Zippaboy 4th Gear August 23, 2014 Share August 23, 2014 Only hear people say top up the fluid..Brake fluid and ATF, differential oil, coolant , engine, even aircon you hear of people flushing the system. ↡ Advertisement Link to post Share on other sites More sharing options...
QQDreamer 4th Gear August 23, 2014 Share August 23, 2014 yes i always did it once yearly to drain out the oil and replace with new oil for brake and power steering oil. Link to post Share on other sites More sharing options...
Watwheels Supersonic August 23, 2014 Share August 23, 2014 It's supposedly red in colour. If it turns black it's time to flush & replaced. This will become a thing of the past soon as new cars are electric assisted steering. No steering fluid or any fluid in the system. Link to post Share on other sites More sharing options...
13177 Supersonic August 23, 2014 Share August 23, 2014 What will happen if dont change? Link to post Share on other sites More sharing options...
Aaronlkl Supersonic August 23, 2014 Share August 23, 2014 (edited) Power steering fluid need not change. If unsure, Check your owners manual. Edited August 23, 2014 by Aaronlkl 5 Link to post Share on other sites More sharing options...
Watwheels Supersonic August 23, 2014 Share August 23, 2014 Over time when the hydraulic fluid become oxidized or moisture is present in the system it becomes less effective. The properties of water is different from the hydraulic fluid. Or else engineers can just use water why use hydraulic fluid? Becoz the fluid's properties have changed it will also put a strain on the system and the pump. Same goes for the brake fluid. 3-4years do a flush to these 2 systems is good enough. It's not costly or require any big effort. 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic August 23, 2014 Share August 23, 2014 (edited) What will happen if dont change? Nothing will happen! I have never changed (just top up when needed only) steering fluid (which is same as transmission fluid) or engine coolant in more than 20 yrs of car ownership. In fact most manufacturers would not want you to touch the transmission fluid at all. Brake fluid - good to flush once every few years. Edited August 23, 2014 by Volvobrick 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 23, 2014 Share August 23, 2014 In a new car chances are the Power Steering fluid is made of mineral oil. So its a good idea to drain and flush at 20k km and fill with fully synthetic fluid. And this should be good for another 100k before needing to change again. 7 Link to post Share on other sites More sharing options...
Gnahp Supercharged August 26, 2014 Share August 26, 2014 What will happen if dont change? Nothing will happen. My last car clocked 270,000km / 7.5 years, never change, no top up as the oil level didn't drop at all, no leak nothing. It is a close hydraulic system with no external contamination, hydraulic fluid is not hygroscopic like brake fluid. don't disturb it unless it is leaking. Anyway, If it made the car owner feel good and secure after changing the fluid, it probably worth the money spent. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 26, 2014 Share August 26, 2014 Only hear people say top up the fluid.. Brake fluid and ATF, differential oil, coolant , engine, even aircon you hear of people flushing the system. OK most cars PS fluid is also ATF so it does wear out after time. When it loses its lubricating ability n additives r gone it wil cause more wear to your PS pump n also steering rack. The rubber seals wil harden n leak which wil need costly repairs. I flush n replace my PS fluid after abt 4-5 years(abt 70K km). U can do it every 2-3 yeqars if u wan. I put 1 bottle(abt 1 lit ) of PS fluid with stop leak cos it has stronger additives to protect the PS system. I then top-up with ATF as recommended in the handbook. If u loaded, then u can use PS fluid for a 100% filling. While top-up, turn yr steering (engine on) full lock left then right a few times to bleed out all the air from the system. 2 Link to post Share on other sites More sharing options...
Zippaboy 4th Gear September 15, 2014 Author Share September 15, 2014 OK most cars PS fluid is also ATF so it does wear out after time. When it loses its lubricating ability n additives r gone it wil cause more wear to your PS pump n also steering rack. The rubber seals wil harden n leak which wil need costly repairs. I flush n replace my PS fluid after abt 4-5 years(abt 70K km). U can do it every 2-3 yeqars if u wan. I put 1 bottle(abt 1 lit ) of PS fluid with stop leak cos it has stronger additives to protect the PS system. I then top-up with ATF as recommended in the handbook. If u loaded, then u can use PS fluid for a 100% filling. While top-up, turn yr steering (engine on) full lock left then right a few times to bleed out all the air from the system. great info !!!! i see my steering fluid, it is no longer ATF-red. abit brownish already after 4 years. should be time.... ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
Looking for Job in automotive sector, need advise
In need of vehicle history software
Syria Quake
Syria Quake
