Abdulwz 52 1st Gear April 11, 2016 Congrats! What's the est delivery date your SE advise?End May or early June.... ↡ Advertisement Share this post Link to post Share on other sites
newbie12345 17 1st Gear April 11, 2016 Anybody have gone to the workshop? Care to share what is it all about?? Share this post Link to post Share on other sites
razor54 318 3rd Gear April 11, 2016 (edited) Bros driving the XT variant, do you notice any difference between running 95 and 98 petrol grade? The notice on the petrol flip door showed to use 95 and above but the manual recommended 98, although it also mentioned that using 95 will not cause damage to the engine. SE also said 95 will do. I have read somewhere that using 95 will have effect of power being reduced. Not sure how true... So asking XT drivers here for your experience if you have tried both grades. Edited April 11, 2016 by razor54 Share this post Link to post Share on other sites
stripes 19 1st Gear April 12, 2016 Anybody have gone to the workshop? Care to share what is it all about?? 1st part watch video in the theatre. After that the engineer will bring you to the car and explain to you parts of the engine bay and interior and operational use. What you can touch in the engine and what not to touch... what petrol grade to use for XT and which grade for NA. I think it was quite good. I would recommend you to attend. If you got questions on your DUO points, got 1 personnel there to explain to you also. Share this post Link to post Share on other sites
razor54 318 3rd Gear April 12, 2016 1st part watch video in the theatre. After that the engineer will bring you to the car and explain to you parts of the engine bay and interior and operational use. What you can touch in the engine and what not to touch... what petrol grade to use for XT and which grade for NA. I think it was quite good. I would recommend you to attend. If you got questions on your DUO points, got 1 personnel there to explain to you also. So what's the engineer's recommendation of petrol grade for XT? Share this post Link to post Share on other sites
stripes 19 1st Gear April 12, 2016 So what's the engineer's recommendation of petrol grade for XT?He recommended 0W40 for XT. For NA he mentioned 0W30. Share this post Link to post Share on other sites
razor54 318 3rd Gear April 12, 2016 He recommended 0W40 for XT. For NA he mentioned 0W30.Sorry I meant the petrol grade. Any information from the engineer on that? Share this post Link to post Share on other sites
stripes 19 1st Gear April 12, 2016 Sorry I meant the petrol grade. Any information from the engineer on that? Not sure if he mentioned cos I left 20 mins early as I had something to attend to. My SE did tell me minimum to pump 95. But the book recommended 98. So I'll stick to the book. Pump 98. If pump 95, obviously the car will lose horsepower. How can a lower grade petrol give you the same power as a higher one? Just my opinion Share this post Link to post Share on other sites
BenTong 9,175 Turbocharged April 12, 2016 (edited) Not sure if he mentioned cos I left 20 mins early as I had something to attend to. My SE did tell me minimum to pump 95. But the book recommended 98. So I'll stick to the book. Pump 98. If pump 95, obviously the car will lose horsepower. How can a lower grade petrol give you the same power as a higher one? Just my opinion three considerations: (Horse power lost & FC goes up) vs $$$ savings (98 vs 95 quite a bit nowadays). Almost $0.3 to 0.35/litre diff. My experience with 95. Don't feel any HP lost on Caltex and SPC. Shell can really feel the HP lost. Esso not tried FC : avg 8-10% more. Edited April 12, 2016 by BenTong Share this post Link to post Share on other sites
Kayaloti 202 2nd Gear April 12, 2016 Wow, you meant this is for NA or XT ? So, 95 will increase your FC? That's interesting. three considerations:(Horse power lost & FC goes up) vs $$$ savings (98 vs 95 quite a bit nowadays)My experience with 95. Don't feel any HP lost on Caltex and SPC. Shell can really feel the HP lost. Esso not triedFC : avg 8-10% more. Share this post Link to post Share on other sites
BenTong 9,175 Turbocharged April 12, 2016 (edited) Wow, you meant this is for NA or XT ? So, 95 will increase your FC? That's interesting. On my previous OB. But still worth it. Coz the price differential b/w 95 vs 98 more than $0.35/litre vs FC increase by 10% or $0.17/litre Edited April 12, 2016 by BenTong 1 Share this post Link to post Share on other sites
