Mustank Hypersonic October 14, 2019 Share October 14, 2019 But Home Depot a lot cheaper! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 14, 2019 Share October 14, 2019 (edited) 1 hour ago, Mustank said: this type no point using bleach dont bother with any chemical all no use one. There is no easy way to deal with these type of stains. Only way is either (drill + brush attachment) or green scrub if you have a Battery powered hand held drill the easier: can use this: 12pcs Electric Drill Brush Scrub Pads Grout Power Drills Scrubber Cleaner https://s.lazada.sg/s.hdA4 trick is to spray water on the wall first, then use the drill + brush. Start with the lower wall. That’s the hardest to do. Then work your way up the wall. Last then is the floor which is the easiest. Scrub one section, use water to spray one section. Prepare to spend one hour. Usually your battery won’t last very Long one so you probably have to spilt up the work Don’t bother with the power jet spray. These type just use drill brush if you don’t have drill brush, then you need new green scrub. Same method. Water, scrub, water. Very siong one. but once you do once nice nice one. Then every week maintenance is not so siong. Those very week maintenance can use power spray but the best maintenance trick is this: everytime bath finish, use the shower head to spray cold water on the wall to flush down any soap. 10 seconds job but save one hell of a work Ah ha ok, I just bought the slim brown bottle cleaner you recommended earlier. 2 bottles for $2.60 at NTUC. Tonight try a bit on my bathroom wall tiles and glass shower screen see can work or not. Also, I wonder if sandpaper is a better substitute for the green scrub? Edited October 14, 2019 by Beehive3783 Link to post Share on other sites More sharing options...
BanCoe Hypersonic October 14, 2019 Share October 14, 2019 (edited) 2 hours ago, Volvobrick said: Update us when you start seeing your birds doing this: this video look like the parrot having a good time flossing its tooth or using FOC toothpicks 🤣🤣 No need to visit dentist; Parrot : HaT trick Human 0 Edited October 14, 2019 by BanCoe 1 3 Link to post Share on other sites More sharing options...
Playtime Twincharged October 14, 2019 Share October 14, 2019 2 hours ago, Volvobrick said: Update us when you start seeing your birds doing this: They have evolved ... 😂 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic October 14, 2019 Share October 14, 2019 1 hour ago, Beehive3783 said: Ah ha ok, I just bought the slim brown bottle cleaner you recommended earlier. 2 bottles for $2.60 at NTUC. Tonight try a bit on my bathroom wall tiles and glass shower screen see can work or not. Also, I wonder if sandpaper is a better substitute for the green scrub? NO NO NO!!!! DONT use the brown bottle on tiles!!! Link to post Share on other sites More sharing options...
Mustank Hypersonic October 14, 2019 Share October 14, 2019 your tiles will be destroyed!! you go scrub or you go buy the Bar keeper friend the brown bottle can only use on concrete 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic October 14, 2019 Share October 14, 2019 You use the brown bottle you will regret 100% 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 14, 2019 Share October 14, 2019 3 minutes ago, Mustank said: your tiles will be destroyed!! you go scrub or you go buy the Bar keeper friend the brown bottle can only use on concrete My bathroom wall tiles are those old style white glossy type stock from HDB prefab, cannot use ah? The label says can use on mosaic flooring, brick wall, porcelain tiles, toilet bowl and sides of drains. I not sure what type my wall tiles are lol. But it's ok, if really can't use on the wall tiles, then i use for toilet bowl lor. lol Link to post Share on other sites More sharing options...
Mustank Hypersonic October 14, 2019 Share October 14, 2019 15 minutes ago, Beehive3783 said: My bathroom wall tiles are those old style white glossy type stock from HDB prefab, cannot use ah? The label says can use on mosaic flooring, brick wall, porcelain tiles, toilet bowl and sides of drains. I not sure what type my wall tiles are lol. But it's ok, if really can't use on the wall tiles, then i use for toilet bowl lor. lol Don’t go and use lah this one destroy tiles one it is so strong can eat into dried bird shit and still got spare power to eat into the concrete you use on tiles, the protective layer on the ceramic tiles will be eaten. Then your tiles will forever black black toilet bowl I don’t know lah Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 15, 2019 Share October 15, 2019 On 10/14/2019 at 2:29 PM, Mustank said: Don’t go and use lah this one destroy tiles one it is so strong can eat into dried bird shit and still got spare power to eat into the concrete you use on tiles, the protective layer on the ceramic tiles will be eaten. Then your tiles will forever black black toilet bowl I don’t know lah Mr DIY indeed 😁 2 Link to post Share on other sites More sharing options...
Mustank Hypersonic October 15, 2019 Share October 15, 2019 34 minutes ago, Fcw75 said: Mr DIY indeed 😁 Times are hard need to diy more often these days 1 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic October 15, 2019 Share October 15, 2019 So whose going to start the fire when the birds are ready? I bring beer!!! 1 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic October 15, 2019 Share October 15, 2019 We didn’t start the fire Link to post Share on other sites More sharing options...
Tianmo Hypersonic October 15, 2019 Share October 15, 2019 11 minutes ago, Mustank said: We didn’t start the fire No start fire how to bbq the birds? 1 1 Link to post Share on other sites More sharing options...
Aloe111 5th Gear October 15, 2019 Share October 15, 2019 烧鸽 1 2 Link to post Share on other sites More sharing options...
Mkl22 Twincharged October 15, 2019 Share October 15, 2019 Don’t worry about killing pigeons. The statutes regard them as flying rats! Cant stand them. 3 Link to post Share on other sites More sharing options...
Tianmo Hypersonic October 15, 2019 Share October 15, 2019 35 minutes ago, Aloe111 said: 烧鸽 油炸,红烧, i think no body will object also, but I think 碳烤 not bad, sld go well with some cool beer... 2 Link to post Share on other sites More sharing options...
Tianmo Hypersonic October 15, 2019 Share October 15, 2019 4 minutes ago, Mkl22 said: Don’t worry about killing pigeons. The statutes regard them as flying rats! Cant stand them. you start the fire, I bring the beer!!! Ok guys, put place put time... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Help with STA report remarks
MOM help FTs look for jobs ?
MyResponder app to call SCDF
