nope, cos when I collect the car, it is not there.... only surface about 9 months of ownership. Clockspring aka rotary switch kaput liao. Request for replacement if still under warranty, else wait until airbag sign comes up. I or they have change the clock spring 5 times liao...is clock spring called a slip ring as well? this time round, tell me the slip ring is generating the noise and it is normal.... kaoz...what can I do. car still under warranty.... Did you feel as though you losing control of the steering wheel when going over a hump and even if stationery, when u do a slight turn left or right of the steering, u hear the sound? If yes, better get a 2nd opinion to check. I recently encountered it and after checking with 2 mechanics, i was informed that the bar holding the wheel axis had broken or to that extend. Had to replace it. But my car was 8 years old already nope. car is in control all the time. My car although not vw but had this sound before. Did a steering fluid flush and it was gone. Check your steering fluid. It should be red in colour, if turned black it's time for a change. don't think it is hydraulic PS. mine is electric PS. hmm...don't know what is wrong?? Edited February 12, 2014 by Keithchue Link to post Share on other sites More sharing options...
Slayer666 Neutral Newbie July 2, 2017 Share July 2, 2017 Hi Guys, I have a VW with a clicking noise, like a spring being pulled while the steering wheel is being turned. been into VW for the 6th time and was told that this is normal. they have relubed, replace the spring and the noise is still back after 1-2 weeks is this normal? or what could be wrong? Hey keithchue, This is an old thread, I'm just curious if u ever managed to get the clicking noise resolved? I have the same intermittent clicks when turning at slow speeds. Noise coming from steering column below dashboard. VW as well. Link to post Share on other sites More sharing options...
Keen 1st Gear July 10, 2017 Share July 10, 2017 Did you feel as though you losing control of the steering wheel when going over a hump and even if stationery, when u do a slight turn left or right of the steering, u hear the sound? If yes, better get a 2nd opinion to check. I recently encountered it and after checking with 2 mechanics, i was informed that the bar holding the wheel axis had broken or to that extend. Had to replace it. But my car was 8 years old alreadyHi Crashburner, Just to check. Do you have any idea what's the parts that you change? Because I got exactly the same issue and so far 3-4 workshop can't diagnose it Link to post Share on other sites More sharing options...
Slayer666 Neutral Newbie September 23, 2018 Share September 23, 2018 Hi Crashburner, Just to check. Do you have any idea what's the parts that you change? Because I got exactly the same issue and so far 3-4 workshop can't diagnose it Hello Keen, Is Yours a VW too? A golf MK 7? Did you manage to get the issue resolved? Dealer changed clock spring, steering wheel, airbag, steering column. After 2 months, the noise came back again. VW says it is a normal operational noise to a certain tolerance. But its too irritating. And my tolerance is low. lol Please share your thoughts. Much appreciated. Feels like getting rid of the car for a KIA. So disappointed in the so-called German engineering. ↡ Advertisement Link to post Share on other sites More sharing options...
Xpeng is Coming to Town
Steering leather wrapping
Volkswagen Sharan..
Volkswagen Sharan..
2011 VW New beetle
2011 VW New beetle
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
2021 8th Generation VW Golf
