Tennis_ball Clutched May 7, 2015 Share May 7, 2015 hi, have a problem today. hope you guys know what it is. kia forte 1.6sx of 5 years and 4 months old, 77Kkm mileage. Today the car jerks at idle at red light, and i can see that RPM slight jumps up and down, like 400rpm - 700rpm. Usually it is idle at 400rpm without up and down. The jerk is about every 4 seconds, not constant jerking. can feel the car tremble. When i press the throttle to accelerate during travelling, the car will jerk again, and does not accelerate instantly as normal. after a while it accelerates to a higher cruising speed, then it's OK again. During jerking, the engine light flashes like 10 times. when the jerk stops, engine light becomes off again. I just changed engine oil and engine filter 2 months ago. Is this worn spark plugs, or ATF due to change (coz it's been a while), or both, or something else? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Kippei 3rd Gear May 7, 2015 Share May 7, 2015 scan for code first will be the fastest Link to post Share on other sites More sharing options...
Vinceng Turbocharged May 7, 2015 Share May 7, 2015 Could possibly be due to spark plugs or high tension cable needs to be replaced. 1 Link to post Share on other sites More sharing options...
Volvobrick Supersonic May 7, 2015 Share May 7, 2015 yes, plugs/ignition coil/cable should be checked first... A OBD scan should pin point the exact problem. Buy one from here and download a smartphone apps: http://deals.dx.com/team.php?id=13506 1 Link to post Share on other sites More sharing options...
flashbang Turbocharged May 8, 2015 Share May 8, 2015 I'm not very experienced, but it does sound like a misfire. Link to post Share on other sites More sharing options...
Kiat626 1st Gear May 8, 2015 Share May 8, 2015 Guess work is only good for symptoms common to a model. Use OBD to isolate first. Go to workshops with the right tool. Link to post Share on other sites More sharing options...
Deividz 5th Gear May 8, 2015 Share May 8, 2015 My car started shivering today. Diagnosis - ignition coil. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 8, 2015 Share May 8, 2015 Yeah. I also think it's misfiring. Worn spark plug won't activate CEL. Link to post Share on other sites More sharing options...
Sei_fei_loh 1st Gear May 8, 2015 Share May 8, 2015 Maybe MAF sensor faulty or dirty Link to post Share on other sites More sharing options...
flashbang Turbocharged May 9, 2015 Share May 9, 2015 Buy a cheap OBD2 bluetooth adapter from Dealextreme, I got one from them as well and it works great. For engine codes you can google them to get a better idea of what they mean as some code names are not clear. Link to post Share on other sites More sharing options...
Leroyluo85 1st Gear May 9, 2015 Share May 9, 2015 Blinking check engine light usually due to misfiring... 1 Link to post Share on other sites More sharing options...
Tennis_ball Clutched May 10, 2015 Author Share May 10, 2015 it is misfiring from the code. initially p0300. but after changing coil and spark plugs, it still has misfiring with p0302. 2nd cylinder misfiring. just hope it is not something seriously bad and will have to spend a bomb. still yet to diagnose what exactly it is. Link to post Share on other sites More sharing options...
Contipro 5th Gear August 13, 2017 Share August 13, 2017 it is misfiring from the code. initially p0300. but after changing coil and spark plugs, it still has misfiring with p0302. 2nd cylinder misfiring. just hope it is not something seriously bad and will have to spend a bomb. still yet to diagnose what exactly it is.Hi.. do u still remember at the end what is the cause?I am experiencing the same issue on my ride. Link to post Share on other sites More sharing options...
Wavvyykaa October 24, 2017 Share October 24, 2017 Hi Need help There is this roaring sound from engine compartment when car move off from stationary sounded very rough. Normally about 2000rpm onwards. When ok highway which rpm is normally below 2000 there is not significant sound. This roaring sound will sometimes disappear and it will be smooth like baby but most of time it is around. Abit like modified exhaust sound but my car is stock. When in neutral and accelerate there is no sound thus engine should be fine and exhaust not leaking. Honda vezel 2015, 60k mileage Link to post Share on other sites More sharing options...
GravityBlue 4th Gear October 27, 2017 Share October 27, 2017 Hi Need help There is this roaring sound from engine compartment when car move off from stationary sounded very rough. Normally about 2000rpm onwards. When ok highway which rpm is normally below 2000 there is not significant sound. This roaring sound will sometimes disappear and it will be smooth like baby but most of time it is around. Abit like modified exhaust sound but my car is stock. When in neutral and accelerate there is no sound thus engine should be fine and exhaust not leaking. Honda vezel 2015, 60k mileage Let me make a wild guess , likely a worn bearings from the drive train. Could be ac compressor , tensional pulley , alternator .... Link to post Share on other sites More sharing options...
Wavvyykaa October 27, 2017 Share October 27, 2017 Let me make a wild guess , likely a worn bearings from the drive train. Could be ac compressor , tensional pulley , alternator .... I was guessing the drive train bearing, is it normally located along the moving shaft linked to the wheel bearings? I notice my wheel bearing is also a bit wear out. But weird that the sound only appears when I accelerate Link to post Share on other sites More sharing options...
GravityBlue 4th Gear October 27, 2017 Share October 27, 2017 I was guessing the drive train bearing, is it normally located along the moving shaft linked to the wheel bearings? I notice my wheel bearing is also a bit wear out. But weird that the sound only appears when I accelerate From pass experience , roaring sound that comes n go (intermittent) normally caused by bearing. Get it check by experienced mechanic. Link to post Share on other sites More sharing options...
nahana92 Neutral Newbie August 19, 2019 Share August 19, 2019 hi, have a problem today. hope you guys know what it is. kia forte 1.6sx of 5 years and 4 months old, 77Kkm mileage. Today the car jerks at idle at red light, and i can see that RPM slight jumps up and down, like 400rpm - 700rpm. Usually it is idle at 400rpm without up and down. The jerk is about every 4 seconds, not constant jerking. can feel the car tremble. When i press the throttle to accelerate during travelling, the car will jerk again, and does not accelerate instantly as normal. after a while it accelerates to a higher cruising speed, then it's OK again. During jerking, the engine light flashes like 10 times. when the jerk stops, engine light becomes off again. I just changed engine oil and engine filter 2 months ago. Is this worn spark plugs, or ATF due to change (coz it's been a while), or both, or something else? Thanks. Hi, I am having the same problem. May I know what is the actual cause? And how much is the cost to repair? ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Kia EV6
2022 Kia EV6
Kia EV9 Concept
Kia EV9 Concept
2025 Kia K4 (Replacement of Cerato)
KIA K3 Owners check-in!
Kia Stonic
Kia Stonic
Kia K5
Kia K5
