Stratovarius Turbocharged July 16, 2020 Share July 16, 2020 On 7/11/2020 at 11:39 PM, WML888 said: Was looking at STi rims (12 spokes), with +55 offset (stock is +45 offset). But, it claims can clear BBK ... is that due to spoke design ? Hmmm.... I always thought stock is +50. To clear most aftermarket bbk, you need at least +45 or +43. Mine is +48 still can clear some 6 pot caliper. Personally, I think STi rims are quite overpriced. ↡ Advertisement Link to post Share on other sites More sharing options...
WML888 2nd Gear July 16, 2020 Share July 16, 2020 3 hours ago, Stratovarius said: Hmmm.... I always thought stock is +50. To clear most aftermarket bbk, you need at least +45 or +43. Mine is +48 still can clear some 6 pot caliper. Personally, I think STi rims are quite overpriced. Wonder which one lighter ? STi tuning with 15 spokes or STi with 12 spokes ? Or just different spoke design ? Link to post Share on other sites More sharing options...
Sunshines11 1st Gear July 27, 2020 Share July 27, 2020 Hi all... I have been having prob in depressing the brake when I need to step on it to start the engine... I have to keep stepping on it harder than usual quite a few times before I manage to start e engine... The brakes work normally once I manage to start e engine... May I know if anyone experience this in their car too? My car ride is just over 3 years, wonder if Subaru will be willing to fix it for free... Thank you so much in advance! 🙂 Link to post Share on other sites More sharing options...
Yippe 1st Gear July 30, 2020 Share July 30, 2020 On 7/27/2020 at 8:51 PM, Sunshines11 said: Hi all... I have been having prob in depressing the brake when I need to step on it to start the engine... I have to keep stepping on it harder than usual quite a few times before I manage to start e engine... The brakes work normally once I manage to start e engine... May I know if anyone experience this in their car too? My car ride is just over 3 years, wonder if Subaru will be willing to fix it for free... Thank you so much in advance! 🙂 Hi, I has tht issue too. last did was replace new vacuum hose, if solve for a few days and back again. I believe tht cause by micro leak in booster, brake get hard after about 5 hrs cause by leaking vacuum inside holding booster. After engine starts everything back to normal (because the vacuum build up again) My leakage period was 12 hrs before and now clock 5 hrs, a few Subies bros here has tht issue too., I´m sure is Mfg defect not sure if they had solved. not sure if MI could fix it, equires booster abt $500, this time I left it tht way. Post here if has improvement after MI svs. Drive Safe. 1 Link to post Share on other sites More sharing options...
Sunshines11 1st Gear July 31, 2020 Share July 31, 2020 Hi Yippe, thks for the reply! I will update here again if there is any update 🙂 Link to post Share on other sites More sharing options...
kenz_26 Neutral Newbie July 31, 2020 Share July 31, 2020 I too have this problem since 2 weeks ago. My ride is about 3.5yrs old. Planning to bring it down to BKS to have a check soon. Link to post Share on other sites More sharing options...
Sunshines11 1st Gear August 1, 2020 Share August 1, 2020 On 7/31/2020 at 7:45 PM, kenz_26 said: I too have this problem since 2 weeks ago. My ride is about 3.5yrs old. Planning to bring it down to BKS to have a check soon. Hi kenz_26, my ride is 2 yrs 4 mths too... Guess it’s a common prob among our forester... I will be servicing my car soon too, I will chk with them what’s e prob and see if Subaru is willing to fix it for free ... Will update you guys soon if there is anything 🙂 Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear August 2, 2020 Share August 2, 2020 On 7/30/2020 at 8:50 AM, Yippe said: Hi, I has tht issue too. last did was replace new vacuum hose, if solve for a few days and back again. I believe tht cause by micro leak in booster, brake get hard after about 5 hrs cause by leaking vacuum inside holding booster. After engine starts everything back to normal (because the vacuum build up again) My leakage period was 12 hrs before and now clock 5 hrs, a few Subies bros here has tht issue too., I´m sure is Mfg defect not sure if they had solved. not sure if MI could fix it, equires booster abt $500, this time I left it tht way. Post here if has improvement after MI svs. Drive Safe. Hi. There is no need to replace hose. Just remove the vaccum hose, apply glue to the highlighted area and replace hose with clamps. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged August 2, 2020 Share August 2, 2020 12 hours ago, Sunshines11 said: Hi kenz_26, my ride is 2 yrs 4 mths too... Guess it’s a common prob among our forester... I will be servicing my car soon too, I will chk with them what’s e prob and see if Subaru is willing to fix it for free ... Will update you guys soon if there is anything 🙂 On 7/31/2020 at 7:45 PM, kenz_26 said: I too have this problem since 2 weeks ago. My ride is about 3.5yrs old. Planning to bring it down to BKS to have a check soon. I just got this problem sorted out by mi. They changed out the brake booster. My ride was over 3 years and mi still honor the warranty when I stated the delay was due to cb and trouble getting appointment with mi. Since Ken and Sunshine's ride is around 3 years, I suggest you go to mi instead. However, you need to leave your car overnight even when mine hardens a couple of hours after parking. 2 Link to post Share on other sites More sharing options...
