WangZhizhong 1st Gear May 5, 2019 Share May 5, 2019 Anyone manage to use mi max 3 on android auto? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Selesurge 1st Gear May 8, 2019 Share May 8, 2019 Any kind souls car to share their ICE upgrades? Its been half a year and i have yet to move in my old setup. Anybody can share pics of their retrofitted headunits in place of the original? The factory installed ones in the first batch of AD sucks big time, the volume control is erratic, soundquality is generally bad and the bluetooth connectivity is spotty. I will be replacing it with my old Pioneer AVH 5850. I had bought the fascia from aliexpress, but am not sure if I still need to get the interface cable for the steering remote, or the existing one works fine? (BTW, the headunit of the first batch ADs are actually cheap Chinese 3rd party ones, only the later batches with Android play are actual factory installed from Korea) Link to post Share on other sites More sharing options...
Devilcup 3rd Gear May 10, 2019 Share May 10, 2019 just did my 20k and they seems to lube the steering column the sound of the steering is not much Link to post Share on other sites More sharing options...
Splinter 2nd Gear May 10, 2019 Share May 10, 2019 Any kind souls car to share their ICE upgrades? Its been half a year and i have yet to move in my old setup. Anybody can share pics of their retrofitted headunits in place of the original? The factory installed ones in the first batch of AD sucks big time, the volume control is erratic, soundquality is generally bad and the bluetooth connectivity is spotty. I will be replacing it with my old Pioneer AVH 5850. I had bought the fascia from aliexpress, but am not sure if I still need to get the interface cable for the steering remote, or the existing one works fine? (BTW, the headunit of the first batch ADs are actually cheap Chinese 3rd party ones, only the later batches with Android play are actual factory installed from Korea) I took the same route as you. I upgraded to Pioneer avh-z5250bt last week and while combing through Taobao, I found out our non-standard head units are actually available for purchase on Taobao as well. Back to your question, from my experience, Pioneer head unit can be programmed to steering control, so you still retain the use of your steering control. Link to post Share on other sites More sharing options...
Matrix0405 5th Gear May 11, 2019 Share May 11, 2019 Any tips & tricks to make the stock HU play video (from USB drive or handphone)? Link to post Share on other sites More sharing options...
Ivan_06 5th Gear May 11, 2019 Share May 11, 2019 Any tips & tricks to make the stock HU play video (from USB drive or handphone)?Must hack android auto. Root it. Link to post Share on other sites More sharing options...
Selesurge 1st Gear May 11, 2019 Share May 11, 2019 I took the same route as you. I upgraded to Pioneer avh-z5250bt last week and while combing through Taobao, I found out our non-standard head units are actually available for purchase on Taobao as well. Back to your question, from my experience, Pioneer head unit can be programmed to steering control, so you still retain the use of your steering control. So meaning to say the steering controls can be installed and programmed directly without the need for 3rd party connectors or wiring?? Link to post Share on other sites More sharing options...
Splinter 2nd Gear May 11, 2019 Share May 11, 2019 So meaning to say the steering controls can be installed and programmed directly without the need for 3rd party connectors or wiring?? For my case - AVH-Z5250BT, yes. There's a wire in the harness that connects to the steering control wire. After it's connected, the installer or yourself will use the steering control settings in Pioneer head unit to learn the steering controls. Do note that the brake wire has to be wired up to access steering control settings. Link to post Share on other sites More sharing options...
Xenotech 1st Gear May 14, 2019 Share May 14, 2019 just did my 20k and they seems to lube the steering column the sound of the steering is not much Hi, did you order a new steering column? Just saying, lubing is not solving the root cause of the problem. And since car is under warranty, might as well get it replaced. My part is here, I will be changing it at end of this month during my 20k service as well. Will update again how things go. 1 Link to post Share on other sites More sharing options...
Familymanz 3rd Gear May 14, 2019 Share May 14, 2019 Hi, did you order a new steering column? Just saying, lubing is not solving the root cause of the problem. And since car is under warranty, might as well get it replaced. My part is here, I will be changing it at end of this month during my 20k service as well. Will update again how things go. I'm changing mine tomorrow Link to post Share on other sites More sharing options...
Devilcup 3rd Gear May 14, 2019 Share May 14, 2019 (edited) Hi, did you order a new steering column? Just saying, lubing is not solving the root cause of the problem. And since car is under warranty, might as well get it replaced. My part is here, I will be changing it at end of this month during my 20k service as well. Will update again how things go. i agree on that. i will continue to monitor and see if it get worse. if so, i will go down and get it change. dun mind share the feeling of the steering after change. if the whining sound gone completely? Edited May 14, 2019 by Devilcup 1 Link to post Share on other sites More sharing options...
Familymanz 3rd Gear May 15, 2019 Share May 15, 2019 I'm changing mine tomorrow4hrs.... Link to post Share on other sites More sharing options...
poresia 2nd Gear May 15, 2019 Share May 15, 2019 4hrs.... i seem to have this problem too. may report it at my coming 40k Servicing. actually, i didnt go back to KM for 20k Servicing. i am not sure if my problem is same as bros here. its tight n have sound but not very loud. 1 Link to post Share on other sites More sharing options...
Tiger1 6th Gear May 15, 2019 Share May 15, 2019 What's the sound you hearing? Link to post Share on other sites More sharing options...
Kurty Supercharged May 15, 2019 Share May 15, 2019 Any kind souls car to share their ICE upgrades? Its been half a year and i have yet to move in my old setup. Anybody can share pics of their retrofitted headunits in place of the original? The factory installed ones in the first batch of AD sucks big time, the volume control is erratic, soundquality is generally bad and the bluetooth connectivity is spotty. I will be replacing it with my old Pioneer AVH 5850. I had bought the fascia from aliexpress, but am not sure if I still need to get the interface cable for the steering remote, or the existing one works fine? (BTW, the headunit of the first batch ADs are actually cheap Chinese 3rd party ones, only the later batches with Android play are actual factory installed from Korea) i only added a full range 2.5" speaker, pretty good and doable for my ears 1 Link to post Share on other sites More sharing options...
Familymanz 3rd Gear May 15, 2019 Share May 15, 2019 i seem to have this problem too. may report it at my coming 40k Servicing. actually, i didnt go back to KM for 20k Servicing. i am not sure if my problem is same as bros here. its tight n have sound but not very loud. 40k.. Which batch of elantra? Current issue largely to 2018 batch Link to post Share on other sites More sharing options...
poresia 2nd Gear May 15, 2019 Share May 15, 2019 What's the sound you hearing?Like steering wheel very hard to turn. 1 Link to post Share on other sites More sharing options...
Tiger1 6th Gear May 15, 2019 Share May 15, 2019 Like steering wheel very hard to turn.Thanks. Mine is... After I started my car, the first touch of the steering wheel would have a soft "tud". ↡ Advertisement Link to post Share on other sites More sharing options...
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
Kia Stonic
Kia Stonic
