Mkl22 Twincharged October 15, 2018 Share October 15, 2018 same....just one under fluorescent lighting and one under natural sunlight. is it red or orange? back never paint? ↡ Advertisement Link to post Share on other sites More sharing options...
Vratenza Supersonic October 15, 2018 Share October 15, 2018 (edited) Red. It is brembo OEM 4 Potter anyway. Here's the before..the brakes that comes with amg-line cars.. .. Felt little weird when I saw them use chemical to brush off the Mercedes Benz wordings while prepping the surface for paint job. is it red or orange? back never paint? Edited October 15, 2018 by Vratenza 2 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear October 15, 2018 Share October 15, 2018 Red. It is brembo OEM 4 Potter anyway. Here's the before..the brakes that comes with amg-line cars.. .. Felt little weird when I saw them use chemical to brush off the Mercedes Benz wordings while prepping the surface for paint job. 20181012_101709-picsay.jpg 20181012_132135-picsay.jpg nice, i quite like this stock amg line brake kit. very subtle Link to post Share on other sites More sharing options...
Vratenza Supersonic October 15, 2018 Share October 15, 2018 Very good set of brakes, nicely modulated and braking power for cars with weight and power output in likes of glc 200/250 Performance wise nothing to fault. so decided to keep the brakes and just beng it up. nice, i quite like this stock amg line brake kit. very subtle 1 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear October 15, 2018 Share October 15, 2018 Very good set of brakes, nicely modulated and braking power for cars with weight and power output in likes of glc 200/250 Performance wise nothing to fault. so decided to keep the brakes and just beng it up. 6 pot might look nicer but overkill. don't need waste money haha Link to post Share on other sites More sharing options...
Vratenza Supersonic October 15, 2018 Share October 15, 2018 yes... saw a 8 pot neon green tarox on an vellfire before..... 6 pot might look nicer but overkill. don't need waste money haha Link to post Share on other sites More sharing options...
Yuendi 3rd Gear October 19, 2018 Share October 19, 2018 When a PI shows an item on their spec-sheet as "Sports Suspension", does it means "AMG Suspension", or does it refers to the lowering of the normal GLC spring like what Cycle is doing with their GLC Coupe. Link to post Share on other sites More sharing options...
Daniel_Ling Neutral Newbie October 19, 2018 Share October 19, 2018 When a PI shows an item on their spec-sheet as "Sports Suspension", does it means "AMG Suspension", or does it refers to the lowering of the normal GLC spring like what Cycle is doing with their GLC Coupe. 3 Suspensions come with the GLC : - Standard Suspension (most models) - Sports Suspension (AMG Line) - Air Suspension (Additional option to be purchased for non AMG GL43/GL63 models) Link to post Share on other sites More sharing options...
Yuendi 3rd Gear October 19, 2018 Share October 19, 2018 Thanks. Link to post Share on other sites More sharing options...
Daniel_Ling Neutral Newbie October 24, 2018 Share October 24, 2018 Anyone here bought replacement wiper fluid? Do I need to get the Mercedes original ones? Stockist or C&C? Thanks Link to post Share on other sites More sharing options...
Dice 3rd Gear October 24, 2018 Author Share October 24, 2018 Anyone here bought replacement wiper fluid? Do I need to get the Mercedes original ones? Stockist or C&C? ThanksAiyo, can just use water la. Link to post Share on other sites More sharing options...
inlinesix Supersonic October 24, 2018 Share October 24, 2018 Aiyo, can just use water la.That was my thought till I use BMW summer wiper fluid. No more squeaky wiper now. Anyone here bought replacement wiper fluid? Do I need to get the Mercedes original ones? Stockist or C&C? ThanksJuz go parts department to get it. Rem to dilute it more than required. Very likely to be very soapy Link to post Share on other sites More sharing options...
Throttle2 Supersonic October 24, 2018 Share October 24, 2018 (edited) Just beng my ride ..... 20181012_121138-picsay.jpg 20181012_132147-picsay.jpg Wah lau, sibei beng leh, Doc! Muayhahahahahahahaha Ok lah forgive you. You are at least 10yrs my junior Can lah can lah Edited October 24, 2018 by Throttle2 2 Link to post Share on other sites More sharing options...
Yuendi 3rd Gear October 24, 2018 Share October 24, 2018 What is your rims specs? Usually from what I know, the wider rear rims will require a wider tyre compared to the front. Good choice in the design of the rims..Like it. PM me the details? This is an old message that I have dug out.. I'm also curious to know.. is it really possible to pop in 4 identical tyres to staggered rims? If so, it will allow rotation of tyres. Link to post Share on other sites More sharing options...
Sunny Hypersonic October 24, 2018 Share October 24, 2018 This is an old message that I have dug out.. I'm also curious to know.. is it really possible to pop in 4 identical tyres to staggered rims? If so, it will allow rotation of tyres.Staggered means no rotation of tyres 2 Link to post Share on other sites More sharing options...
Vratenza Supersonic October 24, 2018 Share October 24, 2018 yes, have it 4 same tyres on my current staggered rims like @Sunny. Each rim width can take a range of tyre widths. The tyre/rim shop should be able to give a guidance if your particular rim width can use a certain tyre profile. Technically, if you insist, can be rotated, just more leh chey, need the shop to dismount the tyres and remount it on the corresponding rims. Most shop would probably charge you an arm just to do that. This is an old message that I have dug out.. I'm also curious to know.. is it really possible to pop in 4 identical tyres to staggered rims? If so, it will allow rotation of tyres. 2 Link to post Share on other sites More sharing options...
Yuendi 3rd Gear October 24, 2018 Share October 24, 2018 yes, have it 4 same tyres on my current staggered rims like @Sunny. Each rim width can take a range of tyre widths. The tyre/rim shop should be able to give a guidance if your particular rim width can use a certain tyre profile. Technically, if you insist, can be rotated, just more leh chey, need the shop to dismount the tyres and remount it on the corresponding rims. Most shop would probably charge you an arm just to do that. Oic.. sounds like though you put 4 identical tyres on the staggered rims, you dont rotate tyres ? Link to post Share on other sites More sharing options...
Vratenza Supersonic October 24, 2018 Share October 24, 2018 Nope. once you stagger the general rule of thumb is you give up rotation. Rotation is mainly to even out any uneven wear on the tires to prolong their lifespan....how much of the lifespan you prolong is debatable. This is another reason why a lot of people hesitate to go stagger set up for the increased running cost as you might need to change your tyres more frequently. Oic.. sounds like though you put 4 identical tyres on the staggered rims, you dont rotate tyres ? ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Mercedes CLE
Mercedes CLE
New Subaru XV
New Subaru XV
Kia EV9 Concept
Kia EV9 Concept
Kia Stonic
Kia Stonic
W212 owners, please check-in
