Advancer 434 3rd Gear February 22, 2015 Hi one of my car tire cannot be charged, suspect the charging valve is stuck.What should I do? Can the valve be replaced or must I change tire? ↡ Advertisement Share this post Link to post Share on other sites
Thaiyotakamli 51,254 Supersonic February 22, 2015 Tyre cannot charge one They only can be pumped. 5 Share this post Link to post Share on other sites
Shibadog 7,665 Turbocharged February 22, 2015 Hi one of my car tire cannot be charged, suspect the charging valve is stuck. What should I do? Can the valve be replaced or must I change tire? valve can be changed. 2 Share this post Link to post Share on other sites
Wolfy3769 125 2nd Gear February 22, 2015 go to a tire shop to resolve... maybe need to change the valve... this is safer.. any problem, the tire shop will be able to resolve... rather than u do it in a carpark and end with a flat tire.. 2 Share this post Link to post Share on other sites
Advancer 434 3rd Gear February 22, 2015 Would it be expensive just to change the valve? Changing car in 2 weeks, don't wanna spend too much money on this old car. 1 Share this post Link to post Share on other sites
Fitvip 17,274 Turbocharged February 22, 2015 Would it be expensive just to change the valve? Changing car in 2 weeks, don't wanna spend too much money on this old car. I see you are very kancheong! Opening 2 threads! I paid $10 for the valve recently! 1 Share this post Link to post Share on other sites
Advancer 434 3rd Gear February 22, 2015 I see you are very kancheong! Opening 2 threads! I paid $10 for the valve recently! Yes paiseh. Was afraid either forum is inactive. Thanks for the response, will visit a tire shop later. Share this post Link to post Share on other sites
Yeobh 598 4th Gear February 22, 2015 Hi one of my car tire cannot be charged, suspect the charging valve is stuck. What should I do? Can the valve be replaced or must I change tire? The one-way check valve that is screwed into the tubless valve stem may have a fault or sized spring due to water or dirts. The check valve can be easily removed with s simple 4 way tyre tool. 1 Share this post Link to post Share on other sites
Fitvip 17,274 Turbocharged February 22, 2015 Yes paiseh. Was afraid either forum is inactive. Thanks for the response, will visit a tire shop later. No problem. Hope you can resolve your problem soon. Share this post Link to post Share on other sites
lausai88 77,607 Hypersonic February 22, 2015 Tyre cannot charge one They only can be pumped. lol Share this post Link to post Share on other sites
Eyke 6,869 Supercharged February 22, 2015 Tyre cannot charge one They only can be pumped. Tyre cannot pump one. They only can be inflated. 5 Share this post Link to post Share on other sites
Pocus 13,719 Turbocharged February 22, 2015 Valves are cheap, around 10+ don't worry. Share this post Link to post Share on other sites
Forte3737 1,873 5th Gear February 22, 2015 Hi one of my car tire cannot be charged, suspect the charging valve is stuck. What should I do? Can the valve be replaced or must I change tire? Your English standard until primary 6 is it? 2 Share this post Link to post Share on other sites
Advancer 434 3rd Gear February 22, 2015 (edited) Your English standard until primary 6 is it?Hi is it necessary to make fun of people like this?I am using charging because I use the term at my work when we charge the aircraft tire. I don't think its wrong. You can go read up the dictionary, charge can also mean to fill(air, water, etc). Edited February 22, 2015 by Advancer 7 Share this post Link to post Share on other sites
lausai88 77,607 Hypersonic February 22, 2015 Hi is it necessary to make fun of people like this? I am using charging because I use the term at my work when we charge the aircraft tire. I don't think its wrong. this is just a forum, take it easy man. Just ignore the comments. Happy CNY 5 Share this post Link to post Share on other sites
Forte3737 1,873 5th Gear February 22, 2015 Sure. Hi is it necessary to make fun of people like this?I am using charging because I use the term at my work when we charge the aircraft tire. I don't think its wrong.You can go read up the dictionary, charge can also mean to fill(air, water, etc). Share this post Link to post Share on other sites
Thaiyotakamli 51,254 Supersonic February 22, 2015 (edited) Hi is it necessary to make fun of people like this? I am using charging because I use the term at my work when we charge the aircraft tire. I don't think its wrong. You can go read up the dictionary, charge can also mean to fill(air, water, etc). Not make fun but trying to let you know for car tyre, we normally call it pump or inflate tyre. No offense, happy CNY Edited February 22, 2015 by Thaiyotakamli Share this post Link to post Share on other sites
Yeobh 598 4th Gear February 22, 2015 (edited) Valves are cheap, around 10+ don't worry. The tubless stem and valve is dirt cheap, the cost of s$10.00 is more for labour in removing the wheel from the car and removing the tyre from the rim using a tyre changing machine. If they use this simple tyre valve tool they could easily make much more profit from labour time saving. Edited February 22, 2015 by Yeobh ↡ Advertisement Share this post Link to post Share on other sites