Yippe 1st Gear August 2, 2020 Share August 2, 2020 1 hour ago, OnceInALifeTime said: Hi. There is no need to replace hose. Just remove the vaccum hose, apply glue to the highlighted area and replace hose with clamps. Yup Bro, that should be the first attempt , I did with sealing casket and replace with new stainless rings. ( you solved yours with our last discussion) leakage after 2 weeks, so suspecting the check valve inside the vaccum hose ( abt. $40 from MI), actually check valve leakage known to be slim. Sunshine and Kenz can tried as recommendation OAT first, it easier. OAT gave me head-up on the sealing that I not did after new hose replacement, will seal and test again. Cheer and safe drive. Link to post Share on other sites More sharing options...
Sunshines11 1st Gear August 7, 2020 Share August 7, 2020 Hihi... I managed to bring my car down to MI and they replaced the brake booster out of goodwill for free... My warranty has just expired and they are still willing to honour the warranty... I am not sure if it’s because we have been bringing back our car back for servicing for the 1st 3 years... Thks all for the sharing esp Stratovarius! 🙂 3 Link to post Share on other sites More sharing options...
shutterbox 3rd Gear August 15, 2020 Share August 15, 2020 On 7/27/2020 at 10:51 PM, Sunshines11 said: Hi all... I have been having prob in depressing the brake when I need to step on it to start the engine... I have to keep stepping on it harder than usual quite a few times before I manage to start e engine... The brakes work normally once I manage to start e engine... May I know if anyone experience this in their car too? My car ride is just over 3 years, wonder if Subaru will be willing to fix it for free... Thank you so much in advance! 🙂 Brake booster problem. If still under warranty, get MI to fix Link to post Share on other sites More sharing options...
James996 4th Gear August 28, 2020 Share August 28, 2020 Had my rims and tires changed. Thanks to richard_crl032 for sharing about rims and tire sizes. 1 Link to post Share on other sites More sharing options...
WML888 2nd Gear August 28, 2020 Share August 28, 2020 1 hour ago, James996 said: Had my rims and tires changed. Thanks to richard_crl032 for sharing about rims and tire sizes. Nice rims ! What is the offset ? 1 Link to post Share on other sites More sharing options...
James996 4th Gear August 30, 2020 Share August 30, 2020 On 8/28/2020 at 10:08 PM, WML888 said: Nice rims ! What is the offset ? 18 x 8.5jj, Offset 42. Link to post Share on other sites More sharing options...
olisg 1st Gear August 31, 2020 Share August 31, 2020 Wah sweet, enkei rs05rr rims, i am also going to change into this rims, i was thinking of primacy 4 with this tyre, how is this tyre Link to post Share on other sites More sharing options...
moremore1212 Neutral Newbie August 31, 2020 Share August 31, 2020 anyone is looking for SPMP package ? mine left 3 times and willing to transfer. Link to post Share on other sites More sharing options...
James996 4th Gear September 1, 2020 Share September 1, 2020 14 hours ago, olisg said: Wah sweet, enkei rs05rr rims, i am also going to change into this rims, i was thinking of primacy 4 with this tyre, how is this tyre great minds think alike...Kekeke. I used this GYA5 on previous ride and like the performances on the dry and esp wet, so decided to fit on the forester. Had a few choices, RE004, GYA5, Primacy 4. Wanted to try RE004 but still remember the noisy sticky RE003, so decided to pass since not so much review as new model. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Subaru Solterra BEV
Advice on exhaust.
Advice on exhaust.
New Subaru XV
New Subaru XV
