Tohto Hypersonic November 2, 2019 Share November 2, 2019 My 3.5yrs got a lot squeaky noise from all the door rubber seal. After bought this and applied on the rubber. Noise is gone. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
inlinesix Supersonic November 2, 2019 Share November 2, 2019 49 minutes ago, Tohto said: My 3.5yrs got a lot squeaky noise from all the door rubber seal. After bought this and applied on the rubber. Noise is gone. Remember to reapply later 1 Link to post Share on other sites More sharing options...
zendriver Neutral Newbie November 11, 2019 Share November 11, 2019 Hey guys, recently I brought my car for servicing and changed the rear brake pads, spark plug and maintenance of the engine gasket. Right after the brake pads were changed, I began to hear squeaky noises when the car was travelling at low speeds. The strange thing is when the noise will only appear when the engine gets warmer. I’m thinking if it’s the disc rotors as they appeared to have grooves on it. Anyone has any idea? 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator November 11, 2019 Share November 11, 2019 37 minutes ago, zendriver said: Hey guys, recently I brought my car for servicing and changed the rear brake pads, spark plug and maintenance of the engine gasket. Right after the brake pads were changed, I began to hear squeaky noises when the car was travelling at low speeds. The strange thing is when the noise will only appear when the engine gets warmer. I’m thinking if it’s the disc rotors as they appeared to have grooves on it. Anyone has any idea? Squeak sounds that go away or change when the car warms up can be a challenge to locate because they don’t stick around long making them difficult to catch soon enough. If it changes with the RPM’s (revolution per minute), then the noise is coming from the motor. If the noise changes with the speed you drive, then it is coming from the wheels or an axle. Can bring back to check with your mech if you are worried. 🙂 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear November 11, 2019 Share November 11, 2019 @RadX Link to post Share on other sites More sharing options...
abovealllimofl Neutral Newbie November 14, 2019 Share November 14, 2019 Hi Most car noises come from the engine, belts and pulleys, hoses, exhaust system, tires, suspension system, tire to pavement contact, braking and aerodynamic interference. You can remove the interior panels where you think the source of the rattle is coming from. Cut the sound deadening to fit behind the panel with scissors or shears. Thanks ↡ Advertisement 1 Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
Nissan QashQai 2014 Part 2
Nissan Teana Experience
2023 Tan Chong Car Challenge
2018 Nissan Serena e-POWER
