Kippei 3rd Gear November 12, 2014 Share November 12, 2014 http://detail.tmall.com/item.htm?spm=a230r.1.14.49.RiOB9a&id=41207810416&abbucket=11 i ordered this ↡ Advertisement Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 12, 2014 Share November 12, 2014 most sensible suggestion. Just unplug your battery and leave only this jump starter connected... Link to post Share on other sites More sharing options...
Kb27 Supersonic November 12, 2014 Author Share November 12, 2014 Just got my Powerall, it comes with car AC adapter and wall plug adapter (DC), i thought it can only be charged using AC, so can i use my wall plug to charge safely? Just wanna make sure. Yes, you can use on AC. I charged mine all the time on AC. However, do check the unit have the label printed INPUT: 100~240AC. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear November 12, 2014 Share November 12, 2014 Just got my Powerall, it comes with car AC adapter and wall plug adapter (DC), i thought it can only be charged using AC, so can i use my wall plug to charge safely? Just wanna make sure. wall plug should be AC instead. does the adapter state something like 100-240V 50-60Hz for input? Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 13, 2014 Share November 13, 2014 got it. Looks solid. so far it works except the jump start part. Will expect to use it soon as car batt dying and going holiday soon and when return, I think batt si liao and can try it. Will update when I use it. aiya.....disconnect batt and try straight away. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear November 13, 2014 Share November 13, 2014 i read that it is not advisable to disconnect the battery when the engine is running. a battery functions as a voltage stabilizer. think most of us agree on this. so is it safe to disconnect the battery and start the engine using the jumpstart kit in order to test its capability? Link to post Share on other sites More sharing options...
Gkhb1010 1st Gear November 13, 2014 Share November 13, 2014 http://detail.tmall.com/item.htm?spm=a230r.1.14.49.RiOB9a&id=41207810416&abbucket=11 i ordered this How much was this in Sing $? they deliver to Singapore? Looks solid Link to post Share on other sites More sharing options...
Solar Turbocharged November 13, 2014 Share November 13, 2014 aiya.....disconnect batt and try straight away. one thing.. once u disconnect, all the preset settings would be gone right? the other time AA replaced battery for me the guy actually connected it up to another one so there will be a constant flow of electricity to the car. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 13, 2014 Share November 13, 2014 one thing.. once u disconnect, all the preset settings would be gone right? the other time AA replaced battery for me the guy actually connected it up to another one so there will be a constant flow of electricity to the car. radio settings or ecu settings? dont think ecu setting can be erased that easily. Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 13, 2014 Share November 13, 2014 (edited) one thing.. once u disconnect, all the preset settings would be gone right? the other time AA replaced battery for me the guy actually connected it up to another one so there will be a constant flow of electricity to the car. Here is a simple memory saver using 9volt alkaline battery radio settings or ecu settings? dont think ecu setting can be erased that easily. Only European vehicles ( & some top end Japanese cars ), the radio, door lock setting and ECU collected data will be erase once you disconnected the battery. For Bread and Butter Asian cars normally the radio and clock settings will go . Latest memory saver for European cars , the unit is plug directly into the OBD2 16pins socket. Edited November 13, 2014 by Yeobh Link to post Share on other sites More sharing options...
Jtb 6th Gear November 13, 2014 Share November 13, 2014 curious to know how often jump start your car. mostly around 18months or below your cold start will always give you a symptom, this is the time to change the battery. by then you hv one and wtd to jump start, bty is flat then how? usually we are not prepare and bty is always not at full charge or standby. Full charge for standby also will be drained off eventually. 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 13, 2014 Share November 13, 2014 think more useful for those who go frequently for road trips, especially when you are off the beaten tracks and birds don't lay eggs areas. curious to know how often jump start your car. mostly around 18months or below your cold start will always give you a symptom, this is the time to change the battery. by then you hv one and wtd to jump start, bty is flat then how? usually we are not prepare and bty is always not at full charge or standby. Full charge for standby also will be drained off eventually. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 13, 2014 Share November 13, 2014 How much was this in Sing $? they deliver to Singapore? Looks solid same i bought this also but mine is yellow in color. the unit is exactly same. Link to post Share on other sites More sharing options...
Kippei 3rd Gear November 13, 2014 Share November 13, 2014 How much was this in Sing $? they deliver to Singapore? Looks solid I use agent to order + shipping and having sales that time $60 Link to post Share on other sites More sharing options...
Gkhb1010 1st Gear November 19, 2014 Share November 19, 2014 Please feedback after goody arrived from alldeals. Look like value for money. Just used it yesterday, purposely left light on. I intended to change batt yesterday anyway. Worked well. Very happy with it. So this China product Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 19, 2014 Share November 19, 2014 Just used it yesterday, purposely left light on. I intended to change batt yesterday anyway. Worked well. Very happy with it. So this China product thanks for review. Btw, its that US$79? Link to post Share on other sites More sharing options...
Gkhb1010 1st Gear November 19, 2014 Share November 19, 2014 thanks for review. Btw, its that US$79? Hahaha nope. Singapore dollars Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 19, 2014 Share November 19, 2014 Hahaha nope. Singapore dollars all the better... ↡ Advertisement Link to post Share on other sites More sharing options...
70mai vs BASEUS Car Jump Starter
Can you jump start a car with an EV?
疑情海翻波 青年坠楼重伤
疑情海翻波 青年坠楼重伤
[Review] 1000 Peak Amp Jump Starter
Would you pay $15 to jump start your car ...??
Starter Motor Re-conditioning
Starter motor faulty
