KennyLi Neutral Newbie October 9, 2018 Share October 9, 2018 Same bro... Tomorrow 5th day... What can we do other than wait...My car also registered on 2 Oct. Till now still no call to go collect ↡ Advertisement Link to post Share on other sites More sharing options...
WangZhizhong 1st Gear October 9, 2018 Share October 9, 2018 My car also registered on 2 Oct. Till now still no call to go collectUnderstand the feeling bro... Link to post Share on other sites More sharing options...
KennyLi Neutral Newbie October 9, 2018 Share October 9, 2018 Understand the feeling bro...Bo bian. Nothing we can do since people say there is alot car there. Link to post Share on other sites More sharing options...
Johnnylim 5th Gear October 9, 2018 Share October 9, 2018 Going N to D and D to N wear down your shift cable and clutch band. So under what circumstances then we use the 'N'? Or can ignore its existence? Link to post Share on other sites More sharing options...
Kippei 3rd Gear October 9, 2018 Share October 9, 2018 So under what circumstances then we use the 'N'? Or can ignore its existence? When you know you gonna be stopping for a long time or traffic jam. Link to post Share on other sites More sharing options...
Johnnylim 5th Gear October 9, 2018 Share October 9, 2018 When you know you gonna be stopping for a long time or traffic jam. But then u mentioned will wear down your shift cable and clutch band, so shld I shift to 'P' instead? Link to post Share on other sites More sharing options...
Contipro 5th Gear October 9, 2018 Share October 9, 2018 But then u mentioned will wear down your shift cable and clutch band, so shld I shift to 'P' instead?to overcome this concern, best switch to hybrid.no need to switch as accelerate and deaccelerate also connected for each respective purpose. Link to post Share on other sites More sharing options...
Devilcup 3rd Gear October 9, 2018 Share October 9, 2018 (edited) But then u mentioned will wear down your shift cable and clutch band, so shld I shift to 'P' instead?it is ok to leave as drive on traffic... ur brake pedal should tell ur engine disengage to gearbox. only ur torque converter is spinning. as for the cable... prolong using will wear down. this is wear and tear.. but i think it will still last 10 yrs... the only concern is the stop latch when you engage p... it is best practice to put ur gear in n mode pull handbrake then engage p. still AT will still wear out... it is good to change ATF accordingly to spec.. i prefer every 40 to 50k km interval. Edited October 9, 2018 by Devilcup Link to post Share on other sites More sharing options...
Bond2222 2nd Gear October 9, 2018 Share October 9, 2018 anyone tried the komoco one time servicing package cost about $200 plus before? Do I get further discount if I bring my own engine oil? Link to post Share on other sites More sharing options...
Johnnylim 5th Gear October 9, 2018 Share October 9, 2018 it is ok to leave as drive on traffic... ur brake pedal should tell ur engine disengage to gearbox. only ur torque converter is spinning. as for the cable... prolong using will wear down. this is wear and tear.. but i think it will still last 10 yrs... the only concern is the stop latch when you engage p... it is best practice to put ur gear in n mode pull handbrake then engage p. still AT will still wear out... it is good to change ATF accordingly to spec.. i prefer every 40 to 50k km interval. I'm looking at the next alternative instead of remaining at 'D' n stepping on the brake at traffic lights/jams as I'm used to engaging at 'N' for my previous manual ride to rest my leg. Still unsure of the best/correct method though. Link to post Share on other sites More sharing options...
CMChong_197462 1st Gear October 9, 2018 Share October 9, 2018 I'm looking at the next alternative instead of remaining at 'D' n stepping on the brake at traffic lights/jams as I'm used to engaging at 'N' for my previous manual ride to rest my leg. Still unsure of the best/correct method though.Same, I'm used to drive manual, sometimes can't judge either wanna swift to N or remain at D while stop at traffic lights. How long is long? Link to post Share on other sites More sharing options...
singcheng 2nd Gear October 9, 2018 Share October 9, 2018 anyone tried the komoco one time servicing package cost about $200 plus before? Do I get further discount if I bring my own engine oil? If you sign up for package with engine oil, don't think you will get money back if you bring your own oil... Link to post Share on other sites More sharing options...
Kurty Supercharged October 10, 2018 Share October 10, 2018 Same, I'm used to drive manual, sometimes can't judge either wanna swift to N or remain at D while stop at traffic lights. How long is long? manual is the best, always remain at N. well, for sg usage, just keep it to D, even the same applies for custom jams. Link to post Share on other sites More sharing options...
Johnnylim 5th Gear October 10, 2018 Share October 10, 2018 Same, I'm used to drive manual, sometimes can't judge either wanna swift to N or remain at D while stop at traffic lights. How long is long? Well, for me, practically every traffic lights stop previously But mine is more routine, so I'm familiar with the duration of the stops. Link to post Share on other sites More sharing options...
13177 Supersonic October 10, 2018 Share October 10, 2018 Same, I'm used to drive manual, sometimes can't judge either wanna swift to N or remain at D while stop at traffic lights. How long is long? Will shifting of the gear from D to N while stopping at traffic lights spoilt the gearbox fast? Link to post Share on other sites More sharing options...
yapjx100 1st Gear October 10, 2018 Share October 10, 2018 (edited) Will shifting of the gear from D to N while stopping at traffic lights spoilt the gearbox fast?I think frequent shifting of gears would obviously wear out the gearbox components faster than if you don’t do it. This includes but is not limited to shifting from D to N when stopped at traffic lights. So, naturally the advice is not to do that unless necessary, if you intend to keep the car for a long long time. Edited October 10, 2018 by yapjx100 Link to post Share on other sites More sharing options...
13177 Supersonic October 10, 2018 Share October 10, 2018 I think frequent shifting of gears would obviously wear out the gearbox components faster than if you don’t do it. This includes but is not limited to shifting from D to N when stopped at traffic lights. So, naturally the advice is not to do that unless necessary, if you intend to keep the car for a long long time. Noticed many people have such habit of shifting the gear to N when stopped at traffic lights. But dont know will it really wear out the gearbox components faster?! 1 Link to post Share on other sites More sharing options...
therock Supersonic October 10, 2018 Share October 10, 2018 The point value of fuel saved is not worth the issues of putting to neutral bros.. If fuel costs are really that large an issue, there are other modes of transport.. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Toyota GR Corolla
2018 Toyota Supra
2018 Toyota Supra
2024 Hyundai Kona Electric Debuts: Refreshed Design, 260-Mile Estimated Range
2018 Kia Cerato K3 / Forte (BD Series) + 2021 Facelift
[Official] 2023 2nd Generation Hyundai Kona
[Seek experts' views] Pioneer Z9250BT vs stock HU
