t0y0ta Supercharged October 18, 2021 Share October 18, 2021 2 hours ago, xiaosi01 said: @t0y0ta thank you for the advice. 👍🏼 At least you got a 2.0 luxury sedan at 140k..... already saved a lot of money compared to 320 or C180... now is time you may need to re-invest some of the savings 😁 ↡ Advertisement Link to post Share on other sites More sharing options...
Mkl22 Twincharged October 18, 2021 Share October 18, 2021 18 hours ago, xiaosi01 said: Mileage is 60000km now. Car is 4 years old. Still have 1 year warranty with Audi. All along servicing with Audi and car in stock condition. main seal should be under warranty. it can be a wear item but at a much higher mileage typically above 100k. i think you need to insist. try to see if you can search the web for main seal warranty in other countries. The other thing to note is if this warranty is by Audi Singapore via insurance base or via Audi GmbH which is the factory warranty. if insurance based, typically they come up with all cock and bull to deny. Link to post Share on other sites More sharing options...
t0y0ta Supercharged October 18, 2021 Share October 18, 2021 1 hour ago, Mkl22 said: main seal should be under warranty. it can be a wear item but at a much higher mileage typically above 100k. i think you need to insist. try to see if you can search the web for main seal warranty in other countries. The other thing to note is if this warranty is by Audi Singapore via insurance base or via Audi GmbH which is the factory warranty. if insurance based, typically they come up with all cock and bull to deny. TS had said 4th year.... most probably insurance based. And this should be a really big ticket labour item. Link to post Share on other sites More sharing options...
Wt_know Supersonic October 18, 2021 Share October 18, 2021 5 minutes ago, t0y0ta said: TS had said 4th year.... most probably insurance based. And this should be a really big ticket labour item. yeah. 1st 3 year claim Audi, 4th and 5th year is local warranty right? 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged October 18, 2021 Share October 18, 2021 47 minutes ago, Wt_know said: yeah. 1st 3 year claim Audi, 4th and 5th year is local warranty right? 4th and 5th year on paper is warranty but most of the time is claim ownself. 😁 Link to post Share on other sites More sharing options...
xiaosi01 Clutched October 24, 2021 Share October 24, 2021 @Mkl22 Hi Guys, to update. Audi Singapore finally honor the warranty claim for my main seal leak issue after I wrote them a long email and attached the Audi warranty handbook. Handbook did not mentioned main seal is consider wear and tear And my car is only 4 years old. 9 Link to post Share on other sites More sharing options...
epigram Clutched October 24, 2021 Share October 24, 2021 Kudos for your persistence! Link to post Share on other sites More sharing options...
Wt_know Supersonic October 24, 2021 Share October 24, 2021 (edited) 2 hours ago, epigram said: Kudos for your persistence! bookmark for future reference .... Edited October 24, 2021 by Wt_know Link to post Share on other sites More sharing options...
bruce76 1st Gear October 24, 2021 Share October 24, 2021 @xiaosi01 that's the way...back up with facts and reasonableness Link to post Share on other sites More sharing options...
epigram Clutched November 2, 2021 Share November 2, 2021 Hi, anyone having this problem? MMI works as Guest but whenever you try to add a User, this happens... Link to post Share on other sites More sharing options...
trd2970 Clutched September 27, 2022 Share September 27, 2022 @ziege On 3/27/2018 at 9:12 PM, ziege said: the 16 " are indeed forged rims and are around 7+ kg each. Compared to the A3's 16 " rims, those are around 10kg each Confirmed forged. look at the rear of the rim. Wordings are engraving and don’t see any indentations or recesses that look casted from mould 1 Link to post Share on other sites More sharing options...
183795_1566627385 Neutral Newbie October 12, 2022 Share October 12, 2022 Hi, I am new here. Would like to seek some advice from the pros if going 18" makes more sense or 19 for A4 1.4 B9. Thank you Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 12, 2022 Share October 12, 2022 19“ for look and better handling that lower profile tyres provide. Link to post Share on other sites More sharing options...
macrosszero Turbocharged October 13, 2022 Share October 13, 2022 12 hours ago, 183795_1566627385 said: Hi, I am new here. Would like to seek some advice from the pros if going 18" makes more sense or 19 for A4 1.4 B9. Thank you Larger rims will be heavier and you have a tiny 1.4 putting out barely 150hp to push along that Conti barge. Some may argue that aftermarket rims are lighter than stock, then I would argue apples to apples aftermarket 18 is always lighter than 19 in the same design too. It is always going to cost you performance and fuel economy. Going larger rim also means you lose comfort due to less sidewall. Finally, the car looks funny if it has big rims but tiny brake rotors. 3 1 Link to post Share on other sites More sharing options...
Wt_know Supersonic October 13, 2022 Share October 13, 2022 (edited) A4=18" , A6=19" ... simple equations ... lol Edited October 13, 2022 by Wt_know Link to post Share on other sites More sharing options...
Poopular 1st Gear October 15, 2022 Share October 15, 2022 Hi, I am driving a A4 B9, car at 4th year and time to change the battery. Anyone has workshop to recommend for the change in battery? Link to post Share on other sites More sharing options...
Mach23 2nd Gear October 16, 2022 Share October 16, 2022 Search Carousell and message the shops for quotation for your car model. Link to post Share on other sites More sharing options...
183795_1566627385 Neutral Newbie October 18, 2022 Share October 18, 2022 On 10/13/2022 at 9:29 AM, Macrosszero said: Larger rims will be heavier and you have a tiny 1.4 putting out barely 150hp to push along that Conti barge. Some may argue that aftermarket rims are lighter than stock, then I would argue apples to apples aftermarket 18 is always lighter than 19 in the same design too. It is always going to cost you performance and fuel economy. Going larger rim also means you lose comfort due to less sidewall. Finally, the car looks funny if it has big rims but tiny brake rotors. aww, thank you for sharing! ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda EZ-6
2025 Mazda EZ-6
MAZDA 6
MAZDA 6
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
