Ronleech 2nd Gear December 5, 2014 Share December 5, 2014 Discovered last few week. oil drip on exhaust joint. Changed seals of crank, sump and side cover. Still got little trace of drip. Car left 9mths to go. Will it catch fire when i am driving long distance ie to genting/KL? my friend advice is just to keep a liter of EO in the car and is necessary top up. And also when car is parked overnite, when accelerating got a very fine squeeking sound, but after 5 mins of driving it went off totally. Only when accelerating...wat is that? My main concern is will it catch fire...safety come 1st mah. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 5, 2014 Share December 5, 2014 Discovered last few week. oil drip on exhaust joint. Changed seals of crank, sump and side cover. Still got little trace of drip. Car left 9mths to go. Will it catch fire when i am driving long distance ie to genting/KL? my friend advice is just to keep a liter of EO in the car and is necessary top up. And also when car is parked overnite, when accelerating got a very fine squeeking sound, but after 5 mins of driving it went off totally. Only when accelerating...wat is that? My main concern is will it catch fire...safety come 1st mah. Engine oil escaping via the exhaust gas is an indication that your car piston oil scrapping ring ( maybe one or more pistons) is not scrapping the cylinder walls excess oil and allowing them to drip into the sump. Your mech maybe shooting in the wrong direction - Changing Crankshaft end seal and etc . The other possibility is yr positive crankcase valve / system is mulfuctioning - but I will rule out this as yr car engine is running ok and not erratically. Engine oil discharging via exhaust pipe is not healthy for the cat in the long run. Hope this helps 1 Link to post Share on other sites More sharing options...
Ronleech 2nd Gear December 5, 2014 Author Share December 5, 2014 Engine oil escaping via the exhaust gas is an indication that your car piston oil scrapping ring ( maybe one or more pistons) is not scrapping the cylinder walls excess oil and allowing them to drip into the sump. Your mech maybe shooting in the wrong direction - Changing Crankshaft end seal and etc . The other possibility is yr positive crankcase valve / system is mulfuctioning - but I will rule out this as yr car engine is running ok and not erratically. Engine oil discharging via exhaust pipe is not healthy for the cat in the long run. Hope this help Thanks bro....but the drip seems to be from the corner of the oil pan which is directly on the exhaust joint as it looks wet. Wonder what is the cause.... btw, what is the range of flash point for EO? Under such situation, will be cause fire for long distance driving? Link to post Share on other sites More sharing options...
KR81 4th Gear December 5, 2014 Share December 5, 2014 Here's the flash point for Mobil 1 0W-40, guess other EO should be around this range Typical Properties Mobil 1 0W-40 Value Viscosity, cSt (ASTM D445) @ 40º C 75 @ 100º C 13.5 Viscosity Index 185 MRV at -40ºC, cP (ASTM D4684) 31,000 HTHS Viscosity, mPa•s @ 150ºC, (ASTM D4683) 3.8 Total Base Number (ASTM D2896) 11.8 Sulfated Ash, wt% (ASTM D874) 1.3 Phosphorous, wt% (ASTM D4981) 0.1 Flash Point, ºC (ASTM D92) 230 Density @15.6 ºC, g/ml (ASTM D4052) 0.85 http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-40.aspx Thanks bro....but the drip seems to be from the corner of the oil pan which is directly on the exhaust joint as it looks wet. Wonder what is the cause.... btw, what is the range of flash point for EO? Under such situation, will be cause fire for long distance driving? 1 Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 5, 2014 Share December 5, 2014 Thanks bro....but the drip seems to be from the corner of the oil pan which is directly on the exhaust joint as it looks wet. Wonder what is the cause.... btw, what is the range of flash point for EO? Under such situation, will be cause fire for long distance driving? If from oil pan , and not end of crankshaft that means either the oil pan gasket is leaking oo yr crankcase sump has higher than necessary back pressure in the system dueo to high piston ring blow-by or the positive crankacse valve is not functioning Link to post Share on other sites More sharing options...
Ronleech 2nd Gear December 5, 2014 Author Share December 5, 2014 If from oil pan , and not end of crankshaft that means either the oil pan gasket is leaking oo yr crankcase sump has higher than necessary back pressure in the system dueo to high piston ring blow-by or the positive crankacse valve is not functioning Crankcase valve not functioning? what effect will it shown? Sump have been redone together with seal of crank recently. Crank is clean no leak from top. Can see some trace of oil from a screw below sump which is directly on top of exhaust joint. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 5, 2014 Share December 5, 2014 Crankcase valve not functioning? what effect will it shown? Sump have been redone together with seal of crank recently. Crank is clean no leak from top. Can see some trace of oil from a screw below sump which is directly on top of exhaust joint. Pressure inside the crankcase is normally 0.5 atm higher than outside to prevent dirt from being suck into the sysem. Higher pressure is caused by piston rings poor sealing and therefore allowing too much combustion gases to leak into the system and this gases must be relieve via the positive crankcase valve if not it will force the seals to get out. Very sorry, the subject is getting top technical and need few hours to go into the basic and working details of the system and components and not to mentioned the method and specialty tools required to carry out all the tests. 2 Link to post Share on other sites More sharing options...