razor54 318 3rd Gear April 12, 2016 On my previous OB. But still worth it. Coz the price differential b/w 95 vs 98 more than $0.35/litre vs FC increase by 10% or $0.17/litreThat's a good way to calculate the savings. From what I gathered so far, 95 is able to be used in the current generation XT turbo charged engine. But because of the higher compression characteristics of the turbo engine, 98 is still recommended by Subaru. For the XT, power reduction will happen when the engine sensor pick up pinging from the lower RON 95 used and subsequently reduce compression (resulting in power cut) to eliminate the pinging. Petrol RON are calculated to reduce engine ping according to each individual engine model's design and compression to achieve maximum/most efficient combustion and power. Therefore in the case of the XT, power reduction comes not directly from the RON level in 95, but rather from the ECU receiving signals to cut power when ping is detected to prevent engine damage. So if I'm already spending that extra on the XT for the performance of a turbo charged engine, it make more sense to max out the performance from the turbo. Being able to switch to 95 is a good option in the newer engine. Maybe that will happen if petrol prices rocket to ridiculous levels beyond my pocket threshold....hahaha. So far still on my 2nd tank after car collection and using RON 98. I will try RON 95 after my 1st servicing and see if I can feel any discernible real life difference during driving. Share this post Link to post Share on other sites
Jamesgetz 525 4th Gear April 12, 2016 I would strongly advise those with FXT to pump RON98, esp since the compression ratio is quite high. it's not just about 95 resulting in less power but also whether it causes knocking which can be very damaging to the engine. the FXT has knock sensors which will retard the ignition timing if knocking occurs but it's safer to just pump 98 in case the sensors malfunction 1 Share this post Link to post Share on other sites
Wattokkingu 383 3rd Gear April 12, 2016 I would strongly advise those with FXT to pump RON98, esp since the compression ratio is quite high. it's not just about 95 resulting in less power but also whether it causes knocking which can be very damaging to the engine. the FXT has knock sensors which will retard the ignition timing if knocking occurs but it's safer to just pump 98 in case the sensors malfunction From sgcarmart, XT comp ratio is 10.6, just 0.1 higher than NA. Is 10.6 considered high? I have always thought that the Mazda skyactiv engine comp ratio at 14.0 is considered high. But i do agree that follow the car manual to pump the correct fuel type is the best bet. Share this post Link to post Share on other sites
Red_ryder 55 1st Gear April 12, 2016 Hi guys, this is my first Subaru, collecting my car next week! Is it true that for AWD vehicles, if anything happen to one tire need to change all to match? If one tire punctured, or bald, all must change together? Share this post Link to post Share on other sites
razor54 318 3rd Gear April 12, 2016 (edited) From sgcarmart, XT comp ratio is 10.6, just 0.1 higher than NA. Is 10.6 considered high? I have always thought that the Mazda skyactiv engine comp ratio at 14.0 is considered high. But i do agree that follow the car manual to pump the correct fuel type is the best bet.The XT has a higher compression ratio of just 0.6 than the NA. I think there should be more variables to consider when taking into account compression ratio to necessitate the need for higher octane gas. The ridiculously powerful Nissan Skyline GTR R35 has a compression ratio of 9:1, so does the Mitsubishi Evo 10. Like you mentioned, just follow the recommendation from the manual will be the safest bet for the car (provided it's in stock form). Edited April 12, 2016 by razor54 Share this post Link to post Share on other sites
Singtel88 58 1st Gear April 12, 2016 Hi guys, this is my first Subaru, collecting my car next week! Is it true that for AWD vehicles, if anything happen to one tire need to change all to match? If one tire punctured, or bald, all must change together? change in pair good enough... if money no issue change 4 Share this post Link to post Share on other sites
Kayaloti 202 2nd Gear April 12, 2016 I don't really seen any car that had a bold tire one sided, if that's the case perhaps your alignment is way way out. I always changed mine all 4 together as they wore out quite evenly. ↡ Advertisement Share this post Link to post Share on other sites