Ronleech 2nd Gear December 5, 2014 Author Share December 5, 2014 Pressure inside the crankcase is normally 0.5 atm higher than outside to prevent dirt from being suck into the sysem. Higher pressure is caused by piston rings poor sealing and therefore allowing too much combustion gases to leak into the system and this gases must be relieve via the positive crankcase valve if not it will force the seals to get out. Very sorry, the subject is getting top technical and need few hours to go into the basic and working details of the system and components and not to mentioned the method and specialty tools required to carry out all the tests. Chim indeed....but what will be the ill effect? Pressure gets too high and causing seal to leak that is all? Link to post Share on other sites More sharing options...
nazerath Turbocharged December 5, 2014 Share December 5, 2014 Engine oil escaping via the exhaust gas is an indication that your car piston oil scrapping ring ( maybe one or more pistons) is not scrapping the cylinder walls excess oil and allowing them to drip into the sump. Your mech maybe shooting in the wrong direction - Changing Crankshaft end seal and etc . The other possibility is yr positive crankcase valve / system is mulfuctioning - but I will rule out this as yr car engine is running ok and not erratically. Engine oil discharging via exhaust pipe is not healthy for the cat in the long run. Hope this helps Out of curiosity, does the pcv depend on the intake to draw gas or the pressure from the crankcase alone is enough to expel the air? 12 Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 5, 2014 Share December 5, 2014 Chim indeed....but what will be the ill effect? Pressure gets too high and causing seal to leak that is all? Yes leakage Link to post Share on other sites More sharing options...
Ronleech 2nd Gear December 5, 2014 Author Share December 5, 2014 Yes leakage Ok bro...thanks for the information. So long for the next few month i check regularly for my EO and top up when necessary is ok rite? I only worry it dripped onto the exhaust joint and if travelling in long distance will cause fire.... Link to post Share on other sites More sharing options...
Kb27 Supersonic December 5, 2014 Share December 5, 2014 Out of curiosity, does the pcv depend on the intake to draw gas or the pressure from the crankcase alone is enough to expel the air? PCV is the crankcase way of relieving pressure and expelling used combustion gases back into the engine to be reburn. If the valve is blocked, bad things happen, pressure is not relieved. It finds other way through weakened gaskets, etc. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 5, 2014 Share December 5, 2014 Out of curiosity, does the pcv depend on the intake to draw gas or the pressure from the crankcase alone is enough to expel the air? Basically it's a one-way check valve spring loaded. Once the crankcase blow by pressure is higer than the calibrated sprint setting , the gases will flow out into the intake manifold so that they can be burnt again in the combustion chambers. Link to post Share on other sites More sharing options...
Matrix0405 5th Gear December 5, 2014 Share December 5, 2014 Here's the flash point for Mobil 1 0W-40, guess other EO should be around this range Typical Properties Mobil 1 0W-40 Value Viscosity, cSt (ASTM D445) @ 40º C 75 @ 100º C 13.5 Viscosity Index 185 MRV at -40ºC, cP (ASTM D4684) 31,000 HTHS Viscosity, mPa•s @ 150ºC, (ASTM D4683) 3.8 Total Base Number (ASTM D2896) 11.8 Sulfated Ash, wt% (ASTM D874) 1.3 Phosphorous, wt% (ASTM D4981) 0.1 Flash Point, ºC (ASTM D92) 230 Density @15.6 ºC, g/ml (ASTM D4052) 0.85 http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-40.aspx At what temp will EO ignite? Flash pt = ignite and start to burn on itself. What is the temp in a typical engine during combustion? Link to post Share on other sites More sharing options...
Ronleech 2nd Gear December 5, 2014 Author Share December 5, 2014 OK...the big question now is will it caused fire when driving long distance? Link to post Share on other sites More sharing options...
KR81 4th Gear December 5, 2014 Share December 5, 2014 Around 90-100°C At what temp will EO ignite? Flash pt = ignite and start to burn on itself. What is the temp in a typical engine during combustion? Link to post Share on other sites More sharing options...
Kb27 Supersonic December 5, 2014 Share December 5, 2014 OK...the big question now is will it caused fire when driving long distance? It's highly unlikely. It's not about long distance which is usually cruising speed at a much lower temp than compared with racing on a circuit with high rev all the time. 1 Link to post Share on other sites More sharing options...
Ronleech 2nd Gear December 5, 2014 Author Share December 5, 2014 wonder will my EO be able to last me to and fro genting before it will be totally drained out...lol...anyway will bring along 1+ liters for standby.... ↡ Advertisement Link to post Share on other sites More sharing options...
Kia EV9 Concept
Kia EV9 Concept
2025 Kia K4 (Replacement of Cerato)
KIA K3 Owners check-in!
Kia Stonic
Kia Stonic
Kia K5
Kia K5
New Kia Niro Hybrid
New Kia Niro Hybrid
